MoE performance benchmarking
Use vllm bench serve to measure throughput and latency while a model serves concurrent requests.
The benchmark sends requests to the vLLM OpenAI-compatible API server at /v1/chat/completions.
Start the model server first using the commands from Run mixture of experts (MoE) inference with vLLM , and keep it running in one terminal. Then, run the benchmark command from another terminal.
In the benchmark terminal, change to the directory where you created vllm_env_new. Activate that environment and set MODEL to match the running server:
source vllm_env_new/bin/activate
export MODEL=google/gemma-4-26B-A4B-it
Download the full ShareGPT dataset into this directory:
wget https://huggingface.co/datasets/anon8231489123/ShareGPT_Vicuna_unfiltered/resolve/main/ShareGPT_V3_unfiltered_cleaned_split.json
The reported results use subsets selected with each model tokenizer for approximately 512 input tokens. Downloading the full dataset doesn’t create those subsets. Create the model-specific subsets before running the benchmark commands.
Create ShareGPT prompt subsets
Create a file named create_sharegpt_512_subsets.py with the following code:
import json
from pathlib import Path
from transformers import AutoTokenizer
INPUT = Path("ShareGPT_V3_unfiltered_cleaned_split.json")
MODELS = {
    "gemma4": "google/gemma-4-26B-A4B-it",
    "gptoss": "unsloth/gpt-oss-20b-BF16",
    "qwen": "Qwen/Qwen3-30B-A3B-Thinking-2507",
TOKEN_RANGE = (460, 580)
MAX_SAMPLES = 256
data = json.loads(INPUT.read_text())
for model_name, model_id in MODELS.items():
    tokenizer = AutoTokenizer.from_pretrained(model_id)
    rows = []
    for item in data:
        conversations = item.get("conversations") or item.get("conversation")
        if not conversations:
            continue
        first = conversations[0]
        prompt = first.get("value") or first.get("content")
        if not prompt:
            continue
        n_tokens = len(tokenizer.encode(prompt))
        if TOKEN_RANGE[0] <= n_tokens <= TOKEN_RANGE[1] and len(rows) < MAX_SAMPLES:
            rows.append(item)
    out = Path(f"sharegpt_{model_name}_512.json")
    out.write_text(json.dumps(rows, indent=2))
    print(f"{model_name}: {len(rows)} samples -> {out}")
Run the script:
python create_sharegpt_512_subsets.py
This creates the subset files that are used by the benchmark commands:
sharegpt_gemma4_512.json
sharegpt_gptoss_512.json
sharegpt_qwen_512.json
Review benchmark setup
The benchmark setup that you’ll use includes the following configuration:
Dataset: ShareGPT prompt subsets
Prompt subset: ~512 input tokens
Number of prompts: 128
Requested output length: 512 output tokens
Prefix caching: enabled
Warmup requests: 5
Decoding: greedy decoding with temperature=0, top-p=1, top-k=1
Concurrency values: 4, 8, 16, 32
Benchmark tool: vllm bench serve
Greedy decoding is configured with --top-p 1 --temperature 0 --top-k 1. This selects the highest-probability next token instead of sampling. It doesn’t guarantee identical responses across different builds or precision settings.
When prefix caching is enabled, repeating vllm bench serve against the same server can reuse prompts from earlier benchmark runs and inflate throughput. To avoid cache reuse across runs, start a fresh vLLM server for each concurrency value. Warmup requests can still populate the cache within a run. Keep the warmup and cache settings consistent across comparisons.
Run the benchmark
After the Gemma 4 subset is available in your current directory, run the benchmark:
export C=4
vllm bench serve \
  --model "$MODEL" \
  --backend openai-chat \
  --dataset-name sharegpt \
  --dataset-path ./sharegpt_gemma4_512.json \
  --num-prompts 128 \
  --max-concurrency "$C" \
  --sharegpt-output-len 512 \
  --top-p 1 \
  --temperature 0 \
  --top-k 1 \
  --percentile-metrics ttft,tpot \
  --metric-percentiles 50,95,99 \
  --endpoint /v1/chat/completions \
  --save-result \
  --result-dir bench_out \
  --result-filename gemma4_bf16_sharegpt_mc${C}.json \
  --num-warmups 5
--max-concurrency limits simultaneous requests. --num-prompts sets the total number of requests, and --num-warmups sends warmup requests before measurement. The benchmark prints a summary and saves JSON to bench_out/gemma4_bf16_sharegpt_mc4.json for this run.
--sharegpt-output-len 512 requests up to 512 generated tokens. Responses can stop earlier, so inspect actual output token counts when comparing throughput.
Repeat the command with C=8, then C=16, then C=32. Restart the server and wait for it to become ready before each run. Keep the model, dataset, and server settings unchanged while varying concurrency.
For each additional model, update MODEL in both terminals. Then, restart the server and replace the dataset and result filename arguments. Use distinct result filenames for each model and precision to avoid overwriting earlier runs:
ModelRequired subset fileExample result filename
Gemma 4 BF16sharegpt_gemma4_512.jsongemma4_bf16_sharegpt_mc${C}.json
GPT-OSS BF16sharegpt_gptoss_512.jsongptoss_bf16_sharegpt_mc${C}.json
Qwen3 BF16sharegpt_qwen_512.jsonqwen3_bf16_sharegpt_mc${C}.json
Qwen3 W8A8sharegpt_qwen_512.jsonqwen3_w8a8_sharegpt_mc${C}.json
Use the same Qwen3 subset for both precisions. Record the following values alongside your results:
  • CPU thread binding
  • Server arguments
  • Package versions
  • Any changes to the key-value (KV) cache budget
Review metrics
Check that all 128 measured requests completed successfully before interpreting performance. Investigate failed requests in the server logs.
Use the summary and saved JSON to compare the following metrics at the same concurrency:
MetricMeaningPreferred direction
Request throughputCompleted requests per secondHigher
Output token throughputGenerated tokens per secondHigher
Total token throughputInput and output tokens per secondHigher
TTFTTime to first token, reported in millisecondsLower
TPOTTime per output token after the first, reported in millisecondsLower
The command reports the 50th, 95th, and 99th percentiles for TTFT and TPOT. Higher percentiles help you assess latency for slower requests.
Different response lengths change the amount of work performed. You should therefore compare actual input and output token counts as well as throughput.
After completing a run, you have a serving-performance summary and a saved JSON result for your selected model and workload.
Next, you’ll review the benchmark results and compare the BF16 and INT8/W8A8 MoE runs.
