# Introduction to the PMU
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/triggering-pmu-events/)
- [Introduction to the PMU](https://learn.arm.com/learning-paths/servers-and-cloud-computing/triggering-pmu-events/intro/)
- [L1 Data Cache Events](https://learn.arm.com/learning-paths/servers-and-cloud-computing/triggering-pmu-events/dcache/)
- [L1 Instruction Cache Events](https://learn.arm.com/learning-paths/servers-and-cloud-computing/triggering-pmu-events/icache/)
- [L2 Unified Cache Events](https://learn.arm.com/learning-paths/servers-and-cloud-computing/triggering-pmu-events/l2cache/)
- [LL Cache Events](https://learn.arm.com/learning-paths/servers-and-cloud-computing/triggering-pmu-events/llcache/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/triggering-pmu-events/_next-steps/)
## Neoverse Core PMU
The Neoverse core PMU measures hardware events that occur during software execution.
PMU events:
- Measure performance.
- Monitor workload efficiency.
- Track resource utilization and requirements.
The [Arm Neoverse N2 PMU guide](https://developer.arm.com/documentation/PJDOC-466751330-590448/2-0/?lang=en) describes the architecture and PMU event definitions. You can find other Neoverse core PMU guides on [Arm's website](https://developer.arm.com/).
This Learning Path explains how to trigger common PMU events in specific metric groups and explains why certain events are triggered. You can review example code fragments and see the resultant triggered PMU events.
## PMU Events
This Learning Path uses the Neoverse N2 core to count PMU events; however, the code and analysis of events can also be applied to other Neoverse cores. Check your Neoverse core’s Technical Reference Manual to ensure compatibility.
The Neoverse N2 has six counters that can be programmed to count any PMU event supported by the CPU. Some common microarchitectural events that might be tracked are cache or TLB accesses, and executed instructions.
This Learning Path covers cache events, specifically:
- Level 1 Data Cache Events.
- Level 1 Instruction Cache Events.
- Level 2 Unified Cache Events.
- Last Level Cache Events.
