Give feedback
AI-assisted
Close
Which Android Studio template should I choose to start the project?
Use the Game Activity (C++) template when creating the new project. This template sets up the native C++ scaffolding used by the WebGPU renderer.
Which Android SDK Platform should I install before building?
Install Android 14.0 (“UpsideDownCake”) from the SDK Platforms tab.
After integrating Dawn, which default C++ files should I remove and which new files should be present?
Delete all files from the top cpp directory except CMakeLists.txt. Add webgpuRenderer.cpp, webgpuRenderer.h, and the provided main.cpp for the WebGPU application.
How do I get the WebGPU command queue in code?
Retrieve the device’s single queue with wgpuDeviceGetQueue(), then submit work using methods such as wgpuQueueSubmit.
When should I start profiling with Streamline, and what indicates I’m ready?
Start a Streamline capture after the app builds and renders the simple 3D object on your Android device. When you see the object render without runtime errors, you’re ready to profile and analyze the data.
Return to Mobile, Graphics, and Gaming
