Train MAPPO navigation policies on an Arm cloud instance
Prepare the Arm cloud environment
Configure and train MAPPO
Locate and validate the training checkpoint
(Optional) Deploy the checkpoint to a cloud GUI
Export the MAPPO actor for inference
Use three agents by exporting
AGENTS=3 before configuring the run. With share_policy_params=true, the three agents share one actor while receiving different observations.Activate the training environment, set
RUN_DIR to the run directory that you want to validate, and source "$RUN_DIR/run.env". Then, change to the BenchMARL repository to continue validation.Export
SAMPLING_DEVICE=cpu and TRAIN_DEVICE=cpu before you launch the experiment. BenchMARL configures sampling and training devices independently, and saves these choices in your run environment.Your export contains only the actor policy, without the critic, replay buffer, collector state, or training counters. For VMAS navigation, you’ll get an MLP with 18 inputs, two 256-unit
Tanh layers, and four outputs for a two-dimensional action.No. You can validate the checkpoint and export the actor without the GUI. Use the GUI only when you have the companion checkout described in the prerequisites. Otherwise, skip that stage and continue with exporting the actor.
