In this section, you configure local NUMA and assess the performance uplift achieved through tuning. Cross‑NUMA data transfers generally incur higher latency than intra‑NUMA transfers, so Tomcat should be deployed on the NUMA node where the network interface resides to reduce cross‑node memory traffic and improve throughput and latency.
Check NUMA topology and relative latencies:
numactl -H
You should see that cross‑NUMA latency is higher than intra‑NUMA latency (for example, 10:100):
available: 2 nodes (0-1)
node 0 cpus: 0 1 2 3 4 5 6 7
node 0 size: 193502 MB
node 0 free: 188478 MB
node 1 cpus:
node 1 size: 192625 MB
node 1 free: 192338 MB
node distances:
node 0 1
0: 10 100
1: 100 10
Identify the NUMA node for your network interface (using the ${net} variable defined earlier):
cat /sys/class/net/${net}/device/numa_node
Example output (NIC on NUMA node 1):
1
Allocate the eight reserved cores to the NIC’s NUMA node (the example below keeps CPUs 96–103 online on node 1 and offlines the rest):
for no in {96..103}; do sudo bash -c "echo 1 > /sys/devices/system/cpu/cpu${no}/online"; done
for no in {0..95} {104..191}; do sudo bash -c "echo 0 > /sys/devices/system/cpu/cpu${no}/online"; done
Verify CPU online status and NUMA placement:
lscpu
You should see only CPUs 96–103 online on NUMA node 1:
Architecture: aarch64
CPU op-mode(s): 64-bit
Byte Order: Little Endian
CPU(s): 192
On-line CPU(s) list: 96-103
Off-line CPU(s) list: 0-95,104-191
Vendor ID: ARM
Model name: Neoverse-V2
NUMA:
NUMA node(s): 2
NUMA node0 CPU(s):
NUMA node1 CPU(s): 96-103
Restart Tomcat on the Arm Neoverse bare‑metal instance:
~/apache-tomcat-11.0.10/bin/shutdown.sh 2>/dev/null
ulimit -n 65535 && ~/apache-tomcat-11.0.10/bin/startup.sh
Run wrk2 on the x86_64 bare‑metal client to measure throughput and latency:
ulimit -n 65535 && wrk -c1280 -t128 -R500000 -d60 http://${tomcat_ip}:8080/examples/servlets/servlet/HelloWorldExample
Sample results after placing Tomcat on the NIC’s local NUMA node:
Thread Stats Avg Stdev Max +/- Stdev
Latency 9.41s 4.71s 18.02s 61.07%
Req/Sec 2.84k 76.55 3.06k 72.37%
21814220 requests in 1.00m, 11.32GB read
Requests/sec: 363744.39
Transfer/sec: 193.22MB
