# Integrate MediaPipe solutions
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/)
- [Set up the Development Environment](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/2-app-scaffolding/)
- [Manage Camera Permissions](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/3-camera-permission/)
- [Integrate MediaPipe solutions](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/4-introduce-mediapipe/)
- [Manage UI state with ViewModel](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/5-view-model-setup/)
- [Use SharedFlow to View Events](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/6-flow-data-to-view-1/)
- [Use StateFlow to View Controller States](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/7-flow-data-to-view-2/)
- [Mediate flows to trigger photo capture](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/8-mediate-flows/)
- [Avoid duplicate photo capture requests](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/9-avoid-redundant-requests/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/_next-steps/)
MediaPipe Solutions provides a suite of libraries and tools for you to quickly apply Artificial Intelligence (AI) and Machine Learning (ML) techniques in your applications.
MediaPipe Tasks provides the core programming interface of the MediaPipe Solutions suite, including a set of libraries for deploying innovative ML solutions onto devices with minimal coding effort. It supports multiple platforms, including Android, Web, JavaScript, and Python.
## Add MediaPipe dependencies
1. Navigate to `libs.versions.toml` and append the following line to the end of the `[versions]` section.
   This defines the version of MediaPipe library that you will be using:
   ```kotlin
   mediapipe-vision = "0.10.15"
   > **Note**
   Ensure that you use this particular version, and not later versions as they might produce unexpected behavior.
2. Append the following lines to the end of the `[libraries]` section. This declares MediaPipe’s vision dependency:
   ```kotlin
   mediapipe-vision = { group="com.google.mediapipe", name="tasks-vision", version.ref="mediapipe-vision" }
3. Navigate to `build.gradle.kts` in your project’s `app` directory, then insert the following line into the `dependencies` block, between `implementation` and `testImplementation`:
   ```kotlin
   implementation(libs.mediapipe.vision)
## Prepare model asset bundles
In this app, you will use MediaPipe’s [Face Landmark Detection](https://ai.google.dev/edge/mediapipe/solutions/vision/face_landmarker) and [Gesture Recognizer](https://ai.google.dev/edge/mediapipe/solutions/vision/gesture_recognizer) solutions, which require their model asset bundle files to initialize.
Choose one of the two options below that aligns best with your learning needs.
### 1. Basic approach: manual download
Download the following two files, then move them into the default asset directory `app/src/main/assets`:
https://storage.googleapis.com/mediapipe-models/face_landmarker/face_landmarker/float16/1/face_landmarker.task
https://storage.googleapis.com/mediapipe-models/gesture_recognizer/gesture_recognizer/float16/1/gesture_recognizer.task
> **Tip**
You might need to create an `assets` directory if you do not have one already.
### 2. Advanced approach: configure prebuild download tasks
As Gradle does not come with a convenient [Task](https://docs.gradle.org/current/userguide/tutorial_using_tasks.html) type to manage downloads, you will need to use the [gradle-download-task](https://github.com/michel-kraemer/gradle-download-task) dependency.
1. Navigate to `libs.versions.toml`. Then:
   - Append `download = "5.6.0"` to the `[versions]` section, and append `de-undercouch-download = { id = "de.undercouch.download", version.ref = "download" } to [plugins]` section.
2. Navigate to `build.gradle.kts` in your project’s `app` directory. Then:
   - Append `alias(libs.plugins.de.undercouch.download)` to the `plugins` block. This enables the *Download* task plugin in this `app` subproject.
3. Insert the following lines between the `plugins` block and the `android` block to define the constant values, including the asset directory path and the URLs for both models:
   ```kotlin
   val assetDir = "$projectDir/src/main/assets"
   val gestureTaskUrl = "https://storage.googleapis.com/mediapipe-models/gesture_recognizer/gesture_recognizer/float16/1/gesture_recognizer.task"
   val faceTaskUrl = "https://storage.googleapis.com/mediapipe-models/face_landmarker/face_landmarker/float16/1/face_landmarker.task"
4. Insert `import de.undercouch.gradle.tasks.download.Download` to the top of this file, then append the following code to the end of this file, which hooks two *Download* tasks to be executed before `preBuild`:
   ```kotlin
   tasks.register<Download>("downloadGestureTaskAsset") {
       src(gestureTaskUrl)
       dest("$assetDir/gesture_recognizer.task")
       overwrite(false)
   tasks.register<Download>("downloadFaceTaskAsset") {
       src(faceTaskUrl)
       dest("$assetDir/face_landmarker.task")
       overwrite(false)
   tasks.named("preBuild") {
       dependsOn("downloadGestureTaskAsset", "downloadFaceTaskAsset")
## Encapsulate MediaPipe vision tasks in a helper
1. Sync the project again.
   > **Tip**
   See the previous section [Set up the Development Environment](../2-app-scaffolding#enable-view-binding), as a reminder on how to do this.
2. Now you should see both model asset bundles in your `assets` directory, as shown below:
   ![Image Alt Text:model asset bundles](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/build-android-selfie-app-using-mediapipe-multimodality/images/4/model_asset_bundles.png)
3. You are ready to import MediaPipe’s Face Landmark Detection and Gesture Recognizer into the project. Example code is already implemented for ease of use based on [MediaPipe’s sample code](https://github.com/google-ai-edge/mediapipe-samples/tree/main/examples).
   Simply create a new file called `HolisticRecognizerHelper.kt`, and place it in the source directory along with `MainActivity.kt`, then copy-and-paste the code below into it:
   ```kotlin
   package com.example.holisticselfiedemo
    * Copyright 2022 The TensorFlow Authors. All Rights Reserved.
    * Licensed under the Apache License, Version 2.0 (the "License");
    * you may not use this file except in compliance with the License.
    * You may obtain a copy of the License at
    *             http://www.apache.org/licenses/LICENSE-2.0
    * Unless required by applicable law or agreed to in writing, software
    * distributed under the License is distributed on an "AS IS" BASIS,
    * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
    * See the License for the specific language governing permissions and
    * limitations under the License.
   import android.content.Context
   import android.graphics.Bitmap
   import android.graphics.Matrix
   import android.os.SystemClock
   import android.util.Log
   import androidx.annotation.VisibleForTesting
   import androidx.camera.core.ImageProxy
   import com.google.mediapipe.framework.image.BitmapImageBuilder
   import com.google.mediapipe.framework.image.MPImage
   import com.google.mediapipe.tasks.core.BaseOptions
   import com.google.mediapipe.tasks.core.Delegate
   import com.google.mediapipe.tasks.vision.core.RunningMode
   import com.google.mediapipe.tasks.vision.facelandmarker.FaceLandmarker
   import com.google.mediapipe.tasks.vision.facelandmarker.FaceLandmarkerResult
   import com.google.mediapipe.tasks.vision.gesturerecognizer.GestureRecognizer
   import com.google.mediapipe.tasks.vision.gesturerecognizer.GestureRecognizerResult
   class HolisticRecognizerHelper(
       private var currentDelegate: Int = DELEGATE_GPU,
       private var runningMode: RunningMode = RunningMode.LIVE_STREAM
       var listener: Listener? = null
       private var faceLandmarker: FaceLandmarker? = null
       private var gestureRecognizer: GestureRecognizer? = null
       fun setup(context: Context) {
           setupFaceLandmarker(context)
           setupGestureRecognizer(context)
       fun shutdown() {
           faceLandmarker?.close()
           faceLandmarker = null
           gestureRecognizer?.close()
           gestureRecognizer = null
       // Return running status of the recognizer helper
       val isClosed: Boolean
           get() = gestureRecognizer == null && faceLandmarker == null
       // Initialize the Face landmarker using current settings on the
       // thread that is using it. CPU can be used with Landmarker
       // that are created on the main thread and used on a background thread, but
       // the GPU delegate needs to be used on the thread that initialized the Landmarker
       private fun setupFaceLandmarker(context: Context) {
           // Set general face landmarker options
           val baseOptionBuilder = BaseOptions.builder()
           // Use the specified hardware for running the model. Default to CPU
           when (currentDelegate) {
               DELEGATE_CPU -> {
                   baseOptionBuilder.setDelegate(Delegate.CPU)
               DELEGATE_GPU -> {
                   baseOptionBuilder.setDelegate(Delegate.GPU)
           baseOptionBuilder.setModelAssetPath(MP_FACE_LANDMARKER_TASK)
           try {
               val baseOptions = baseOptionBuilder.build()
               // Create an option builder with base options and specific
               // options only use for Face Landmarker.
               val optionsBuilder = FaceLandmarker.FaceLandmarkerOptions.builder()
                   .setBaseOptions(baseOptions)
                   .setMinFaceDetectionConfidence(DEFAULT_FACE_DETECTION_CONFIDENCE)
                   .setMinTrackingConfidence(DEFAULT_FACE_TRACKING_CONFIDENCE)
                   .setMinFacePresenceConfidence(DEFAULT_FACE_PRESENCE_CONFIDENCE)
                   .setNumFaces(FACES_COUNT)
                   .setOutputFaceBlendshapes(true)
                   .setRunningMode(runningMode)
               // The ResultListener and ErrorListener only use for LIVE_STREAM mode.
               if (runningMode == RunningMode.LIVE_STREAM) {
                   optionsBuilder
                       .setResultListener(this::returnFaceLivestreamResult)
                       .setErrorListener(this::returnLivestreamError)
               val options = optionsBuilder.build()
               faceLandmarker =
                   FaceLandmarker.createFromOptions(context, options)
           } catch (e: IllegalStateException) {
               listener?.onFaceLandmarkerError(
                   "Face Landmarker failed to initialize. See error logs for details"
               Log.e(
                   TAG,
                   "MediaPipe failed to load the task with error: " + e.message
           } catch (e: RuntimeException) {
               // This occurs if the model being used does not support GPU
                   "Face Landmarker failed to initialize. See error logs for details",
                   GPU_ERROR
               Log.e(
                   TAG,
                   "Face Landmarker failed to load model with error: " + e.message
       // Initialize the gesture recognizer using current settings on the
       // thread that is using it. CPU can be used with recognizers
       // the GPU delegate needs to be used on the thread that initialized the recognizer
       private fun setupGestureRecognizer(context: Context) {
           // Set general recognition options, including number of used threads
               DELEGATE_CPU -> {
               DELEGATE_GPU -> {
           baseOptionBuilder.setModelAssetPath(MP_RECOGNIZER_TASK)
           try {
               val optionsBuilder = GestureRecognizer.GestureRecognizerOptions.builder()
                   .setMinHandDetectionConfidence(DEFAULT_HAND_DETECTION_CONFIDENCE)
                   .setMinTrackingConfidence(DEFAULT_HAND_TRACKING_CONFIDENCE)
                   .setMinHandPresenceConfidence(DEFAULT_HAND_PRESENCE_CONFIDENCE)
                   .setNumHands(HANDS_COUNT)
                   optionsBuilder
                       .setResultListener(this::returnGestureLivestreamResult)
               gestureRecognizer =
                   GestureRecognizer.createFromOptions(context, options)
               listener?.onGestureError(
                   "Gesture recognizer failed to initialize. See error logs for details"
               Log.e(
                   TAG,
                   "MP Task Vision failed to load the task with error: " + e.message
                   "Gesture recognizer failed to initialize. See error logs for details",
                   GPU_ERROR
               Log.e(
                   TAG,
       // Convert the ImageProxy to MP Image and feed it to GestureRecognizer and FaceLandmarker.
       fun recognizeLiveStream(
           imageProxy: ImageProxy,
           val frameTime = SystemClock.uptimeMillis()
           // Copy out RGB bits from the frame to a bitmap buffer
           val bitmapBuffer = Bitmap.createBitmap(
               imageProxy.width, imageProxy.height, Bitmap.Config.ARGB_8888
           imageProxy.use { bitmapBuffer.copyPixelsFromBuffer(imageProxy.planes[0].buffer) }
           imageProxy.close()
           val matrix = Matrix().apply {
               // Rotate the frame received from the camera to be in the same direction as it'll be shown
               postRotate(imageProxy.imageInfo.rotationDegrees.toFloat())
               // flip image since we only support front camera
               postScale(-1f, 1f, imageProxy.width.toFloat(), imageProxy.height.toFloat())
           // Rotate bitmap to match what our model expects
           val rotatedBitmap = Bitmap.createBitmap(
               bitmapBuffer,
               0,
               0,
               bitmapBuffer.width,
               bitmapBuffer.height,
               matrix,
               true
           // Convert the input Bitmap object to an MPImage object to run inference
           val mpImage = BitmapImageBuilder(rotatedBitmap).build()
           recognizeAsync(mpImage, frameTime)
       // Run hand gesture recognition and face landmarker using MediaPipe Gesture Recognition API
       @VisibleForTesting
       fun recognizeAsync(
           mpImage: MPImage,
           frameTime: Long
           // As we're using running mode LIVE_STREAM, the recognition result will
           // be returned in returnLivestreamResult function
           faceLandmarker?.detectAsync(mpImage, frameTime)
           gestureRecognizer?.recognizeAsync(mpImage, frameTime)
       // Return the landmark result to this helper's caller
       private fun returnFaceLivestreamResult(
           result: FaceLandmarkerResult,
           input: MPImage
           val finishTimeMs = SystemClock.uptimeMillis()
           val inferenceTime = finishTimeMs - result.timestampMs()
           listener?.onFaceLandmarkerResults(
               FaceResultBundle(
                   result,
                   inferenceTime,
                   input.height,
                   input.width
       // Return the recognition result to the helper's caller
       private fun returnGestureLivestreamResult(
           result: GestureRecognizerResult,
           input: MPImage
           listener?.onGestureResults(
               GestureResultBundle(
                   listOf(result), inferenceTime, input.height, input.width
       // Return errors thrown during recognition to this Helper's caller
       private fun returnLivestreamError(
           error: RuntimeException
               error.message ?: "An unknown error has occurred"
       companion object {
           const val TAG = "HolisticRecognizerHelper ${this.hashCode()}"
           const val DELEGATE_CPU = 0
           const val DELEGATE_GPU = 1
           private const val MP_FACE_LANDMARKER_TASK = "face_landmarker.task"
           const val FACES_COUNT = 2
           const val DEFAULT_FACE_DETECTION_CONFIDENCE = 0.5F
           const val DEFAULT_FACE_TRACKING_CONFIDENCE = 0.5F
           const val DEFAULT_FACE_PRESENCE_CONFIDENCE = 0.5F
           private const val MP_RECOGNIZER_TASK = "gesture_recognizer.task"
           const val HANDS_COUNT = FACES_COUNT * 2
           const val DEFAULT_HAND_DETECTION_CONFIDENCE = 0.5F
           const val DEFAULT_HAND_TRACKING_CONFIDENCE = 0.5F
           const val DEFAULT_HAND_PRESENCE_CONFIDENCE = 0.5F
           const val OTHER_ERROR = 0
           const val GPU_ERROR = 1
       interface Listener {
           fun onFaceLandmarkerResults(resultBundle: FaceResultBundle)
           fun onFaceLandmarkerError(error: String, errorCode: Int = OTHER_ERROR)
           fun onGestureResults(resultBundle: GestureResultBundle)
           fun onGestureError(error: String, errorCode: Int = OTHER_ERROR)
   data class FaceResultBundle(
       val result: FaceLandmarkerResult,
       val inferenceTime: Long,
       val inputImageHeight: Int,
       val inputImageWidth: Int,
   data class GestureResultBundle(
       val results: List<GestureRecognizerResult>,
   > **Info**
   The scope of this Learning Path is limited to the recognition of one person with two hands in the camera using the MediaPipe vision solutions.
   If you would like to experiment with a greater number of people, change the `FACES_COUNT` constant to a higher value.
In the next section, you will connect the dots from this helper class to the UI layer through a ViewModel.
