# Manage UI state with ViewModel
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/)
- [Set up the Development Environment](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/2-app-scaffolding/)
- [Manage Camera Permissions](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/3-camera-permission/)
- [Integrate MediaPipe solutions](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/4-introduce-mediapipe/)
- [Manage UI state with ViewModel](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/5-view-model-setup/)
- [Use SharedFlow to View Events](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/6-flow-data-to-view-1/)
- [Use StateFlow to View Controller States](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/7-flow-data-to-view-2/)
- [Mediate flows to trigger photo capture](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/8-mediate-flows/)
- [Avoid duplicate photo capture requests](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/9-avoid-redundant-requests/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/_next-steps/)
## ViewModel
The `ViewModel` class is a business logic or screen level state holder, as explained in [ViewModel overview](https://developer.android.com/topic/architecture/ui-layer/stateholders) on the Android Developer website. It exposes state to the UI and encapsulates related business logic.
The main advantage of using the `ViewModel` class is that it caches state and persists it through configuration changes. This means that the UI does not have to fetch data again when navigating between activities, or following configuration changes, such as screen rotation.
## Add Android Jetpack Lifecycle libraries
You can now add Jetpack Lifecycle libraries to your app.
1. Navigate to `libs.versions.toml` and append the following line to the end of the `[versions]` section. This defines the version of the Jetpack Lifecycle libraries that you will be using.
   ```toml
   lifecycle = "2.8.7"
2. Insert the following line to the `[libraries]` section, ideally between `androidx-appcompat` and `material`. This declares the Jetpack Lifecycle ViewModel Kotlin extension:
   ```toml
   androidx-lifecycle-viewmodel = { group="androidx.lifecycle", name="lifecycle-viewmodel-ktx", version.ref="lifecycle" }
3. Navigate to `build.gradle.kts` in your project’s `app` directory, then insert the following line into the `dependencies` block, ideally between `implementation(libs.androidx.constraintlayout)` and `implementation(libs.camera.core)`:
   ```kotlin
   implementation(libs.androidx.lifecycle.viewmodel)
## Access the helper through a ViewModel
1. Create a new file named `MainViewModel.kt` and place it into the same directory of `MainActivity.kt`. Now copy and paste the code below into it:
   ```kotlin
   package com.example.holisticselfiedemo
   import android.app.Application
   import android.util.Log
   import androidx.lifecycle.ViewModel
   import androidx.lifecycle.viewModelScope
   import kotlinx.coroutines.launch
   class MainViewModel : ViewModel(), HolisticRecognizerHelper.Listener {
       private val holisticRecognizerHelper = HolisticRecognizerHelper()
       fun setupHelper(context: Context) {
           viewModelScope.launch {
               holisticRecognizerHelper.apply {
                   listener = this@MainViewModel
                   setup(context)
       fun shutdownHelper() {
                   listener = null
                   shutdown()
       fun recognizeLiveStream(imageProxy: ImageProxy) {
           holisticRecognizerHelper.recognizeLiveStream(
               imageProxy = imageProxy,
       override fun onFaceLandmarkerResults(resultBundle: FaceResultBundle) {
           Log.i(TAG, "Face result: $resultBundle")
       override fun onFaceLandmarkerError(error: String, errorCode: Int) {
           Log.e(TAG, "Face landmarker error $errorCode: $error")
       override fun onGestureResults(resultBundle: GestureResultBundle) {
           Log.i(TAG, "Gesture result: $resultBundle")
       override fun onGestureError(error: String, errorCode: Int) {
           Log.e(TAG, "Gesture recognizer error $errorCode: $error")
       companion object {
           private const val TAG = "MainViewModel"
   You might notice that success and failure messages are logged with different APIs. For more information on log level guidelines, see [Understanding Logging: Log Level Guidelines](https://source.android.com/docs/core/tests/debug/understanding-logging#log-level-guidelines).
2. Bind `MainViewModel` to `MainActivity` by inserting the following line into `MainActivity.kt`, above the `onCreate` method. Do not forget to import the `viewModels` [extension function](https://kotlinlang.org/docs/extensions.html#extension-functions) through `import androidx.activity.viewModels`.
   ```kotlin
   private val viewModel: MainViewModel by viewModels()
3. Setup and shutdown the helper’s internal MediaPipe tasks on the app becomes [active and inactive](https://developer.android.com/guide/components/activities/activity-lifecycle#alc).
   ```kotlin
   private var isHelperReady = false
   override fun onResume() {
       super.onResume()
       viewModel.setupHelper(baseContext)
       isHelperReady = true
   override fun onPause() {
       super.onPause()
       viewModel.shutdownHelper()
## Feed camera frames into livestream recognition
1. Add a new member variable named `imageAnalysis` to `MainActivity`, along with other camera-related member variables:
   ```kotlin
   private var imageAnalysis: ImageAnalysis? = null
2. In `MainActivity`’s `bindCameraUseCases()` method, insert the following code after building `preview`, above `cameraProvider.unbindAll()`:
   ```kotlin
   // ImageAnalysis. Using RGBA 8888 to match how MediaPipe models work
   imageAnalysis =
       ImageAnalysis.Builder()
           .setResolutionSelector(resolutionSelector)
           .setTargetRotation(targetRotation)
           .setBackpressureStrategy(ImageAnalysis.STRATEGY_KEEP_ONLY_LATEST)
           .setOutputImageFormat(ImageAnalysis.OUTPUT_IMAGE_FORMAT_RGBA_8888)
           .build()
           // The analyzer can then be assigned to the instance
           .also {
               it.setAnalyzer(
                   // Forcing a serial executor without parallelism
                   // to avoid packets sent to MediaPipe out-of-order
                   Dispatchers.Default.limitedParallelism(1).asExecutor()
               ) { image ->
                   if (isHelperReady)
                       viewModel.recognizeLiveStream(image)
   The `isHelperReady` flag is a lightweight mechanism to prevent camera image frames being sent to helper once you have started shutting down the helper.
3. Append `imageAnalysis` along with other use cases to `camera`:
   ```kotlin
   camera = cameraProvider.bindToLifecycle(
       this, cameraSelector, preview, imageAnalysis
4. Build and run the app again. Now you should see `Face result: ...` and `Gesture result: ...` debug messages in your [Logcat](https://developer.android.com/tools/logcat), which prove that MediaPipe tasks are functioning properly. Good job!
