Start by creating a new Android Studio project.
Open Android Studio, click New Project, and select Game Activity (C++) as shown below:
Figure 4: New C++ Game Activity
The project is created in ~/AndroidStudioProjects
GameActivity is a Jetpack library designed to assist Android games in processing app cycle commands, input events, and text input in the application’s C/C++ code.
GameActivity is a direct descendant of NativeActivity and shares a similar architecture:
Figure 5: Game Activity Architecture
With GameActivity, you can focus on game development and avoid spending excessive amounts of time dealing with the Java Native Interface (JNI) code.
GameActivity performs the following functions:
You can find more information about Android Game Activity and its capabilities in the Game Activity Documentation .
The process of creating a WebGPU application involves adding a number of files from GitHub to your Game Activity project.
The objective of this part of the Learning Path is to show you how to take the Game Activity template and modify it to become a WebGPU application.
To get started, open a terminal, create a new directory, and download the project files:
mkdir ~/webgpu-files ; cd ~/webgpu-files
wget https://github.com/varunchariArm/Android_DawnWebGPU/archive/refs/heads/main.zip
Unzip the project files:
unzip main.zip
You now have a directory named Android_DawnWebGPU-main in the webgpu-files directory.
During the following sections, you will copy some of the required files from the Android_DawnWebGPU-main directory into your Game Activity project to learn how to create WebGPU applications.
Return to Android Studio and start work on the WebGPU application.
The Android Game Activity framework uses OpenGLES3 for graphics. You can remove this dependency and replace it with WebGPU.
Add WebGPU to the project using the following steps:
webgpu.hpp
header file:
mkdir -p app/src/main/cpp/webgpu/include/webgpu
cd app/src/main/cpp/webgpu/include/webgpu
cp ~/webgpu-files/Android_DawnWebGPU-main/app/src/main/cpp/webgpu/include/webgpu/webgpu.hpp .
cd ../..
Next, copy the remaining WebGPU files to your project.
cp ~/webgpu-files/Android_DawnWebGPU-main/app/src/main/cpp/webgpu/CMakeLists.txt .
cp ~/webgpu-files/Android_DawnWebGPU-main/app/src/main/cpp/webgpu/FetchDawn.cmake .
cp ~/webgpu-files/Android_DawnWebGPU-main/app/src/main/cpp/webgpu/fetch_dawn_dependencies.py .
cp ~/webgpu-files/Android_DawnWebGPU-main/app/src/main/cpp/webgpu/webgpu.cmake .
cd ..
Notice that FetchDawn.cmake
uses a stable chromium/6536
branch of Dawn repository.
WebGPU is a constantly evolving standard and hence its implementation, Dawn is also under active development. For sake of stability, we have chosen a stable branch for our development. Updating to latest or different branch may cause breakage.
To add Dawn to our application, there are two options:
You will use the second option here, since it provides more flexibility for debug.
The files webgpu/webgpu.cmake
and CMakeLists.txt
facilitate downloading and building WebGPU with Dawn implementation and integrating Dawn into the project.
WebGPU is added to the project in the file CMakeLists.txt
Copy the updated file by running the command:
cp ~/webgpu-files/Android_DawnWebGPU-main/app/src/main/cpp/CMakeLists.txt .
Review CMakeLists.txt
and see that the options
, include
, and add_subdirectory
are added from the original Game Activity file.
#Set Dawn build options
option(DAWN_FETCH_DEPENDENCIES "" ON)
option(DAWN_USE_GLFW "" ON)
option(DAWN_SUPPORTS_GLFW_FOR_WINDOWING "" OFF)
option(DAWN_USE_X11 "" OFF)
option(ENABLE_PCH "" OFF)
include(utils.cmake)
add_subdirectory(webgpu)
Also look at the CMakeLists.txt
file and see that the target_link_libraries
is changed to remove the WebGL components and add the webgpu
libraries.
# Configure libraries CMake uses to link your target library.
target_link_libraries(dawnwebgpu
# The game activity
game-activity::game-activity
# webgpu dependency
webgpu
jnigraphics
android
log)
The webgpu.hpp
header file acts like an interface, exposing all the WebGPU functions and variables to the main Application.
Navigate to the next section to continue building the WebGPU application.
