Log an issue
Fork and edit
Discuss on Discord
What is Frame Advisor?
Capture a trace
Analyze draw calls
Analyze frame construction
Analyze mesh geometry
Send feedback
Review
You should now know how to:
Which graphics APIs are supported by Frame Advisor when capturing data from an Android application?
Which Frame Advisor views can you use to step through draw calls to see how the frame is built?
The Render Graph is used to:
How can you reduce processing cost and memory bandwidth?
You need to answer each question to see the results.
