# Build and run a WebGPU application
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/android_webgpu_dawn/)
- [Overview of WebGPU](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/android_webgpu_dawn/1-webgpu-fundamentals/)
- [Set up a development environment](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/android_webgpu_dawn/2-env-setup/)
- [Create an application with Dawn](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/android_webgpu_dawn/3-integrate-dawn/)
- [Using Dawn WebGPU APIs in the application](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/android_webgpu_dawn/4-using-webgpu-apis/)
- [Render a simple 3D object](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/android_webgpu_dawn/5-render-a-simple-3d-object-part-1/)
- [Build and run a WebGPU application](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/android_webgpu_dawn/6-render-a-simple-3d-object-part-2/)
- [Profiling the Application using Streamline](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/android_webgpu_dawn/7-profiling-app-using-streamline/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/android_webgpu_dawn/_next-steps/)
## 3D meshes
Once a Render Pipeline is created, you can use WebGPU APIs to create and render a 3D mesh. This is similar to other graphics APIs.
The steps are listed below:
- Create the Vertex Buffer(s).
- Create the Index Buffer(s).
- Create the Uniform Buffer(s).
- Create a Depth Buffer (Z-Buffer algorithm).
- Create the Depth Texture and TextureView.
- Create a Depth Stencil.
- Create the Transformation and Projection matrices.
All these steps are common in graphics programming, and WebGPU allows you to perform these same operations.
It is a good idea to read the individual chapters in the [3D Rendering](https://eliemichel.github.io/LearnWebGPU/basic-3d-rendering/index.html) section to learn more.
### Loading 3D objects
In this Learning Path you can use OBJ files to define 3D meshes.
Instead of manually parsing OBJ files, you can use the [TinyOBJLoader](https://github.com/tinyobjloader/tinyobjloader) library.
The file format is not complex, but parsing files is out of the scope of this Learning Path.
You can use open-source software such as Blender to create your own 3D objects.
> **Note**
> Only one of your source files must define `TINYOBJLOADER_IMPLEMENTATION` before including it:
> ```cpp
> #define TINYOBJLOADER_IMPLEMENTATION // add this to exactly 1 of your C++ files
> #include "tiny_obj_loader.h"
There is a helper function [`loadGeometryFromObj`](https://github.com/varunchariArm/Android_DawnWebGPU/blob/main/app/src/main/cpp/webgpuRenderer.cpp#L475) available to load objects.
You are now ready to render a 3D object.
## Rendering using WebGPU
You can run a rendering pass and *draw* something onto our *surface*.
To encode any commands to be issued to GPU, you need to create a `CommandEncoder`. Modern APIs record commands into command buffers, rather than issuing commands one by one, and submit all of them at once.
In WebGPU, this is done through a `CommandEncoder` as shown below:
```cpp
wgpu::CommandEncoderDescriptor commandEncoderDesc;
commandEncoderDesc.label = "Command Encoder";
wgpu::CommandEncoder encoder = device.createCommandEncoder(commandEncoderDesc);
The next step is to create a `RenderPassEncoder`.
It encodes commands related to controlling the vertex and fragment shader stages, as issued by RenderPipeline. It forms part of the overall encoding activity of a CommandEncoder. A render pipeline renders graphics to Texture attachments, typically intended for displaying on a surface, but it could also render to textures used for other purposes that never appear onscreen.
It has two main stages:
- A vertex stage, in which a vertex shader takes positioning data fed into the GPU and uses it to position a series of vertices in 3D space by applying specified effects like rotation, translation, or perspective.
- A fragment stage, in which a fragment shader computes the color for each pixel covered by the primitives produced by the vertex shader.
You can create a RenderPassEncoder using the `encoder.beginRenderPass()` API:
```cpp
wgpu::RenderPassDescriptor renderPassDesc{};
wgpu::RenderPassColorAttachment renderPassColorAttachment{};
renderPassColorAttachment.view = nextTexture;
renderPassColorAttachment.resolveTarget = nullptr;
renderPassColorAttachment.loadOp = wgpu::LoadOp::Clear;
renderPassColorAttachment.storeOp = wgpu::StoreOp::Store;
renderPassColorAttachment.clearValue = Color{ 1, 1, 1, 1.0 };
renderPassColorAttachment.depthSlice = WGPU_DEPTH_SLICE_UNDEFINED;
renderPassDesc.colorAttachmentCount = 1;
renderPassDesc.colorAttachments = &renderPassColorAttachment;
renderPassDesc.timestampWrites = nullptr;
wgpu::RenderPassEncoder renderPass = encoder.beginRenderPass(renderPassDesc);
> **Note**
> `ColorAttachment` is the only mandatory field. Make sure you have specified `renderPassColorAttachment.depthSlice`.
> It is recommended to go through the ColorAttachment [members](https://gpuweb.github.io/gpuweb/#color-attachments).
You can invoke the following APIs to draw a 3D object:
- `renderPass.setPipeline(...);`
- `renderPass.setVertexBuffer(...);`
- `renderPass.setBindGroup(...);`
- `renderPass.draw(...);`
To finish encoding the sequence of commands and issue them to the GPU, a few more API calls are needed:
- End render pass `renderPass.end()`
- Finish the command
  ```cpp
  wgpu::CommandBufferDescriptor cmdBufferDescriptor{};
  cmdBufferDescriptor.label = "Command buffer";
  wgpu::CommandBuffer command = encoder.finish(cmdBufferDescriptor);
  encoder.release();
- Submit the Queue `queue.submit(command)`
- Present the object onto surface `surface_.present()`
> **Tip**
> Make sure you release the created encoders and buffers by calling the respective `.release()` in order to avoid dangling pointers or other errors.
> **Note**
> By default, Dawn runs callbacks only when the device “ticks”, so the error callbacks are invoked in a different call stack than where the error occurred, making the breakpoint less informative.
> To force Dawn to invoke error callbacks as soon as there is an error, you can enable an instance toggle:
> ```cpp
> #ifdef WEBGPU_BACKEND_DAWN
> // Make sure the uncaptured error callback is called as soon as an error
> // occurs rather than at the next call to "wgpuDeviceTick".
> WGPUDawnTogglesDescriptor toggles;
> toggles.chain.next = nullptr;
> toggles.chain.sType = WGPUSType_DawnTogglesDescriptor;
> toggles.disabledToggleCount = 0;
> toggles.enabledToggleCount = 1;
> const char* toggleName = "enable_immediate_error_handling";
> toggles.enabledToggles = &toggleName;
> desc.nextInChain = &toggles.chain;
> #endif // WEBGPU_BACKEND_DAWN
> Toggles are Dawn’s way of enabling/disabling features at the scale of the whole WebGPU instance. See the complete list in [Toggle.cpp](https://dawn.googlesource.com/dawn/+/refs/heads/main/src/dawn/native/Toggles.cpp#33).
## Building and running the application
You are now ready to build and run the application.
First, copy the files with the shader code and 3D object files to a connected phone:
```bash
cd ~/AndroidStudioProjects/dawnwebgpu/app/src/main/cpp
adb shell "mkdir /data/local/tmp/webgpu/"
adb push resources/shader_texture_file.wgsl /data/local/tmp/webgpu/
adb push resources/cone_in_turdis.obj /data/local/tmp/webgpu/
adb push resources/cone_in_turdis.mtl /data/local/tmp/webgpu/
> **Note**
> If `adb` is not in your search path, enter the path to `adb`. For example:
> ```bash
> ~/Library/Android/sdk/platform-tools/adb shell "mkdir /data/local/tmp/webgpu/"
Now click the **Run** icon in Android Studio, which builds the application and launches it on the connected device, producing the following output:
![Image Alt Text:Output ](/learning-paths/mobile-graphics-and-gaming/android_webgpu_dawn/images/output.gif)
*Figure 10: Output*
Congratulations! You have now run a WebGPU application on an Android device.
