Overview
In this section, you’ll build a multi-architecture container image and perform vulnerability scanning using Trivy on an Azure Cobalt 100 Arm64 Ubuntu VM.
You will:
  • Configure Docker Buildx for multi-architecture builds
  • Create a demo container application
  • Push a multi-architecture image to Docker Hub
  • Install and verify Trivy on your Arm64 VM
  • Perform local vulnerability scanning
  • Generate vulnerability reports
Prerequisites
Before starting, ensure you have:
  • An Azure Cobalt 100 Arm64 Ubuntu VM running
  • Docker installed and configured on your VM
  • A Docker Hub account
To install Docker on your Arm64 VM, follow the Docker installation guide .
Once Docker is installed, verify it’s running:
docker --version
uname -m
You should see Docker version information and aarch64 architecture output.
Install Docker on Arm64 VM
Update your system and install required tools for Docker installation.
sudo apt update
sudo apt install -y ca-certificates curl gnupg lsb-release
Add Docker GPG key
Add Docker’s official signing key so packages are trusted.
sudo mkdir -p /etc/apt/keyrings
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
Add repository
Register Docker’s package source for Arm64 Ubuntu.
echo "deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/ubuntu \
$(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
Install Docker
Install Docker Engine and Buildx for multi-architecture builds.
sudo apt update
sudo apt install -y docker-ce docker-ce-cli containerd.io docker-buildx-plugin
Enable Docker without sudo
sudo usermod -aG docker $USER
newgrp docker
Adds the user to the docker group and applies the new group permissions immediately, enabling non-root access to Docker.
Confirm Docker is running natively on Arm64.
docker info | grep Architecture
You should see a result similar to:
        Architecture: aarch64
Create builder:
Create a special Docker builder capable of building images for multiple CPU architectures.
docker buildx create --name multiarch-builder --use
Initialize
Prepare the builder to support multi-platform builds.
docker buildx inspect --bootstrap
The first command creates a builder instance capable of cross-platform builds. The second command initializes it to support multiple platforms.
Create a demo application
Set up a workspace for your demo container:
mkdir $HOME/trivy-multiarch-demo
cd $HOME/trivy-multiarch-demo
Create a Dockerfile:
FROM nginx:latest
COPY index.html /usr/share/nginx/html/index.html
Create an index.html file:
<h1>Multi-Architecture NGINX on Azure Cobalt Arm64</h1>
Authenticate with Docker Hub
Run the Docker login command to authenticate:
docker login
Docker displays a one-time device code and a login URL:
https://login.docker.com/activate
Steps to complete login:
  • Open the displayed URL in your web browser
  • Enter the one-time confirmation code shown in the terminal
  • Click Confirm / Activate
Once authentication completes, the terminal will show:
        WARNING! Your credentials are stored unencrypted in '/home/azureuser/.docker/config.json'.
Configure a credential helper to remove this warning. See
https://docs.docker.com/go/credential-store/
Login Succeeded
This confirms your system is now authenticated with Docker Hub and ready to push or pull container images.
Next, run the docker login again:
docker login
Note the “Username” that is presented and save it, as you’ll use it in the next step (as DOCKER_USERNAME below).
Finally, create a personal access token in Docker Hub. Log into Docker Hub with your Docker username and password, then select “Account Settings” -> “Personal Access Token” to create a token. Select “Read-Only” privileges and copy and save the token, as it will become your “DOCKER_PASSWORD” in future steps.
Build and push multi-architecture images
Build your image for both amd64 and arm64 architectures. Replace <DOCKER_USERNAME> with your Docker username:
docker buildx build \
  --platform linux/amd64,linux/arm64 \
  -t <DOCKER_USERNAME>/trivy-multiarch-nginx:latest \
  --push .
This command builds the container for both architectures and pushes the multi-architecture image directly to Docker Hub. The same image specification can now run on both x86 and Arm systems.
Download the Arm64-compatible Trivy scanner:
cd $HOME
wget https://github.com/aquasecurity/trivy/releases/download/v0.68.1/trivy_0.68.1_Linux-ARM64.deb
Note
The Arm Ecosystem Dashboard recommends Trivy 0.29.0 or later for Arm platforms.
Install Trivy on your system:
sudo dpkg -i trivy_0.68.1_Linux-ARM64.deb
Verify the installation:
trivy version
You should see version information displayed.
Scan your Docker Hub image (replace <DOCKER_USERNAME> with your username):
trivy image <DOCKER_USERNAME>/trivy-multiarch-nginx:latest
Trivy analyzes the container layers and reports all detected vulnerabilities with severity levels (LOW, MEDIUM, HIGH, CRITICAL).
Generate a JSON vulnerability report
Create a machine-readable report for audits and CI pipelines:
trivy image \
  --format json \
  -o trivy-report.json \
Create a machine-readable vulnerability report for audits and CI pipelines.
        2026-01-23T06:42:30Z    INFO    [vuln] Vulnerability scanning is enabled
2026-01-23T06:42:30Z    INFO    [secret] Secret scanning is enabled
2026-01-23T06:42:30Z    INFO    [secret] If your scanning is slow, please try '--scanners vuln' to disable secret scanning
2026-01-23T06:42:30Z    INFO    [secret] Please see https://trivy.dev/docs/v0.68/guide/scanner/secret#recommendation for faster secret detection
2026-01-23T06:42:32Z    INFO    Detected OS     family="debian" version="12.5"
2026-01-23T06:42:32Z    INFO    [debian] Detecting vulnerabilities...   os_version="12" pkg_num=149
2026-01-23T06:42:33Z    INFO    Number of language-specific files       num=0
2026-01-23T06:42:33Z    WARN    Using severities from other vendors for some vulnerabilities. Read https://trivy.dev/docs/v0.68/guide/scanner/vulnerability#severity-selection for details.
In this section, you:
  • Built and pushed a multi-architecture container image to Docker Hub
  • Installed Trivy on your Arm64 VM
  • Scanned your container image for vulnerabilities
  • Generated a JSON vulnerability report for analysis
You now have a working local security scanning setup. Next, you’ll integrate Trivy into a GitHub Actions CI/CD pipeline to automate security scanning on every code push.
