Now you have two independent Flows indicating the conditions of face landmark detection and gesture recognition.
The simplest multimodality strategy is to combine multiple source Flows into a single output Flow, which emits consolidated values as the single source of truth for its observers, the collectors, to carry out corresponding actions.
Combine two Flows into a single Flow
  1. Navigate to MainViewModel and append the following constant values to its companion object:
    • The first constant defines how frequently you sample the conditions from each Flow.
    • The second constant defines the debounce threshold of the stability check on whether to trigger a photo capture.
                    private const val CONDITION_CHECK_SAMPLING_INTERVAL = 100L
        private const val CONDITION_CHECK_STABILITY_THRESHOLD = 500L
  1. Add a private member variable named _bothOk:
                private val _bothOk =
        combine(
            _gestureOk.sample(CONDITION_CHECK_SAMPLING_INTERVAL),
            _faceOk.sample(CONDITION_CHECK_SAMPLING_INTERVAL),
        ) { gestureOk, faceOk -> gestureOk && faceOk }
            .stateIn(viewModelScope, SharingStarted.WhileSubscribed(), false)
Note
Kotlin Flow’s combine transformation is equivalent to ReactiveX’s combineLatest . It combines emissions from multiple observables, so that each time any observable emits, the combinator function is called with the latest values from all sources.
You might need to add the @OptIn(FlowPreview::class) annotation as sample is still in preview.
  1. Expose a SharedFlow variable which emits a Unit whenever the face and gesture conditions are met and stays stable for a while, which means 500ms as defined above. Again, add @OptIn(FlowPreview::class) if required.
                val captureEvents: SharedFlow<Unit> = _bothOk
        .debounce(CONDITION_CHECK_STABILITY_THRESHOLD)
        .filter { it }
        .map { }
        .shareIn(viewModelScope, SharingStarted.WhileSubscribed())
You can also opt to use SharedFlow<Boolean> and remove the map { } operation. Note that when you collect this Flow, it does not matter whether the emitted Boolean values are true or false. In fact, they are always true due to the filter operation.
Configure the ImageCapture use case
  1. Navigate to MainActivity and append a ImageCapture use case below the other camera-related member variables:
                private var imageCapture: ImageCapture? = null
  1. Configure this ImageCapture in the bindCameraUseCases() method:
                    // Image Capture
        imageCapture = ImageCapture.Builder()
            .setCaptureMode(ImageCapture.CAPTURE_MODE_MINIMIZE_LATENCY)
            .setTargetRotation(targetRotation)
            .build()
  1. Append this use case to bindToLifecycle:
                        camera = cameraProvider.bindToLifecycle(
                this, cameraSelector, preview, imageAnalyzer, imageCapture
Execute photo capture with ImageCapture
  1. Append the following constant values to MainActivity’s companion object. They define the file name format and the media type:
                    // Image capture
        private const val FILENAME = "yyyy-MM-dd-HH-mm-ss-SSS"
        private const val PHOTO_TYPE = "image/jpeg"
  1. Implement the photo capture logic with a new method named executeCapturePhoto():
                private fun executeCapturePhoto() {
        imageCapture?.let { imageCapture ->
            val name = SimpleDateFormat(FILENAME, Locale.US)
                .format(System.currentTimeMillis())
            val contentValues = ContentValues().apply {
                put(MediaStore.MediaColumns.DISPLAY_NAME, name)
                put(MediaStore.MediaColumns.MIME_TYPE, PHOTO_TYPE)
                if (Build.VERSION.SDK_INT > Build.VERSION_CODES.P) {
                    val appName = resources.getString(R.string.app_name)
                    put(
                        MediaStore.Images.Media.RELATIVE_PATH,
                        "Pictures/${appName}"
            val outputOptions = ImageCapture.OutputFileOptions
                .Builder(
                    contentResolver,
                    MediaStore.Images.Media.EXTERNAL_CONTENT_URI,
                    contentValues
                .build()
            imageCapture.takePicture(outputOptions, Dispatchers.IO.asExecutor(),
                object : ImageCapture.OnImageSavedCallback {
                    override fun onError(error: ImageCaptureException) {
                        Log.e(TAG, "Photo capture failed: ${error.message}", error)
                    override fun onImageSaved(outputFileResults: ImageCapture.OutputFileResults) {
                        val savedUri = outputFileResults.savedUri
                        Log.i(TAG, "Photo capture succeeded: $savedUri")
  1. Append the following code to the repeatOnLifecycle(Lifecycle.State.RESUMED) block in the onCreate method:
                            launch {
                    viewModel.captureEvents.collect {
  1. Even though the photo capture has already been implemented, it is still inconvenient to check out the logs afterwards to find out whether the photo capture has been successfully executed, so you can now add a flash effect UI to explicitly show the users that a photo has been captured.
Add a flash effect upon capturing photo
  1. Navigate to the activity_main.xml layout file and insert the following View element between the two overlay views and the two SwitchCompat views. This is essentially just a white blank view covering the whole surface:
                <View
        android:id="@+id/flashOverlay"
        android:layout_width="match_parent"
        android:layout_height="match_parent"
        android:background="@android:color/white"
        android:visibility="gone" />
  1. Append the constant value below to the companion object of MainActivity, then add a private method named showFlashEffect() to animate the above flashOverlay view from hidden to shown in 100ms and then again from shown to hidden in 100ms.
                private const val IMAGE_CAPTURE_FLASH_DURATION = 100L
                private fun showFlashEffect() {
        viewBinding.flashOverlay.apply {
            visibility = View.VISIBLE
            alpha = 0f
            // Fade in and out animation
            animate()
                .alpha(1f)
                .setDuration(IMAGE_CAPTURE_FLASH_DURATION)
                .withEndAction {
                    animate()
                        .alpha(0f)
                        .withEndAction {
                            visibility = View.GONE
  1. Invoke the showFlashEffect() method in the executeCapturePhoto() method, before invoking imageCapture.takePicture().
  2. Build and run the app:
    • Try to maintain a smiling face whilst also presenting thumb-up gestures.
    • When you see both switches, turn on and stay stable for approximately half a second.
    • The screen should flash white and then a photo should be captured. This will show up in your album, which might take a few seconds depending on your Android device’s hardware. Good job!
