You will need a x86_64 or Apple M1 computer with Android Studio installed. Currently, Android Studio is not supported on Windows and Linux machines with Arm based CPUs.
You will also need a Armv8 powered smartphone running Android to run your application on. We tested the application in this learning path on a Google Pixel 7 smartphone.
Do not repeat yourself (DRY) is one of the major principles of software development. Following this principle means reusing your code using functions. However, invoking a function adds extra overhead. In certain cases compilers can reduce this overhead by taking advantage of built-in functions called intrinsics. The compiler replaces the intrinsics that are used in high-level programming languages, for example C/C++, with mostly 1:1 mapped assembly instructions.
To further improve performance, you need to use assembly code. However, with Arm Neon intrinsics you can avoid the complication of writing assembly functions. Instead you only need to program in C/C++ and call the intrinsics or instruction functions that are declared in the arm_neon.h
header file. Neon intrinsics can improve the performance of your application.
Arm Neon intrinsics technology is an advanced Single Instruction Multiple Data (SIMD) architecture extension for Arm processors. SIMD performs the same operation on a sequence, or vector, of data during a single CPU cycle.
In this section, you will setup your Android development environment to use Neon instrinsics.
Open Android Studio on your development machine.
Create a project using the Native C++ Project
option in the Phone and Tablet section and click Next
, as shown below:
Neon Intrinsics
, select Java
as the language, leave the Minimum SDK selection as API 24: Android 7.0(Nougat)
and click Next
, as shown below:Toolchain Default
selection for C++ Standard and then click Finish
, as shown below:CMake
and Android NDK
. Click on File->Settings
. On the left pane, under System Settings
select Android SDK
. From the tabs on the right, click on SDK Tools
. Select the CMake
and NDK(Side by side)
packages and click on Apply
followed by OK
, as shown below:MainActivity
class. It prints a “Hello from C++” string in the app which comes from the native-lib
library. Open app/cpp/native-lib.cpp
as shown below to view the code for this library:arm64-v8a
ABI. This ABI is for Armv8-A based CPUs, which support the 64-bit Arm architecture. On the left pane, expand Gradle Scripts
and open build.gradle(Module :app)
file. Add the line below to the defaultConfig
section:
ndk.abiFilters 'arm64-v8a'
The code in this section should look like:
defaultConfig {
applicationId "com.example.neonintrinsics"
minSdk 24
targetSdk 33
versionCode 1
versionName "1.0"
testInstrumentationRunner "androidx.test.runner.AndroidJUnitRunner"
build.grade(Module :app)
arguments "-DANDROID_ARM_NEON=ON"
This argument is added under externalNativeBuild
in the defaultConfig
section of the file. The complete build.gradle(Module :app)
file is shown below for completeness:
plugins {
id 'com.android.application'
android {
namespace 'com.example.neonintrinsics'
compileSdk 33
defaultConfig {
minSdk 24
targetSdk 33
versionCode 1
versionName "1.0"
externalNativeBuild {
cmake{
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android-optimize.txt'), 'proguard-rules.pro'
compileOptions {
sourceCompatibility JavaVersion.VERSION_1_8
targetCompatibility JavaVersion.VERSION_1_8
cmake {
path file('src/main/cpp/CMakeLists.txt')
version '3.22.1'
buildFeatures {
viewBinding true
dependencies {
implementation 'androidx.appcompat:appcompat:1.6.1'
implementation 'com.google.android.material:material:1.9.0'
implementation 'androidx.constraintlayout:constraintlayout:2.1.4'
testImplementation 'junit:junit:4.13.2'
androidTestImplementation 'androidx.test.ext:junit:1.1.5'
androidTestImplementation 'androidx.test.espresso:espresso-core:3.5.1'
With these changes you can use Neon intrinsics, which are declared within the arm_neon.h
header.
Build->Make Project
. When the build completes, you should see messages in the Build console similar to those shown below:
BUILD SUCCESSFUL in 2m 44s
37 actionable tasks: 37 executed
Build Analyzer results available
Tools->Device Manager
. Select the Physical
tab and your connected phone should show up on the list of devices as shown in the image below:Then select Run->Run app
or press Shift+F10
to run the app on the connected phone.
The output from the app running on the Google Pixel 7 running Android 13 is shown below:
You have now successfully setup and validated your Android development environment for running applications with Neon intrinsics on a 64-bit Arm powered smartphone.
In the next section, you will implement the dot product of two vectors using Neon intrinsics.
