Recently Arm has created a set of micro-kernels called KleidiAI that more efficiently use Arm’s i8mm (8-bit integer matrix multiply) processor feature. Arm has worked with the Google AI Edge team to integrate KleidiAI into the MediaPipe framework through XNNPACK. These improvements increase the throughput of quantized LLMs running on Arm chips that contain the i8mm feature.
In this step, you will cross-compile an inference benchmarking executable with and without the i8mm build flag, which will demonstrate the performance gains achieved by using KleidiAI micro-kernels.
To test whether your phone chipset contains the i8mm feature, run:
adb shell cat /proc/cpuinfo | grep i8mm
If any lines are returned, then your phone has the i8mm capability.
You can choose either ‘decode’ or ’encode’ as the method to benchmark latency. Encode in this context, refers to how many tokens are processed in a second. This affects the time to first token, which is the time needed to process the input from the user. Decode refers to how many tokens are generated in a second. These instructions use ’encode’ to benchmark.
Modify the mediapipe/tasks/cc/genai/inference/utils/xnn_utils/llm_test.cc
file to specify encode
as the benchmarking method.
Search for this line:
std::string, benchmark_method, "decode",
And replace with this line:
std::string, benchmark_method, "encode",
You can now build the llm_test
executable. First, lets build it by including support for i8mm
without KleidiAI micro-kernels:
bazel build -c opt --config=android_arm64 --define=xnn_enable_arm_i8mm=true --define=xnn_enable_kleidiai=false --dynamic_mode=off mediapipe/tasks/cc/genai/inference/utils/xnn_utils:llm_test
Push the resulting binary to the phone:
adb push bazel-bin/mediapipe/tasks/cc/genai/inference/utils/xnn_utils/llm_test /data/local/tmp/gen_ai
As before, if you are building from a Docker container, you must first copy the executable from your docker container to your local disk. First find the container ID of your running container by running:
docker ps
And then replace [container ID]
in this command with your running container ID:
docker cp [container ID]:/home/ubuntu/mediapipe/bazel-bin/mediapipe/tasks/cc/genai/inference/utils/xnn_utils/llm_test .
You can then run
adb push llm_test /data/local/tmp/gen_ai
To push the binary to your phone.
Run the binary on the phone via adb shell
adb shell
cd /data/local/tmp/gen_ai
./llm_test
The output should look like this:
husky:/data/local/tmp/gen_ai $ ./llm_test
2024-02-22T16:11:35-06:00
Running ./llm_test
Run on (9 X 1704 MHz CPU s)
***WARNING*** CPU scaling is enabled, the benchmark real time measurements may be noisy and will incur extra overhead.
Benchmark Time CPU Iterations UserCounters...
BM_Llm_QCINT8/512/128/1/real_time 838363322 ns 829751099 ns 1 items_per_second=152.678/s
BM_Llm_QCINT8/512/128/4/real_time 841265137 ns 834988592 ns 1 items_per_second=152.152/s
BM_Llm_QCINT8/512/128/7/real_time 852055258 ns 841642618 ns 1 items_per_second=150.225/s
BM_Llm_QCINT8/512/128/14/real_time 860270793 ns 851762316 ns 1 items_per_second=148.79/s
BM_Llm_QCINT8/512/128/16/real_time 841513062 ns 833101183 ns 1 items_per_second=152.107/s
BM_Llm_QCINT8/512/128/28/real_time 864154582 ns 853668539 ns 1 items_per_second=148.122/s
BM_Llm_QCINT8/512/128/32/real_time 830871257 ns 825545782 ns 1 items_per_second=154.055/s
BM_Llm_QCINT8/512/128/48/real_time 854287110 ns 844283619 ns 1 items_per_second=149.833/s
BM_Llm_QCINT8/512/128/64/real_time 854422201 ns 843630972 ns 1 items_per_second=149.809/s
BM_Llm_Mixed_INT48/512/128/1/real_time 782606446 ns 759264361 ns 1 items_per_second=163.556/s
BM_Llm_Mixed_INT48/512/128/4/real_time 822570557 ns 796060223 ns 1 items_per_second=155.61/s
BM_Llm_Mixed_INT48/512/128/7/real_time 792235759 ns 775831486 ns 1 items_per_second=161.568/s
BM_Llm_Mixed_INT48/512/128/14/real_time 778684611 ns 761880662 ns 1 items_per_second=164.38/s
BM_Llm_Mixed_INT48/512/128/16/real_time 776865235 ns 759403033 ns 1 items_per_second=164.765/s
BM_Llm_Mixed_INT48/512/128/28/real_time 814798707 ns 791258841 ns 1 items_per_second=157.094/s
BM_Llm_Mixed_INT48/512/128/32/real_time 795295655 ns 764343419 ns 1 items_per_second=160.946/s
BM_Llm_Mixed_INT48/512/128/48/real_time 792191082 ns 771217878 ns 1 items_per_second=161.577/s
BM_Llm_Mixed_INT48/512/128/64/real_time 775814250 ns 756604293 ns 1 items_per_second=164.988/s
There is a bit of throughput variation that can happen in each iteration of this benchmark, if you want to run multiple times and get a coefficient of variation you can run it like this:
./llm_test --benchmark_repetitions=10
As you might expect, this will take ten times as long to run, but will give you some nice statistics about the aggregated iterations.
You can now rebuild llm_test
, but this time with the i8mm flag enabled:
bazel build -c opt --config=android_arm64 --define=xnn_enable_arm_i8mm=true --dynamic_mode=off mediapipe/tasks/cc/genai/inference/utils/xnn_utils:llm_test
When you use “–define=xnn_enable_arm_i8mm=true”, the use of KleidiAI micro-kernels is enabled by default.
Perform the same steps as before to push the llm_test
executable to the phone.
Again, run:
adb shell
./llm_test
The output should look like this, with performance dramatically improved for the int4/int8 mixed benchmarks:
2024-02-21T20:22:24-06:00
Running ./llm_test
BM_Llm_QCINT8/512/128/1/real_time 878131633 ns 869451284 ns 1 items_per_second=145.764/s
BM_Llm_QCINT8/512/128/4/real_time 861170695 ns 850807124 ns 1 items_per_second=148.635/s
BM_Llm_QCINT8/512/128/7/real_time 844140096 ns 837621854 ns 1 items_per_second=151.634/s
BM_Llm_QCINT8/512/128/14/real_time 833818278 ns 827093253 ns 1 items_per_second=153.511/s
BM_Llm_QCINT8/512/128/16/real_time 825771973 ns 819266606 ns 1 items_per_second=155.006/s
BM_Llm_QCINT8/512/128/28/real_time 906640219 ns 895908902 ns 1 items_per_second=141.181/s
BM_Llm_QCINT8/512/128/32/real_time 815335613 ns 809224814 ns 1 items_per_second=156.991/s
BM_Llm_QCINT8/512/128/48/real_time 939988810 ns 925805136 ns 1 items_per_second=136.172/s
BM_Llm_QCINT8/512/128/64/real_time 867672364 ns 861572060 ns 1 items_per_second=147.521/s
BM_Llm_Mixed_INT48/512/128/1/real_time 649379069 ns 643777214 ns 1 items_per_second=197.111/s
BM_Llm_Mixed_INT48/512/128/4/real_time 639673380 ns 633901237 ns 1 items_per_second=200.102/s
BM_Llm_Mixed_INT48/512/128/7/real_time 625728760 ns 620227580 ns 1 items_per_second=204.561/s
BM_Llm_Mixed_INT48/512/128/14/real_time 630814657 ns 624941732 ns 1 items_per_second=202.912/s
BM_Llm_Mixed_INT48/512/128/16/real_time 616205852 ns 610839353 ns 1 items_per_second=207.723/s
BM_Llm_Mixed_INT48/512/128/28/real_time 622859253 ns 617623170 ns 1 items_per_second=205.504/s
BM_Llm_Mixed_INT48/512/128/32/real_time 628669597 ns 622151198 ns 1 items_per_second=203.605/s
BM_Llm_Mixed_INT48/512/128/48/real_time 631355876 ns 626120761 ns 1 items_per_second=202.738/s
BM_Llm_Mixed_INT48/512/128/64/real_time 633293213 ns 628101344 ns 1 items_per_second=202.118/s
And as in the previous section, if you want to run multiple times and get a coefficient of variation you can run it like this:
As you can see, by comparing this output to the output in the previous section, the performance improvements are noticeable in the mixed int4/int8 benchmarks. By taking advantage of the KleidiAI micro-kernels, you are able to increase the performance of the i8mm processor feature.
If you would like to learn more about KleidiAI Integration with MediaPipe, please see this KleidiAI blog post .
