# Understand W8A8 quantization for vLLM models
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/vllm-benchmark-quantisation/)
- [Set up vLLM](https://learn.arm.com/learning-paths/servers-and-cloud-computing/vllm-benchmark-quantisation/1-overview-and-setup/)
- [Understand W8A8 quantization for vLLM models](https://learn.arm.com/learning-paths/servers-and-cloud-computing/vllm-benchmark-quantisation/2-quantisation-recipe/)
- [Run inference with vLLM](https://learn.arm.com/learning-paths/servers-and-cloud-computing/vllm-benchmark-quantisation/3-run-inference/)
- [Evaluate Llama 3.1 8B throughput and accuracy](https://learn.arm.com/learning-paths/servers-and-cloud-computing/vllm-benchmark-quantisation/4-benchmarking/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/vllm-benchmark-quantisation/_next-steps/)
## How W8A8 quantization works
Quantized models have their weights converted to a lower precision data type, which reduces the memory requirements of the model and can improve performance significantly. There are many publicly available quantized versions of popular models, such as [RedHatAI/Meta-Llama-3.1-8B-quantized.w8a8](https://huggingface.co/RedHatAI/Meta-Llama-3.1-8B-quantized.w8a8) and [RedHatAI/whisper-large-v3-quantized.w8a8](https://huggingface.co/RedHatAI/whisper-large-v3-quantized.w8a8), which you’ll use in this Learning Path.
The notation `w8a8` means that the weights have been quantized to 8-bit integers and the activations (the input data) are dynamically quantized to the same. This allows Arm’s 8-bit integer matrix multiply feature I8MM to be used. For more information, see the [KleidiAI and matrix multiplication](https://learn.arm.com/learning-paths/cross-platform/kleidiai-explainer/) Learning Path.
The `w8a8` models that you’ll use in this Learning Path apply quantization only to the weights and activations in the linear layers of the transformer blocks. The activation quantizations are applied per-token and the weights are quantized per-channel. That is, each output channel dimension has a scaling factor applied between INT8 and BF16 representations.
## (Optional) Quantize your own models
This step is optional. You’ll be using pre-quantized models from Hugging Face for the rest of this Learning Path, so you don’t need to run this recipe. Quantizing a model yourself can take several hours.
To learn more about quantizing your own models, see the [Run vLLM inference with INT4 quantization on Arm servers](https://learn.arm.com/learning-paths/servers-and-cloud-computing/vllm-acceleration/) Learning Path.
If you prefer to generate your own `w8a8` quantized model rather than using the pre-quantized Red Hat models, you can use the following recipe. Install the required packages before running the quantization script:
The following commands use specific package versions that were tested with this recipe. To find the latest versions, see [llmcompressor](https://github.com/vllm-project/llm-compressor/releases), [compressed-tensors](https://github.com/neuralmagic/compressed-tensors/releases), and [datasets](https://github.com/huggingface/datasets/releases) on GitHub.
```bash
pip install compressed-tensors==0.14.0.1
pip install llmcompressor==0.10.0.1
pip install datasets==4.6.0
The script uses Generalized Post-Training Quantization (GPTQ) to calibrate the quantization scales. It loads 256 samples from a calibration dataset, runs a forward pass through each linear layer, and computes per-channel weight scales and per-token activation scales. The output is saved as a quantized model in the `Meta-Llama-3.1-8B-quantized.w8a8` directory.
Create a file named `w8a8_quant.py` with the following content:
```python
from transformers import AutoTokenizer
from datasets import Dataset, load_dataset
from transformers import AutoModelForCausalLM
from llmcompressor import oneshot
from llmcompressor.modifiers.quantization import GPTQModifier
from compressed_tensors.quantization import QuantizationType, QuantizationStrategy
import random
model_id = "meta-llama/Meta-Llama-3.1-8B"  # Note: this uses the Meta-prefixed model ID required by llmcompressor
num_samples = 256
max_seq_len = 4096
tokenizer = AutoTokenizer.from_pretrained(model_id)
def preprocess_fn(example):
  return {"text": example["text"]}
ds = load_dataset("neuralmagic/LLM_compression_calibration", split="train")
ds = ds.shuffle().select(range(num_samples))
ds = ds.map(preprocess_fn)
scheme = {
        "targets": ["Linear"],
        "weights": {
            "num_bits": 8,
            "type": QuantizationType.INT,
            "strategy": QuantizationStrategy.CHANNEL,
            "symmetric": True,
            "dynamic": False,
            "group_size": None
        "input_activations":
            "num_bits": 8,
            "strategy": QuantizationStrategy.TOKEN,
            "dynamic": True,
            "symmetric": False,
            "observer": None,
        "output_activations": None,
recipe = GPTQModifier(
  targets="Linear",
  config_groups={"group_0": scheme},
  ignore=["lm_head"],
  dampening_frac=0.01,
  block_size=512,
model = AutoModelForCausalLM.from_pretrained(
  model_id,
  device_map="auto",
  trust_remote_code=True,
oneshot(
  model=model,
  dataset=ds,
  recipe=recipe,
  max_seq_length=max_seq_len,
  num_calibration_samples=num_samples,
model.save_pretrained("Meta-Llama-3.1-8B-quantized.w8a8")
Run the script. This step can take several hours depending on your hardware:
```bash
python w8a8_quant.py
When quantization is completed, copy the tokenizer files from the original model into your quantized model directory before running inference:
```bash
for f in tokenizer.json tokenizer_config.json special_tokens_map.json tokenizer.model; do
  cp ~/.cache/huggingface/hub/models--meta-llama--Meta-Llama-3.1-8B/snapshots/*/"$f" Meta-Llama-3.1-8B-quantized.w8a8/ 2&gt;/dev/null || true
done
## What you’ve accomplished and what’s next
You’ve now learned about quantization of vLLM models and the steps to quantize a model if you want to.
Next, you’ll use vLLM to run inference on both quantized and non-quantized models and compare their outputs.
