Cross-compile the ONNX Runtime Generate() API for Android CPU
The Generate() API in ONNX Runtime is designed for text generation tasks using models like Phi-3. It implements the generative AI loop for ONNX models, including:
  • pre- and post-processing
  • inference with ONNX Runtime
  • logits processing
  • search and sampling
  • KV cache management. You can learn more by reading the ONNX Runtime generate() API page .
Clone onnxruntime-genai repo
Within your Windows PowerShell prompt, checkout the source repo:
            C:\Users\$env:USERNAME
git clone https://github.com/microsoft/onnxruntime-genai
cd onnxruntime-genai
git checkout 1e4d289502a61265c3b07efb17d8796225bb0b7f
Note
You might be able to use later commits. These steps have been tested with the commit 1e4d289502a61265c3b07efb17d8796225bb0b7f.
Build for Android CPU
Ninja generator is used to build on Windows for Android. Make sure you have set JAVA_HOME before running the following command:
            python -m pip install requests
python3.11 build.py --build_java --android --android_home C:\Users\$env:USERNAME\AppData\Local\Android\Sdk --android_ndk_path C:\Users\$env:USERNAME\AppData\Local\Android\Sdk\ndk\27.0.12077973 --android_abi arm64-v8a --config Release
When the build is complete, confirm the shared library has been created:
        ls build\Android\Release\onnxruntime-genai.so
