IOMMU (Input–Output Memory Management Unit) controls how I/O devices access memory. In many cloud environments, SmartNICs offload IOMMU-related work. On Arm Neoverse bare‑metal systems, you can often improve Tomcat networking performance by disabling strict mode and enabling passthrough (setting iommu.strict=0 and iommu.passthrough=1).
Edit the GRUB configuration to set IOMMU to passthrough and disable strict invalidations:
sudo vi /etc/default/grub
Add or update the kernel command line:
GRUB_CMDLINE_LINUX="iommu.strict=0 iommu.passthrough=1"
Update GRUB and reboot to apply the settings:
sudo update-grub && sudo reboot
Verify that IOMMU is in passthrough mode after reboot:
sudo dmesg | grep iommu
You will notice that the IOMMU is already in passthrough mode:
[ 0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-6.14.0-1011-aws root=PARTUUID=1c3f3c20-db6b-497c-8727-f6702f73a5b2 ro iommu.strict=0 iommu.passthrough=1 console=tty1 console=ttyS0 nvme_core.io_timeout=4294967295 panic=-1
[ 0.855658] iommu: Default domain type: Passthrough (set via kernel command line)
Prepare the Arm Neoverse bare‑metal server (ensure your ${net} interface variable is set; if not, set it to your NIC name, for example net=enP11p4s0), align queues, and restart Tomcat:
for no in {96..103}; do sudo bash -c "echo 1 > /sys/devices/system/cpu/cpu${no}/online"; done
for no in {0..95} {104..191}; do sudo bash -c "echo 0 > /sys/devices/system/cpu/cpu${no}/online"; done
# Ensure NIC queue count matches the number of online CPUs (example: 8)
sudo ethtool -L ${net} combined 8
# Restart Tomcat with a higher file‑descriptor limit
~/apache-tomcat-11.0.10/bin/shutdown.sh 2>/dev/null
ulimit -n 65535 && ~/apache-tomcat-11.0.10/bin/startup.sh
Run wrk2 on the x86_64 benchmarking client to measure throughput and latency:
ulimit -n 65535 && wrk -c1280 -t128 -R500000 -d60 http://${tomcat_ip}:8080/examples/servlets/servlet/HelloWorldExample
Sample results after IOMMU tuning:
Thread Stats Avg Stdev Max +/- Stdev
Latency 4.92s 2.49s 10.08s 62.27%
Req/Sec 3.36k 56.23 3.58k 69.64%
25703668 requests in 1.00m, 13.33GB read
Requests/sec: 428628.50
Transfer/sec: 227.69MB
