To harness the power of hardware ray tracing with Lumen in your application, follow these steps to configure your project settings:
  1. Enable SM5 Shader Format:
    • Lumen operates only when the SM5 shader format is active. Navigate to your project settings under Platforms - Android.
    • Enable the option labeled Support Vulkan Desktop [Experimental] to activate SM5 shader format support, as shown below.
    Image Alt Text:SM5 Shader Format
  2. Select Deferred Shading Mode:
    • Currently, Lumen exclusively supports deferred shading mode. Go to your project settings under Engine - Rendering.
    • Uncheck Forward Shading under the Forward Renderer option, as shown below.
    Image Alt Text:Deferred Shading
  3. Enable Hardware Ray Tracing Support:
    • Next, enable hardware ray tracing for the entire engine. In your project settings under Engine - Rendering, check the box for Support Hardware Ray Tracing, as shown below.
    Image Alt Text:Hardware Ray Tracing
  4. Use Hardware Ray Tracing When Available:
    • As previously mentioned, Lumen can utilize both software and hardware ray tracing. To prioritize hardware acceleration, check Use Hardware Ray Tracing when available in the project settings under Engine - Rendering, as shown below.
    • This setting ensures that your application leverages hardware ray tracing first, falling back to software ray tracing if necessary.
    Image Alt Text:Use Hardware Ray Tracing
  5. Configure Console Variables:
    • Edit your engine configuration file to set up two essential console variables as per the following:
      • Set r.Android.DisableVulkanSM5Support=0 to remove any restrictions related to SM5 shader format usage.
      • Enable Ray Query shader support for Vulkan by setting r.RayTracing.AllowInline=1.
Your Lumen-powered application is now ready to dazzle with hardware-accelerated ray tracing!
