Set up the virtual machine
Create a Google Axion C4A Arm-based virtual machine (VM) on Google Cloud Platform. For this Learning Path, you’ll use the c4a-standard-4 machine type. c4a-standard-4provides 4 vCPUs and 16 GB of memory.
The VM that you’ll create will host XGBoost model training, hyperparameter tuning, benchmarking, and the inference API.
Note
For help with Google Cloud Platform setup, see the Learning Path Getting started with Google Cloud Platform .
To create a C4A VM in the Google Cloud console:
  1. Navigate to the Google Cloud console .
  2. Go to Compute Engine > VM Instances and select Create Instance.
  3. Under Machine configuration, populate fields such as Instance name, Region, and Zone.
  4. Set Series to C4A, then select c4a-standard-4 for Machine type.
Image Alt Text:Screenshot of the Google Cloud console showing the Machine configuration section. The Series dropdown is set to C4A and the machine type c4a-standard-4 is selectedSelecting machine type as C4A in the Google Cloud console
  1. Under OS and storage, select Change and then choose an Arm64-based operating system image. For this Learning Path, select SUSE Linux Enterprise Server.
  2. For the license type, choose Pay as you go.
  3. Increase Size (GB) from 10 to 100 to allocate sufficient disk space, and then select Choose.
  4. Expand Advanced options and select Networking.
  5. Under Network tags, enter allow-xgboost-8080 to link the VM to the firewall rule used for external API access and browser connectivity.
  6. Select Create to launch the virtual machine.
After the instance starts, select SSH next to the VM in the instance list to open a browser-based terminal session.
Image Alt Text:Google Cloud console VM instances page displaying running instance with green checkmark and SSH button in the Connect columnConnecting to a running C4A VM using SSH
A new browser window opens with a terminal connected to your VM.
Image Alt Text:Browser-based SSH terminal connected to the Google Axion C4A VM, showing the shell prompt ready for the next stepTerminal session connected to the VM
You’ve now provisioned a Google Axion C4A Arm VM and connected to it using SSH. The VM is linked to the firewall rule that allows access to port 8080 for the XGBoost inference API.
Next, you’ll install XGBoost and configure a Python 3.11 environment for model training and benchmarking.
