SharedFlow and StateFlow are Kotlin Flow APIs that enable Flows to optimally emit state updates and emit values to multiple consumers.
In this Learning Path, you will experiment with both SharedFlow
and StateFlow
. This section focuses on SharedFlow, and the next section focuses on StateFlow.
SharedFlow
is a general-purpose, hot flow that can emit values to multiple subscribers. It is highly configurable, allowing you to configure settings such as the replay cache size and buffer capacity.
MainViewModel
and define a
sealed class
named UiEvent
, with two
direct subclasses
named Face
and Gesture
sealed class UiEvent {
data class Face(
val face: FaceResultBundle
) : UiEvent()
data class Gesture(
val gestures: GestureResultBundle,
) : UiEvent()
SharedFlow
named uiEvents
private val _uiEvents = MutableSharedFlow<UiEvent>(1)
val uiEvents: SharedFlow<UiEvent> = _uiEvents
This SharedFlow
is initialized with a replay size of 1
. This retains the most recent value and ensures that new subscribers don’t miss the latest event.
override fun onFaceLandmarkerResults(resultBundle: FaceResultBundle) {
_uiEvents.tryEmit(UiEvent.Face(resultBundle))
override fun onGestureResults(resultBundle: GestureResultBundle) {
_uiEvents.tryEmit(UiEvent.Gesture(resultBundle))
To visualize the results of Face Landmark Detection and Gesture Recognition tasks, based on MediaPipe’s samples follow the instructions in this section.
FaceLandmarkerOverlayView.kt
and copy the content below:
* Copyright 2023 The TensorFlow Authors. All Rights Reserved.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
package com.example.holisticselfiedemo
import android.content.Context
import android.graphics.Canvas
import android.graphics.Color
import android.graphics.Paint
import android.util.AttributeSet
import android.view.View
import com.google.mediapipe.tasks.vision.core.RunningMode
import com.google.mediapipe.tasks.vision.facelandmarker.FaceLandmarker
import com.google.mediapipe.tasks.vision.facelandmarker.FaceLandmarkerResult
import kotlin.math.max
import kotlin.math.min
class FaceLandmarkerOverlayView(context: Context?, attrs: AttributeSet?) :
View(context, attrs) {
private var results: FaceLandmarkerResult? = null
private var linePaint = Paint()
private var pointPaint = Paint()
private var scaleFactor: Float = 1f
private var imageWidth: Int = 1
private var imageHeight: Int = 1
init {
initPaints()
fun clear() {
results = null
linePaint.reset()
pointPaint.reset()
invalidate()
initPaints()
private fun initPaints() {
linePaint.color = Color.BLUE
linePaint.strokeWidth = LANDMARK_STROKE_WIDTH
linePaint.style = Paint.Style.STROKE
pointPaint.color = Color.YELLOW
pointPaint.strokeWidth = LANDMARK_STROKE_WIDTH
pointPaint.style = Paint.Style.FILL
override fun draw(canvas: Canvas) {
super.draw(canvas)
if (results == null || results!!.faceLandmarks().isEmpty()) {
clear()
return
results?.let { faceLandmarkerResult ->
for(landmark in faceLandmarkerResult.faceLandmarks()) {
for(normalizedLandmark in landmark) {
canvas.drawPoint(normalizedLandmark.x() * imageWidth * scaleFactor, normalizedLandmark.y() * imageHeight * scaleFactor, pointPaint)
FaceLandmarker.FACE_LANDMARKS_CONNECTORS.forEach {
canvas.drawLine(
landmark[it.start()].x() * imageWidth * scaleFactor,
landmark[it.start()].y() * imageHeight * scaleFactor,
landmark[it.end()].x() * imageWidth * scaleFactor,
landmark[it.end()].y() * imageHeight * scaleFactor,
linePaint)
fun setResults(
faceLandmarkerResults: FaceLandmarkerResult,
imageHeight: Int,
imageWidth: Int,
runningMode: RunningMode = RunningMode.IMAGE
results = faceLandmarkerResults
this.imageHeight = imageHeight
this.imageWidth = imageWidth
scaleFactor = when (runningMode) {
RunningMode.IMAGE,
RunningMode.VIDEO -> {
min(width * 1f / imageWidth, height * 1f / imageHeight)
RunningMode.LIVE_STREAM -> {
// PreviewView is in FILL_START mode. So we need to scale up the
// landmarks to match with the size that the captured images will be
// displayed.
max(width * 1f / imageWidth, height * 1f / imageHeight)
invalidate()
companion object {
private const val LANDMARK_STROKE_WIDTH = 8F
GestureOverlayView.kt
and copy in the text below:
* Copyright 2022 The TensorFlow Authors. All Rights Reserved.
import com.google.mediapipe.tasks.vision.gesturerecognizer.GestureRecognizerResult
import com.google.mediapipe.tasks.vision.handlandmarker.HandLandmarker
class GestureOverlayView(context: Context?, attrs: AttributeSet?) :
private var results: GestureRecognizerResult? = null
init {
initPaints()
fun clear() {
results = null
linePaint.reset()
pointPaint.reset()
invalidate()
initPaints()
super.draw(canvas)
results?.let { gestureRecognizerResult ->
for (landmark in gestureRecognizerResult.landmarks()) {
for (normalizedLandmark in landmark) {
canvas.drawPoint(
pointPaint)
HandLandmarker.HAND_CONNECTIONS.forEach {
canvas.drawLine(
linePaint)
fun setResults(
gestureRecognizerResult: GestureRecognizerResult,
imageHeight: Int,
imageWidth: Int,
results = gestureRecognizerResult
RunningMode.IMAGE,
// displayed.
invalidate()
companion object {
activity_main.xml
layout file:
<com.example.holisticselfiedemo.FaceLandmarkerOverlayView
android:id="@+id/overlay_face"
android:layout_width="match_parent"
android:layout_height="match_parent" />
<com.example.holisticselfiedemo.GestureOverlayView
android:id="@+id/overlay_gesture"
uiEvents
in MainActivity
by appending the code below to the end of onCreate
method, below setupCamera()
method call.
lifecycleScope.launch {
repeatOnLifecycle(Lifecycle.State.RESUMED) {
launch {
viewModel.uiEvents.collect { uiEvent ->
when (uiEvent) {
is MainViewModel.UiEvent.Face -> drawFaces(uiEvent.face)
is MainViewModel.UiEvent.Gesture -> drawGestures(uiEvent.gestures)
drawFaces
and drawGestures
private fun drawFaces(resultBundle: FaceResultBundle) {
// Pass necessary information to OverlayView for drawing on the canvas
viewBinding.overlayFace.setResults(
resultBundle.result,
resultBundle.inputImageHeight,
resultBundle.inputImageWidth,
// Force a redraw
viewBinding.overlayFace.invalidate()
private fun drawGestures(resultBundle: GestureResultBundle) {
viewBinding.overlayGesture.setResults(
resultBundle.results.first(),
// Force a redraw
viewBinding.overlayGesture.invalidate()
