Build an Android chat app
Another way to run the model is to use an Android GUI app. You can use the Android demo application included in the onnxruntime-inference-examples repository to demonstrate local inference.
Clone the repo
            git clone https://github.com/microsoft/onnxruntime-inference-examples
cd onnxruntime-inference-examples
git checkout 009920df0136d7dfa53944d06af01002fb63e2f5
Note
You could probably use a later commit but these steps have been tested with the commit 009920df0136d7dfa53944d06af01002fb63e2f5.
Build the app using Android Studio
Open the mobile\examples\phi-3\android directory with Android Studio.
(Optional) In case you want to use the ONNX Runtime AAR you built
Copy ONNX Runtime AAR you built earlier in this learning path:
            Copy onnxruntime\build\Windows\Release\java\build\android\outputs\aar\onnxruntime-release.aar mobile\examples\phi-3\android\app\libs
Update build.gradle.kts (:app) as below:
            // ONNX Runtime with GenAI
//implementation("com.microsoft.onnxruntime:onnxruntime-android:latest.release")
implementation(files("libs/onnxruntime-release.aar"))
Finally, click File > Sync Project with Gradle
Build and run the app
When you select Run, the build will be executed, and then the app will be copied and installed on the Android device. This app will automatically download the Phi-3-mini model during the first run. After the download, you can input the prompt in the text box and execute it to run the model.
You should now see a running app on your phone, which looks like this:
Image Alt Text:App screenshot
