ExecuTorch is an end-to-end solution for enabling on-device inference capabilities across mobile and edge devices; including wearables, embedded devices, and microcontrollers. It is part of the PyTorch Edge ecosystem and enables efficient deployment of PyTorch models to edge devices. You can learn more by reading the ExecuTorch Overview .
The best practice is to generate an isolated Python environment in which to install your ExecuTorch dependencies. We provide instructions for both a Python virtual environment and a Conda virtual environment, but you only need one.
python3.10 -m venv executorch
source executorch/bin/activate
The prompt of your terminal has executorch
as a prefix to indicate the virtual environment is active.
Install Miniconda on your development machine by following the Installing conda instructions.
Once conda
is installed, create the environment:
conda create -yn executorch python=3.10.0
conda activate executorch
From within the conda environment, run the commands below to download the ExecuTorch repository and install the required packages:
git clone https://github.com/pytorch/executorch.git
cd executorch
git submodule sync
git submodule update --init
./install_requirements.sh
./install_requirements.sh --pybind xnnpack
./examples/models/llama/install_requirements.sh
When these scripts finish successfully, ExecuTorch is set up. That means it’s time to dive into the world of Llama models!
