To query which compression was applied, if any, once a VkImage has been created, use a
VkImageCompressionPropertiesEXT
structure.
Add VkImageCompressionPropertiesEXT to the pNext chain of
VkImageSubresource2EXT
, and then call
vkGetImageSubresourceLayout2EXT
VkImageCompressionPropertiesEXT applied_compression_properties{VK_STRUCTURE_TYPE_IMAGE_COMPRESSION_PROPERTIES_EXT};
VkSubresourceLayout2EXT subresource_layout{VK_STRUCTURE_TYPE_SUBRESOURCE_LAYOUT_2_KHR};
subresource_layout.pNext = &applied_compression_properties;
VkImageSubresource2EXT image_subresource{VK_STRUCTURE_TYPE_IMAGE_SUBRESOURCE_2_KHR};
image_subresource.imageSubresource.aspectMask = VK_IMAGE_ASPECT_COLOR_BIT;
image_subresource.imageSubresource.mipLevel = 0;
image_subresource.imageSubresource.arrayLayer = 0;
vkGetImageSubresourceLayout2EXT(get_device().get_handle(), image_handle, &image_subresource, &subresource_layout);
Inspect the values written to the imageCompressionFlags and imageCompressionFixedRateFlags components of VkImageCompressionPropertiesEXT:
LOGI("Created image reports {}", compression_to_string(applied_compression_properties.imageCompressionFlags));
LOGI("Created image reports {}", fixed_rate_flags_to_string(applied_compression_properties.imageCompressionFixedRateFlags));
The output may then look like this:
I/VulkanSamples: [info] Created image reports VK_IMAGE_COMPRESSION_FIXED_RATE_EXPLICIT_EXT
I/VulkanSamples: [info] Created image reports VK_IMAGE_COMPRESSION_FIXED_RATE_5BPC_BIT_EXT
You have now successfully added fixed-rate compression to your image, saving both memory and bandwidth.
