Build Llama runner binary for Android
Cross-compile Llama runner to run on Android using the steps below.
1. Set Android NDK
Set the environment variable to point to the Android NDK:
export ANDROID_NDK=$ANDROID_HOME/ndk/28.0.12433566/
Note
Make sure you can confirm $ANDROID_NDK/build/cmake/android.toolchain.cmake is available for CMake to cross-compile.
2. Build ExecuTorch and associated libraries for Android with KleidiAI
You are now ready to build ExecuTorch for Android by taking advantage of the performance optimization provided by the KleidiAI kernels.
Use cmake to cross-compile ExecuTorch:
cmake -DCMAKE_TOOLCHAIN_FILE=$ANDROID_NDK/build/cmake/android.toolchain.cmake \
    -DANDROID_ABI=arm64-v8a \
    -DANDROID_PLATFORM=android-23 \
    -DEXECUTORCH_BUILD_EXTENSION_NAMED_DATA_MAP=ON \
    -DCMAKE_INSTALL_PREFIX=cmake-out-android \
    -DEXECUTORCH_ENABLE_LOGGING=1 \
    -DCMAKE_BUILD_TYPE=Release \
    -DEXECUTORCH_BUILD_EXTENSION_DATA_LOADER=ON \
    -DEXECUTORCH_BUILD_EXTENSION_MODULE=ON \
    -DEXECUTORCH_BUILD_EXTENSION_TENSOR=ON \
    -DEXECUTORCH_BUILD_EXTENSION_FLAT_TENSOR=ON \
    -DEXECUTORCH_BUILD_XNNPACK=ON \
    -DEXECUTORCH_BUILD_KERNELS_OPTIMIZED=ON \
    -DEXECUTORCH_BUILD_KERNELS_QUANTIZED=ON \
    -DEXECUTORCH_BUILD_KERNELS_CUSTOM=ON \
    -DEXECUTORCH_BUILD_KERNELS_LLM=ON \
    -DEXECUTORCH_BUILD_EXTENSION_LLM_RUNNER=ON \
    -DEXECUTORCH_BUILD_EXTENSION_LLM=ON \
    -DEXECUTORCH_BUILD_EXTENSION_RUNNER_UTIL=ON \
    -DEXECUTORCH_XNNPACK_ENABLE_KLEIDI=ON \
    -DXNNPACK_ENABLE_ARM_BF16=OFF \
    -DBUILD_TESTING=OFF \
    -Bcmake-out-android .
cmake --build cmake-out-android -j7 --target install --config Release
Note
Starting with Executorch version 0.7 beta, KleidiAI is enabled by default. The -DEXECUTORCH_XNNPACK_ENABLE_KLEIDI=ON option is enabled and adds default support for KleidiAI kernels in ExecuTorch with XNNPack.
3. Build Llama runner for Android
Use cmake to cross-compile Llama runner:
    -DPYTHON_EXECUTABLE=python \
    -Bcmake-out-android/examples/models/llama \
cmake --build cmake-out-android/examples/models/llama -j16 --config Release
You should now have llama_main available for Android.
Note
If you notice that Gradle cannot find the Android SDK, add the sdk.dir path to executorch/extension/android/local.properties.
Run on Android via adb shell
You will need an Arm-powered smartphone with the i8mm feature running Android, with 16GB of RAM. The following steps were tested on a Google Pixel 8 Pro phone.
1. Connect your Android phone
Connect your phone to your computer using a USB cable.
You need to enable USB debugging on your Android device. You can follow Configure on-device developer options to enable USB debugging.
Once you have enabled USB debugging and connected via USB, run:
adb devices
You should see your device listed to confirm it is connected.
2. Copy the model, tokenizer, and Llama runner binary to the phone
adb shell mkdir -p /data/local/tmp/llama
adb push llama3_1B_kv_sdpa_xnn_qe_4_64_1024_embedding_4bit.pte /data/local/tmp/llama/
adb push $HOME/.llama/checkpoints/Llama3.2-1B-Instruct/tokenizer.model /data/local/tmp/llama/
adb push cmake-out-android/examples/models/llama/llama_main /data/local/tmp/llama/
3. Run the model
Use the Llama runner to execute the model on the phone with the adb command:
adb shell "cd /data/local/tmp/llama && ./llama_main --model_path llama3_1B_kv_sdpa_xnn_qe_4_64_1024_embedding_4bit.pte --tokenizer_path tokenizer.model --prompt '<|start_header_id|>system<|end_header_id|>\nYour name is Cookie. you are helpful, polite, precise, concise, honest, good at writing. You always give precise and brief answers up to 32 words<|eot_id|><|start_header_id|>user<|end_header_id|>\nHey Cookie! how are you today?<|eot_id|><|start_header_id|>assistant<|end_header_id|>' --warmup=1 --cpu_threads=5"
The output should look something like this.
I tokenizers:regex.cpp:27] Registering override fallback regex
I 00:00:00.003288 executorch:main.cpp:87] Resetting threadpool with num threads = 5
I 00:00:00.006393 executorch:runner.cpp:44] Creating LLaMa runner: model_path=llama3_1B_kv_sdpa_xnn_qe_4_64_1024_embedding_4bit.pte, tokenizer_path=tokenizer.model
E tokenizers:hf_tokenizer.cpp:60] Error parsing json file: [json.exception.parse_error.101] parse error at line 1, column 1: syntax error while parsing value - invalid literal; last read: 'I'
I 00:00:00.131486 executorch:llm_runner_helper.cpp:57] Loaded TikToken tokenizer
I 00:00:00.131525 executorch:llm_runner_helper.cpp:167] Reading metadata from model
I 00:00:00.186538 executorch:llm_runner_helper.cpp:110] Metadata: use_sdpa_with_kv_cache = 1
I 00:00:00.186574 executorch:llm_runner_helper.cpp:110] Metadata: use_kv_cache = 1
I 00:00:00.186578 executorch:llm_runner_helper.cpp:110] Metadata: get_max_context_len = 1024
I 00:00:00.186584 executorch:llm_runner_helper.cpp:110] Metadata: get_max_seq_len = 1024
I 00:00:00.186588 executorch:llm_runner_helper.cpp:110] Metadata: enable_dynamic_shape = 1
I 00:00:00.186596 executorch:llm_runner_helper.cpp:140] eos_id = 128009
I 00:00:00.186597 executorch:llm_runner_helper.cpp:140] eos_id = 128001
I 00:00:00.186599 executorch:llm_runner_helper.cpp:140] eos_id = 128006
I 00:00:00.186600 executorch:llm_runner_helper.cpp:140] eos_id = 128007
I 00:00:01.086570 executorch:text_llm_runner.cpp:89] Doing a warmup run...
I 00:00:01.087836 executorch:text_llm_runner.cpp:152] Max new tokens resolved: 128, given start_pos 0, num_prompt_tokens 54, max_context_len 1024
I 00:00:01.292740 executorch:text_prefiller.cpp:93] Prefill token result numel(): 128256
I 00:00:02.264371 executorch:text_token_generator.h:123]
Reached to the end of generation
I 00:00:02.264379 executorch:text_llm_runner.cpp:209] Warmup run finished!
I 00:00:02.264384 executorch:text_llm_runner.cpp:95] RSS after loading model: 1122.187500 MiB (0 if unsupported)
I 00:00:02.264624 executorch:text_llm_runner.cpp:152] Max new tokens resolved: 74, given start_pos 0, num_prompt_tokens 54, max_context_len 1024
<|start_header_id|>system<|end_header_id|>\nYour name is Cookie. you are helpful, polite, precise, concise, honest, good at writing. You always give precise and brief answers up to 32 words<|eot_id|><|start_header_id|>user<|end_header_id|>\nHey Cookie! how are you today?<|eot_id|><|start_header_id|>assistant<|end_header_id|>I 00:00:02.394162 executorch:text_prefiller.cpp:93] Prefill token result numel(): 128256
I 00:00:02.394373 executorch:text_llm_runner.cpp:179] RSS after prompt prefill: 1122.187500 MiB (0 if unsupported)
I'm doing great, thanks for asking! I'm always ready to help, whether it's answering a question or providing a solution. What can I help you with today?<|eot_id|>
I 00:00:03.072966 executorch:text_token_generator.h:123]
I 00:00:03.072972 executorch:text_llm_runner.cpp:199] RSS after finishing text generation: 1122.187500 MiB (0 if unsupported)
PyTorchObserver {"prompt_tokens":54,"generated_tokens":36,"model_load_start_ms":1756473387815,"model_load_end_ms":1756473388715,"inference_start_ms":1756473389893,"inference_end_ms":1756473390702,"prompt_eval_end_ms":1756473390023,"first_token_ms":1756473390023,"aggregate_sampling_time_ms":22,"SCALING_FACTOR_UNITS_PER_SECOND":1000}
I 00:00:03.072993 executorch:stats.h:108] 	Prompt Tokens: 54    Generated Tokens: 36
I 00:00:03.072995 executorch:stats.h:114] 	Model Load Time:		0.900000 (seconds)
I 00:00:03.072996 executorch:stats.h:124] 	Total inference time:		0.809000 (seconds)  Rate: 	44.499382 (tokens/second)
I 00:00:03.072998 executorch:stats.h:132] 	Prompt evaluation:	0.130000 (seconds)          Rate: 	415.384615 (tokens/second)
I 00:00:03.073000 executorch:stats.h:143] 	Generated 36 tokens:	0.679000 (seconds)      Rate: 	53.019146 (tokens/second)
I 00:00:03.073002 executorch:stats.h:151] 	Time to first generated token:	0.130000 (seconds)
I 00:00:03.073004 executorch:stats.h:158] 	Sampling time over 90 tokens:	0.022000 (seconds)
You have successfully run the Llama 3.1 1B Instruct model on your Android smartphone with ExecuTorch using KleidiAI kernels.
