You can now prepare and run a Phi-3-mini model on your Android smartphone, and view performance metrics:
First, cross-compile the model runner to run on Android using the commands below:
cd onnxruntime-genai
copy src\ort_genai.h examples\c\include\
copy src\ort_genai_c.h examples\c\include\
cd examples\c
Run the cmake command as shown:
cmake -G "Ninja" -S . -B build -DMODEL_QA=ON -DCMAKE_TOOLCHAIN_FILE=C:\Users\$env:USERNAME\AppData\Local\Android\Sdk\ndk\27.3.13750724\build\cmake\android.toolchain.cmake -DANDROID_ABI=arm64-v8a -DANDROID_PLATFORM=android-27 -DCMAKE_BUILD_TYPE=Release -DCMAKE_EXE_LINKER_FLAGS="-L../lib"
cmake --build build --parallel --config Release
cd build
After successful build, a binary program called model_qa will be created.
Phi-3 ONNX models are hosted on HuggingFace. You can download the Phi-3-mini model by using the huggingface-cli command:
pip install huggingface-hub[cli]
huggingface-cli download microsoft/Phi-3-mini-4k-instruct-onnx --include cpu_and_mobile/cpu-int4-rtn-block-32-acc-level-4/* --local-dir .
This command downloads the model into a folder called cpu_and_mobile.
The Phi-3-mini (3B) model has a short (4k) context version and a long (128k) context version. The long context version can accept much longer prompts and produce longer output text, but it does consume more memory. In this learning path, you will use the short context version, which is quantized to 4-bits.
Connect your phone to your computer using a USB cable.
You need to enable USB debugging on your Android device. You can follow Configure on-device developer options to do this.
Once you have enabled USB debugging and connected via USB, run:
adb devices
You should see your device listed to confirm it is connected.
adb push cpu-int4-rtn-block-32-acc-level-4 /data/local/tmp
adb push .\model_qa /data/local/tmp
adb push onnxruntime-genai\build\Android\Release\libonnxruntime-genai.so /data/local/tmp
adb push onnxruntime\build\Windows\Release\libonnxruntime.so /data/local/tmp
Use the runner to execute the model on the phone with the adb command:
adb shell
cd /data/local/tmp
chmod 777 model_qa
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/data/local/tmp
./model_qa cpu-int4-rtn-block-32-acc-level-4
This will allow the runner program to load the model. It will then prompt you to input the text prompt to the model. After you enter your input prompt, the text output by the model will be displayed. On completion, performance metrics similar to those shown below should be displayed:
Prompt length: 64, New tokens: 931, Time to first: 1.79s, Prompt tokens per second: 35.74 tps, New tokens per second: 6.34 tps
You have successfully run the Phi-3 model on your Android smartphone powered by Arm.
