Validate model serving
Start a model server and send a chat request to verify that the selected checkpoint works with your CPU installation.
For each model, start the vLLM server in one terminal, then send a test request from another terminal. Before starting another model, stop the current vLLM server with Ctrl+C and wait for it to exit. Only one vLLM server can use the default port 8000 at a time.
Choose a model
Use the following model IDs in the vllm serve and curl commands:
ModelModel ID
Gemma 4 BF16google/gemma-4-26B-A4B-it
GPT-OSS BF16unsloth/gpt-oss-20b-BF16
Qwen3 BF16Qwen/Qwen3-30B-A3B-Thinking-2507
Qwen3 W8A8RedHatAI/Qwen3-30B-A3B-Thinking-2507-quantized.w8a8
Use the terminal with your virtual environment active and VLLM_CPU_KVCACHE_SPACE set. Set the model ID and start the server. For example, to serve Gemma 4 BF16:
export MODEL=google/gemma-4-26B-A4B-it
vllm serve "$MODEL"
On the first run, vLLM downloads the model weights and warms up the model, including CPU code compilation. Wait until you see Application startup complete before continuing. The server is now listening on port 8000.
To test a different model, stop the current server. Update MODEL using one of the model IDs from the table, then run vllm serve "$MODEL" again.
Send a test request
In another terminal on the same server, set the model ID to match the running server and send a test request.
For example, to send a test request to a Gemma 4 server:
curl http://127.0.0.1:8000/v1/chat/completions \
  -H "Content-Type: application/json" \
  -d '{
    "model": "'"$MODEL"'",
    "messages": [
      {"role": "user", "content": "Explain mixture of experts in one sentence."}
    "max_tokens": 64,
    "temperature": 0
max_tokens limits generation to 64 tokens, and temperature: 0 selects greedy decoding. This is a short connectivity and generation check.
The output is similar to the following Gemma 4 response, with some metadata fields omitted for brevity:
  "id": "chatcmpl-960932ecaccca7ae",
  "object": "chat.completion",
  "created": 1792608120,
  "model": "google/gemma-4-26B-A4B-it",
  "choices": [
      "index": 0,
      "message": {
        "role": "assistant",
        "content": "Mixture of Experts (MoE) is a neural network architecture that increases model capacity by using a \"router\" to activate only a small, specialized subset of its total parameters for any given input, making it more efficient than dense models."
      "finish_reason": "stop"
  "usage": {
    "prompt_tokens": 21,
    "total_tokens": 70,
    "completion_tokens": 49
The response text, ID, timestamp, and token counts can vary. The response by the assistant appears in choices[0].message.content. In this example, finish_reason is stop, indicating that generation ended normally rather than reaching the token limit.
A response with generated text confirms that inference is working for the selected model. If finish_reason is length, generation reached the token limit. Reasoning models can use the short budget before producing a final response. If you need a complete response, inspect any reasoning output and increase max_tokens.
You’ve validated a chat response from your selected model. Repeat the check for each checkpoint that you plan to benchmark.
Next, you’ll benchmark the models with vllm bench serve.
