What is vLLM?
vLLM is an open-source, high-throughput inference and serving engine for large language models (LLMs). It’s designed to make LLM inference faster, more memory-efficient, and scalable, particularly during the prefill (context processing) and decode (token generation) phases of inference.
Key features
  • Continuous batching: dynamically merges incoming inference requests into larger batches, maximizing Arm CPU utilization and overall throughput
  • KV cache management: efficiently stores and reuses key-value attention states, sustaining concurrency across multiple active sessions while minimizing memory overhead
  • Token streaming: streams generated tokens as they are produced, enabling real-time responses for chat or API scenarios
Interaction modes
You can use vLLM in two main ways:
  • Using an OpenAI-Compatible REST Server: vLLM provides a /v1/chat/completions endpoint compatible with the OpenAI API schema, making it drop-in ready for tools like LangChain, LlamaIndex, and the official OpenAI Python SDK
  • Using a Python API: load and serve models programmatically within your own Python scripts for flexible local inference and evaluation
vLLM supports Hugging Face Transformer models out-of-the-box and scales seamlessly from single-prompt testing to production batch inference.
What you will build
In this Learning Path, you’ll build a CPU-optimized version of vLLM targeting the Arm64 architecture, integrated with oneDNN and the Arm Compute Library (ACL). This build enables high-performance LLM inference on Arm servers, leveraging specialized Arm math libraries and kernel optimizations. After compiling, you’ll validate your build by running a local chat example to confirm functionality and measure baseline inference speed.
Set up your environment
Before you begin, make sure your environment meets these requirements:
  • Python 3.12 on Ubuntu 22.04 LTS or newer
  • At least 32 vCPUs, 64 GB RAM, and 64 GB of free disk space
This Learning Path was tested on an AWS Graviton4 c8g.12xlarge instance with 64 GB of attached storage.
Install build dependencies
Install the following packages required for compiling vLLM and its dependencies on Arm64:
sudo apt-get update -y
sudo apt-get install -y build-essential cmake libnuma-dev
sudo apt install -y python3.12-venv python3.12-dev
You can optionally install tcmalloc, a fast memory allocator from Google’s gperftools, which improves performance under high concurrency:
sudo apt-get install -y libtcmalloc-minimal4
Note
On aarch64, vLLM’s CPU backend automatically builds with the Arm Compute Library (ACL) through oneDNN. This ensures optimized Arm kernels are used for matrix multiplications, layer normalization, and activation functions without additional configuration.
Build vLLM for Arm64 CPU
You’ll now build vLLM optimized for Arm (aarch64) servers with oneDNN and the Arm Compute Library (ACL) automatically enabled in the CPU backend.
Create and activate a Python virtual environment
It’s best practice to build vLLM inside an isolated environment to prevent conflicts between system and project dependencies:
python3.12 -m venv vllm_env
source vllm_env/bin/activate
python3 -m pip install --upgrade pip
Clone vLLM and install build requirements
Download the official vLLM source code and install its CPU-specific build dependencies:
git clone https://github.com/vllm-project/vllm.git
cd vllm
git checkout 5fb4137
pip install -r requirements/cpu.txt -r requirements/cpu-build.txt
The specific commit (5fb4137) pins a verified version of vLLM that officially adds Arm CPUs to the list of supported build targets, ensuring full compatibility and optimized performance for Arm-based systems.
Build the vLLM wheel for CPU
Run the following command to compile and package vLLM as a Python wheel optimized for CPU inference:
VLLM_TARGET_DEVICE=cpu python3 setup.py bdist_wheel
The output wheel will appear under dist/ and include all compiled C++/PyBind modules.
Install the wheel
Install the freshly built wheel into your active environment:
pip install --force-reinstall dist/*.whl              # fresh install
# pip install --no-deps --force-reinstall dist/*.whl  # incremental build
Tip
Do not delete the local vLLM source directory. The repository contains C++ extensions and runtime libraries required for correct CPU inference on aarch64 after wheel installation.
Validate your build with offline inference
Run a quick test to confirm your Arm-optimized vLLM build works as expected. Use the built-in chat example to perform offline inference and verify that oneDNN and Arm Compute Library optimizations are active.
python examples/offline_inference/basic/chat.py \
   --dtype=bfloat16 \
   --model TinyLlama/TinyLlama-1.1B-Chat-v1.0
This command runs a small Hugging Face model in bfloat16 precision, streaming generated tokens to the console. You should see output similar to:
        Generated Outputs:
Prompt: None
Generated text: 'The Importance of Higher Education\n\nHigher education is a fundamental right'
Adding requests: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 10/10 [00:00<00:00, 9552.05it/s]
Processed prompts: 100%|████████████████████████████████████████████████████████████████████████| 10/10 [00:01<00:00,  6.78it/s, est. speed input: 474.32 toks/s, output: 108.42 toks/s]
If you see token streaming and generated text, your vLLM build is correctly configured for Arm64 inference.
Note
As CPU support in vLLM continues to mature, these manual build steps will eventually be replaced by a streamlined pip install workflow for aarch64, simplifying future deployments on Arm servers.
You have now verified that your vLLM Arm64 build runs correctly and performs inference using Arm-optimized kernels. Next, you’ll proceed to model quantization, where you’ll compress LLM weights to INT4 precision using llmcompressor and benchmark the resulting performance improvements.
