After establishing a baseline, you can further improve throughput and latency by tuning your network interface controller (NIC) queue count. Many bare‑metal NICs expose a relatively large number of transmit/receive queues (multi‑queue). Each queue maps to an interrupt; when you limit the server to a small number of online CPUs (for example, 8 cores), too many interrupts can land on the same core and increase context switching. Reducing the number of queues to match available CPUs can stabilize performance on Arm Neoverse systems.
Use the following command to find the NIC name corresponding to the IP address:
ip addr
From the output you can see that the NIC name enp1s0f0np0 corresponds to the IP address 10.169.226.181:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enP11p4s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9001 qdisc mq state UP group default qlen 1000
link/ether 0e:cc:0b:ff:f6:57 brd ff:ff:ff:ff:ff:ff
inet 172.31.46.193/20 metric 100 brd 172.31.47.255 scope global dynamic enP11p4s0
valid_lft 1938sec preferred_lft 1938sec
inet6 fe80::ccc:bff:feff:f657/64 scope link
Set the network interface name variable:
net=enp1s0f0np0
Use the following command to check the current transmit/receive queues of the ${net} network interface:
sudo ethtool -l ${net}
You can see that the number of transmit/receive queues for the ${net} network interface is currently 63:
Channel parameters for enP11p4s0:
Pre-set maximums:
RX: n/a
TX: n/a
Other: n/a
Combined: 32
Current hardware settings:
RX: n/a
TX: n/a
Other: n/a
Combined: 32
Set the number of combined queues to match your online CPUs (example: 8):
sudo ethtool -L ${NET_IFACE} combined 8
Verify the change:
sudo ethtool -l ${NET_IFACE}
You should see the Combined value updated to 8 under Current hardware settings:
Pre-set maximums:
RX: n/a
TX: n/a
Other: n/a
Combined: 32
RX: n/a
TX: n/a
Other: n/a
Combined: 8
Queue settings applied with ethtool -L are not persistent across reboots. If needed, make the change persistent using a systemd unit or your distro’s NIC configuration mechanism.
Restart Tomcat on your Arm Neoverse bare‑metal instance:
~/apache-tomcat-11.0.10/bin/shutdown.sh 2>/dev/null
ulimit -n 65535 && ~/apache-tomcat-11.0.10/bin/startup.sh
Run wrk2 from your x86_64 bare‑metal client (replace ${tomcat_ip} with your server IP):
ulimit -n 65535 && wrk -c1280 -t128 -R500000 -d60 http://${tomcat_ip}:8080/examples/servlets/servlet/HelloWorldExample
Example results after tuning NIC queues:
Thread Stats Avg Stdev Max +/- Stdev
Latency 8.35s 4.14s 16.33s 61.16%
Req/Sec 2.96k 73.02 3.24k 89.16%
22712999 requests in 1.00m, 11.78GB read
Requests/sec: 378782.37
Transfer/sec: 201.21MB
If performance improves and latency stabilizes, keep the adjusted queue count for subsequent tuning steps (RSS/RPS/XPS, IRQ affinity, and NUMA locality).
