Each version of the code has two main functions, one for character-wall collision detection and one for character-character collision detection.
The unoptimized character-wall collision implementation is in the function DoWallsPlain(). It is a simple nested loop through all of the characters and all of the walls.
For all characters we want a boolean result which is true when they have hit a wall. Note that in the code there is the assumption that a character can only hit up to two walls at once.
private void DoWallsPlain(int numChar)
  for (int c = 0; c < numChar; ++c)
    for (int s = 0; s < numWalls; ++s)
      staticCollisions[c * numWalls + s] =
          dynamicObjectsVstatic[c].Intersects(staticObjects[s]);
The Intersects function is a simple check for overlapping axis-aligned bounding boxes.
public bool Intersects(StaticCollisionObject other)
  return !(other.minPos.x > maxPos.x
        || other.maxPos.x < minPos.x
        || other.minPos.y > maxPos.y
        || other.maxPos.y < minPos.y);
After the update calls DoWallsPlain to perform the character-wall collision detection, the equivalent for character-character collision is called. This is done in the function called DoCharactersPlain.
DoCharactersPlain contains another simple nested loop. For all characters, it checks if a character hits another character. Again, a boolean value is stored, true indicating that a collision has occurred.
private void DoCharactersPlain(int numChar)
    for (int d = c + 1; d < numChar; ++d)
      dynamicCollisions[c * numChar + d] = dynamicObjects[c].Intersects(dynamicObjects[d]);
Note, the inner loop only ever starts at the character index beyond the index of the outer loop (d = c +1). dynamicCollisions has size enough for all collision pairs.
You could think of this structure as a two-dimensional array: one triangular half contains boolean values for [c][d] and the other for [d][c].
There is no need to check collisions of the reverse (e.g., [d][c]) or a character against itself (i.e., the cases where d equals c).
The Intersects function is a simple radii check; characters have collided if the distance between their centers is less than the sum of their radii.
public bool Intersects(DynamicCollisionObject other)
  float distance = radius + other.radius;
  return math.lengthsq(other.position - position) < distance * distance;
