Download and export the Llama 3.2 1B model
To get started with Llama 3, you can obtain the pre-trained parameters by visiting Meta’s Llama Downloads page. Request access by filling out your details, and read through and accept the Responsible Use Guide. This grants you a license and a download link which is valid for 24 hours. The Llama 3.2 1B Instruct model is used for this exercise, but the same instructions apply to other options as well with minimal modification.
Install the llama-stack package from pip.
            pip install llama-stack
Run the command to download, and paste the download link from the email when prompted.
            llama model download --source meta --model-id Llama3.2-1B-Instruct
When the download is finished, the installation path is printed as output.
        Successfully downloaded model to /<path-to-home>/.llama/checkpoints/Llama3.2-1B-Instruct
Verify by viewing the downloaded files under this path:
            ls $HOME/.llama/checkpoints/Llama3.2-1B-Instruct
checklist.chk           consolidated.00.pth     params.json             tokenizer.model
Working Directory
The rest of the instructions should be executed from the ExecuTorch base directory.
Export model and generate .pte file. Run the Python command to export the model to your current directory.
            python3 -m examples.models.llama.export_llama \
--checkpoint $HOME/.llama/checkpoints/Llama3.2-1B-Instruct/consolidated.00.pth \
--params $HOME/.llama/checkpoints/Llama3.2-1B-Instruct/params.json \
-kv --use_sdpa_with_kv_cache -X --xnnpack-extended-ops -qmode 8da4w \
--group_size 64 -d fp32 \
--metadata '{"get_bos_id":128000, "get_eos_ids":[128009, 128001, 128006, 128007]}' \
--embedding-quantize 4,32 \
--output_name="llama3_1B_kv_sdpa_xnn_qe_4_64_1024_embedding_4bit.pte" \
--max_seq_length 1024
Due to the larger vocabulary size of Llama 3, you should quantize the embeddings with --embedding-quantize 4,32 to further reduce the model size.
