Collect data from the Profiler
In this section, we will collect data from the Profiler that can be used later in the Profile Analyzer. You will record data from two different versions of the collision sample; unoptimized (or plain) and optimized (using Neon). Later on you will load the data into the Analyzer to visualize and compare the datasets.
Our sample app works best on Android when in landscape orientation. Information will be displayed in the bottom right.
Collect data from unoptimized version
You will now collect some data from the unoptimized version of the code. To do this, save the data from the two builds first and then later load the data into the Analyzer to visualize, and compare the two data sets.
  1. Open the script Assets/BurstNeonCollisions/Scripts/CollisionCalculationScript.cs.
  2. Find line 66. Change it to look like this:
                public const Mode codeMode = Mode.Plain;
  3. Build and deploy to your Android device:
    • Open File/Build Settings
    • Ensure the following options are ticked:
      • Development Build
      • Autoconnect Profiler
    • Ensure your device is selected in Run Device drop-down menu
    • Select Build and Run
    • Enter a path and filename for your Android package (e.g., plain.apk)
    • When the app starts on your device, ensure it says Standard Mode in the bottom right. If not, start again from step 1.
  4. The Profiler window will open
    • Ensure the record button is enabled (it will be red)
    • Let the Profiler record - a few hundred frames or so will be enough for this tutorial
  5. Save the performance data
    • Select the disk icon in the top right of the Profiler window
    • Enter filename
                  plain.data
    • Save to disk
Collect data for the optimized version
Let’s repeat the above process but this time build and deploy the optimized version of the code.
    • Find line 66. Change it should look like this:
                  public const Mode codeMode = Mode.Neon;
    • Build and deploy to your Android device:
      1. Open File/Build Settings
      2. Ensure the following options are ticked:
        • Development Build
    • Enter a path and filename for your Android package (e.g., neon.apk)
    • When the app starts on your device, ensure it says Neon Mode in the bottom right. If not, start again from step 1.
  2. The Profiler window will open
    • Let the Profiler record; again, a few hundred frames or so will be enough for this comparison
  3. Save the performance data
    • Enter filename
                  neon.data
    • Save to disk
Profiler summary
You have now collected performance data for two versions of our build; essentially “pre” and “post” optimization. The optimizations (Burst and Neon) made in this sample will be covered in the next learning path in this series.
Plain.data contains performance data from the unoptimized version. Neon.data contains data from our optimized version.
You now know how to use the Profiler tool to analyze specific frames of performance data and save data for later.
In the next section, we will use the Analyzer tool to visualize and compare the data you have collected.
