# Query for compression support
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/afrc/)
- [What is fixed-rate compression?](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/afrc/p1-intro/)
- [How to run the code examples](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/afrc/p2-setup/)
- [Vulkan Extensions](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/afrc/p3-enable-extensions/)
- [Query for compression support](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/afrc/p4-query-afrc-support/)
- [Request fixed-rate compression](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/afrc/p5-request-afrc/)
- [Verify that compression is applied](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/afrc/p6-verify-afrc/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/afrc/_next-steps/)
To create a VkImage, you need a [VkImageCreateInfo](https://registry.khronos.org/vulkan/specs/1.3-extensions/man/html/VkImageCreateInfo.html) structure defining the image’s properties. Before creating the image, you can use these properties to query if the image supports fixed-rate compression on your platform. For instance, the structure may look like this:
```c
VkImageCreateInfo image_create_info = {
    VK_STRUCTURE_TYPE_IMAGE_CREATE_INFO
image_create_info.format = VK_FORMAT_R8G8B8_UNORM;
image_create_info.imageType = VK_IMAGE_TYPE_2D;
image_create_info.tiling = VK_IMAGE_TILING_OPTIMAL;
image_create_info.usage = VK_IMAGE_USAGE_COLOR_ATTACHMENT_BIT | VK_IMAGE_USAGE_SAMPLED_BIT;
image_create_info.extent = {8, 8, 1};
image_create_info.mipLevels = 1;
image_create_info.arrayLayers = 1;
image_create_info.samples = VK_SAMPLE_COUNT_1_BIT;
To query for fixed-rate compression support, use this information to fill in a [VkImageFormatProperties2](https://registry.khronos.org/vulkan/specs/1.3-extensions/man/html/VkImageFormatProperties2KHR.html) structure:
```c
VkPhysicalDeviceImageFormatInfo2 image_format_info = {
    VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_IMAGE_FORMAT_INFO_2
image_format_info.format = image_create_info.format;
image_format_info.type = image_create_info.imageType;
image_format_info.tiling = image_create_info.tiling;
image_format_info.usage = image_create_info.usage;
Additionally, add a [VkImageCompressionControlEXT](https://registry.khronos.org/vulkan/specs/1.3-extensions/man/html/VkImageCompressionControlEXT.html) to its `pNext` chain:
```c
VkImageCompressionControlEXT compression_control = {
    VK_STRUCTURE_TYPE_IMAGE_COMPRESSION_CONTROL_EXT
compression_control.flags = VK_IMAGE_COMPRESSION_FIXED_RATE_DEFAULT_EXT;
image_format_info.pNext = &compression_control;
You may then prepare a `VkImageFormatProperties2` structure, with a [VkImageCompressionPropertiesEXT](https://registry.khronos.org/vulkan/specs/1.3-extensions/man/html/VkImageCompressionPropertiesEXT.html) in its `pNext` chain:
```c
VkImageCompressionPropertiesEXT supported_compression_properties = {
    VK_STRUCTURE_TYPE_IMAGE_COMPRESSION_PROPERTIES_EXT
VkImageFormatProperties2 image_format_properties = {
    VK_STRUCTURE_TYPE_IMAGE_FORMAT_PROPERTIES_2
image_format_properties.pNext = &supported_compression_properties;
Finally, put these two together in a call to `vkGetPhysicalDeviceImageFormatProperties2KHR`:
```c
vkGetPhysicalDeviceImageFormatProperties2KHR(
    get_device().get_gpu().get_handle(),
    &image_format_info,
    &image_format_properties
You can then inspect the values written to `VkImageCompressionPropertiesEXT` to determine if the image supports fixed-rate compression. For instance, you may use the print function helper provided below to inspect the logs when running your sample:
```c
LOGI("Image supports {}", compression_to_string(supported_compression_properties.imageCompressionFlags));
LOGI("Image supports {}", fixed_rate_flags_to_string(supported_compression_properties.imageCompressionFixedRateFlags));
The logcat output may look like this:
```plaintext
__output__ I/VulkanSamples: [info] Image supports VK_IMAGE_COMPRESSION_FIXED_RATE_EXPLICIT_EXT
__output__ I/VulkanSamples: [info] Image supports VK_IMAGE_COMPRESSION_FIXED_RATE_2BPC_BIT_EXT | VK_IMAGE_COMPRESSION_FIXED_RATE_4BPC_BIT_EXT | VK_IMAGE_COMPRESSION_FIXED_RATE_5BPC_BIT_EXT
Print helper functions for reference:
```c
const std::string compression_to_string(VkImageCompressionFlagsEXT flag) {
    switch (flag) {
        case VK_IMAGE_COMPRESSION_DEFAULT_EXT:
            return "VK_IMAGE_COMPRESSION_DEFAULT_EXT";
        case VK_IMAGE_COMPRESSION_FIXED_RATE_DEFAULT_EXT:
            return "VK_IMAGE_COMPRESSION_FIXED_RATE_DEFAULT_EXT";
        case VK_IMAGE_COMPRESSION_FIXED_RATE_EXPLICIT_EXT:
            return "VK_IMAGE_COMPRESSION_FIXED_RATE_EXPLICIT_EXT";
        case VK_IMAGE_COMPRESSION_DISABLED_EXT:
            return "VK_IMAGE_COMPRESSION_DISABLED_EXT";
        default:
            return "";
const std::string fixed_rate_flags_to_string(uint32_t flags) {
    if (0 == flags) {
        return "VK_IMAGE_COMPRESSION_FIXED_RATE_NONE_EXT";
    const std::map<VkImageCompressionFixedRateFlagsEXT, const char*> string_map = {
        {VK_IMAGE_COMPRESSION_FIXED_RATE_1BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_1BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_2BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_2BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_3BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_3BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_4BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_4BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_5BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_5BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_6BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_6BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_7BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_7BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_8BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_8BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_9BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_9BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_10BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_10BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_11BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_11BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_12BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_12BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_13BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_13BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_14BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_14BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_15BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_15BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_16BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_16BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_17BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_17BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_18BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_18BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_19BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_19BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_20BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_20BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_21BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_21BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_22BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_22BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_23BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_23BPC_BIT_EXT"},
        {VK_IMAGE_COMPRESSION_FIXED_RATE_24BPC_BIT_EXT, "VK_IMAGE_COMPRESSION_FIXED_RATE_24BPC_BIT_EXT"}
    std::stringstream result;
    bool append = false;
    for (const auto& s : string_map) {
        if (flags & s.first) {
            if (append) {
                result << " | ";
            result << s.second;
            append = true;
    return result.str();
### Why does this image not support fixed-rate compression?
You may find that the output of the code looks like:
```plaintext
__output__ I/VulkanSamples: [info] Image supports VK_IMAGE_COMPRESSION_DISABLED_EXT
__output__ I/VulkanSamples: [info] Image supports VK_IMAGE_COMPRESSION_FIXED_RATE_NONE_EXT
This means that the image does not support any sort of compression. Possible reasons are discussed in [Arm GPU Best Practices Developer Guide](https://developer.arm.com/documentation/101897/latest/Buffers-and-textures/AFRC?lang=en). Depending on the device, image properties like `image_create_info.format` and `image_create_info.usage` (e.g., storage images) may be incompatible with fixed-rate compression.
Try using different values for these in case you find a suitable combination for your application that supports fixed-rate compression. Otherwise, for better performance, try to find one that at least supports AFBC if possible, following the guidance found in [the AFBC guide](https://developer.arm.com/documentation/101897/latest/Buffers-and-textures/AFBC-textures-for-Vulkan?lang=en), so that the output ideally looks like this:
```plaintext
__output__ I/VulkanSamples: [info] IMAGE SUPPORTS VK_IMAGE_COMPRESSION_DEFAULT_EXT
__output__ I/VulkanSamples: [info] IMAGE SUPPORTS VK_IMAGE_COMPRESSION_FIXED_RATE_NONE_EXT
