Understand the actor-only artifact
The full BenchMARL checkpoint contains the actor together with state used for training and experiment reload, such as the critic, replay buffer, collector state, and training counters.
A downstream inference runtime normally needs only the actor policy.
For the VMAS navigation configuration, the shared actor has the following structure:
18 observation values
Linear 18 → 256
      Tanh
Linear 256 → 256
      Tanh
Linear 256 → 4
For continuous MAPPO, the four raw outputs are split into two location values and two scale values for a two-dimensional action distribution. The validated configuration uses TanhNormal. VMAS navigation uses the default action range [-1, 1]. For deterministic inference, TorchRL’s TanhNormal.deterministic_sample therefore corresponds to applying tanh() to the two location values.
The 18-value VMAS navigation observation is as follows:
2 agent-position values
2 agent-velocity values
2 agent-minus-goal position values
12 LiDAR proximity values
VMAS constructs each LiDAR proximity value as:
lidar_range - measured_range
Note
The exporter is intentionally specific to the validated shared MAPPO actor. It verifies the task configuration, parameter sharing, and MLP layer sizes. It also verifies the activation type, absence of normalization layers, and actor tensor shapes before it creates an artifact.
The tested BenchMARL task configuration doesn’t store the VMAS LiDAR-ray default, so the exporter uses 12 when that field is absent and verifies the resulting 18-input actor shape.
Create the actor exporter
Move to the BenchMARL directory:
source $HOME/venvs/mappo/bin/activate
export RUN_DIR=$HOME/mappo_navigation_runs/latest
source "$RUN_DIR/run.env"
cd $HOME/BenchMARL
This restores the original checkpoint path and activates the packages used to create it. If you copied the experiment to another system, update CHECKPOINT before you run the exporter.
Create export_mappo_actor.py with the following code:
#!/usr/bin/env python3
import argparse
import hashlib
import json
import pickle
from pathlib import Path
import numpy as np
import torch
import torch.nn.functional as F
from tensordict.nn.distributions import NormalParamExtractor
from torchrl.modules import TanhNormal
def sha256_file(path: Path) -> str:
    digest = hashlib.sha256()
    with path.open("rb") as file:
        for chunk in iter(lambda: file.read(1024 * 1024), b""):
            digest.update(chunk)
    return digest.hexdigest()
def cfg_get(cfg, key, default=None):
    """Read a setting from a dict-like or attribute-based config object."""
    if isinstance(cfg, dict):
        return cfg.get(key, default)
    getter = getattr(cfg, "get", None)
    if callable(getter):
        try:
            return getter(key, default)
        except (TypeError, AttributeError):
            pass
    return getattr(cfg, key, default)
def class_name(value) -> str:
    if isinstance(value, type):
        return f"{value.__module__}.{value.__qualname__}"
    return str(value)
def find_actor_loss_group(state):
    matches = []
    for key, value in state.items():
        if not isinstance(key, str) or not key.startswith("loss_"):
            continue
        if not hasattr(value, "items"):
            continue
        if any(
            isinstance(item_key, str) and "actor_network_params" in item_key
            for item_key in value.keys()
            matches.append((key, value))
    if len(matches) != 1:
        raise RuntimeError(
            "Expected exactly one loss group containing actor_network_params; "
            f"found {[name for name, _ in matches]}"
    return matches[0]
def find_actor_tensor(actor_state, suffix):
    matches = [
        value
        for key, value in actor_state.items()
        if isinstance(key, str)
        and "actor_network_params" in key
        and key.endswith(suffix)
        and torch.is_tensor(value)
        raise RuntimeError(
            f"Expected one actor tensor ending in {suffix}; found {len(matches)}"
    return matches[0].detach().cpu().to(torch.float32).contiguous()
def fail_if(condition, message):
    if condition:
        raise SystemExit(message)
def validate_numpy_export(output, torch_weights, scale_mapping):
    """Validate tensor serialization and deterministic TanhNormal semantics."""
    generator = torch.Generator(device="cpu").manual_seed(1234)
    observations = torch.randn((16, 18), generator=generator, dtype=torch.float32)
    W1_t, b1_t, W2_t, b2_t, W3_t, b3_t = torch_weights
    with torch.no_grad():
        hidden1 = torch.tanh(F.linear(observations, W1_t, b1_t))
        hidden2 = torch.tanh(F.linear(hidden1, W2_t, b2_t))
        raw_torch = F.linear(hidden2, W3_t, b3_t)
    with np.load(output, allow_pickle=False) as exported:
        obs_np = observations.numpy()
        hidden1_np = np.tanh(obs_np @ exported["W1"].T + exported["b1"])
        hidden2_np = np.tanh(hidden1_np @ exported["W2"].T + exported["b2"])
        raw_numpy = hidden2_np @ exported["W3"].T + exported["b3"]
    max_raw_error = float(np.max(np.abs(raw_numpy - raw_torch.numpy())))
    if not np.allclose(raw_numpy, raw_torch.numpy(), rtol=1e-5, atol=1e-6):
        raise RuntimeError(
            "Exported NumPy actor does not match the checkpoint actor MLP. "
            f"Maximum raw-output error: {max_raw_error}"
    extractor = NormalParamExtractor(scale_mapping=scale_mapping)
        loc, scale = extractor(raw_torch)
        distribution = TanhNormal(loc, scale, low=-1.0, high=1.0)
        torchrl_action = distribution.deterministic_sample
        lightweight_action = torch.tanh(raw_torch[..., :2])
    max_action_error = float(
        torch.max(torch.abs(torchrl_action - lightweight_action)).item()
    if not torch.allclose(
        torchrl_action, lightweight_action, rtol=1e-5, atol=1e-6
        raise RuntimeError(
            "tanh(loc) does not match TorchRL TanhNormal deterministic_sample. "
            f"Maximum action error: {max_action_error}"
    return max_raw_error, max_action_error
def main():
    parser = argparse.ArgumentParser(
        description=(
            "Export the validated shared BenchMARL MAPPO VMAS-navigation actor "
            "to a lightweight NumPy .npz artifact."
    parser.add_argument("--checkpoint", required=True)
    parser.add_argument("--output", help="Exact .npz output path")
        "--output-dir",
        default=str(Path.home() / "mappo_actor_exports"),
        help="Output directory used when --output is omitted",
    args = parser.parse_args()
    checkpoint = Path(args.checkpoint).expanduser().resolve()
    requested_output = (
        Path(args.output).expanduser().resolve() if args.output else None
    output_dir = Path(args.output_dir).expanduser().resolve()
    fail_if(not checkpoint.is_file(), f"Checkpoint not found: {checkpoint}")
    experiment_dir = checkpoint.parent.parent
    config_file = experiment_dir / "config.pkl"
    fail_if(not config_file.is_file(), f"config.pkl not found: {config_file}")
    # config.pkl is a trusted BenchMARL artifact from the matching training run.
    with config_file.open("rb") as file:
        _task = pickle.load(file)
        task_config = pickle.load(file)
        algorithm_config = pickle.load(file)
        model_config = pickle.load(file)
        _seed = pickle.load(file)
        experiment_config = pickle.load(file)
    n_agents_value = cfg_get(task_config, "n_agents")
    fail_if(n_agents_value is None, "Task configuration does not contain n_agents")
    n_agents = int(n_agents_value)
    collisions = bool(cfg_get(task_config, "collisions", True))
    observe_all_goals = bool(cfg_get(task_config, "observe_all_goals", False))
    n_lidar_rays = int(cfg_get(task_config, "n_lidar_rays", 12))
    fail_if(not collisions, "This exporter expects navigation collisions=true")
    fail_if(
        observe_all_goals,
        "This exporter expects observe_all_goals=false; the observation layout would differ",
    fail_if(
        n_lidar_rays != 12,
        f"This exporter expects 12 LiDAR rays; found {n_lidar_rays}",
    fail_if(
        not bool(getattr(experiment_config, "share_policy_params", False)),
        "This exporter expects share_policy_params=true",
    fail_if(
        not bool(getattr(algorithm_config, "use_tanh_normal", False)),
        "This exporter expects MAPPO use_tanh_normal=true",
    scale_mapping = str(
        getattr(algorithm_config, "scale_mapping", "biased_softplus_1.0")
    num_cells = list(getattr(model_config, "num_cells", []))
    activation_class = getattr(model_config, "activation_class", None)
    layer_class = getattr(model_config, "layer_class", None)
    norm_class = getattr(model_config, "norm_class", None)
    fail_if(
        num_cells != [256, 256],
        f"This exporter expects hidden layers [256, 256]; found {num_cells}",
    fail_if(
        class_name(activation_class) != "torch.nn.modules.activation.Tanh",
        "This exporter expects torch.nn.Tanh hidden activations; "
        f"found {class_name(activation_class)}",
    fail_if(
        class_name(layer_class) != "torch.nn.modules.linear.Linear",
        "This exporter expects torch.nn.Linear layers; "
        f"found {class_name(layer_class)}",
    fail_if(
        norm_class is not None,
        "This exporter expects no normalization layer in the actor MLP",
    state = torch.load(checkpoint, map_location="cpu", weights_only=True)
    loss_group_name, actor_state = find_actor_loss_group(state)
    W1_t = find_actor_tensor(actor_state, "mlp.params.0.weight")
    b1_t = find_actor_tensor(actor_state, "mlp.params.0.bias")
    W2_t = find_actor_tensor(actor_state, "mlp.params.2.weight")
    b2_t = find_actor_tensor(actor_state, "mlp.params.2.bias")
    W3_t = find_actor_tensor(actor_state, "mlp.params.4.weight")
    b3_t = find_actor_tensor(actor_state, "mlp.params.4.bias")
    expected_shapes = {
        "W1": (256, 18),
        "b1": (256,),
        "W2": (256, 256),
        "b2": (256,),
        "W3": (4, 256),
        "b3": (4,),
    torch_tensors = {
        "W1": W1_t,
        "b1": b1_t,
        "W2": W2_t,
        "b2": b2_t,
        "W3": W3_t,
        "b3": b3_t,
    actual_shapes = {name: tuple(value.shape) for name, value in torch_tensors.items()}
    fail_if(
        actual_shapes != expected_shapes,
        "Unexpected actor architecture. "
        f"Expected {expected_shapes}, found {actual_shapes}",
    training_frames = int(state.get("state", {}).get("total_frames", 0))
    agent_group = loss_group_name.removeprefix("loss_")
    output = (
        requested_output
        if requested_output is not None
        else output_dir / f"mappo_actor_{n_agents}agent_{training_frames}.npz"
    fail_if(output.suffix != ".npz", "Actor output file must use the .npz suffix")
    lidar_range = cfg_get(task_config, "lidar_range", 0.35)
    agent_radius = cfg_get(task_config, "agent_radius", 0.1)
    max_steps = cfg_get(task_config, "max_steps")
    metadata = {
        "format": "mappo_shared_actor_numpy_v2",
        "source_checkpoint_name": checkpoint.name,
        "source_checkpoint_path": str(checkpoint),
        "source_checkpoint_sha256": sha256_file(checkpoint),
        "source_config_path": str(config_file),
        "training_frames": training_frames,
        "training_n_agents": n_agents,
        "agent_group": agent_group,
        "share_policy_params": True,
        "actor_input_dim": 18,
        "actor_hidden_dims": [256, 256],
        "actor_raw_output_dim": 4,
        "deterministic_action_dim": 2,
        "activation": "tanh",
        "policy_distribution": "TanhNormal",
        "normal_scale_mapping": scale_mapping,
        "action_bounds": [-1.0, 1.0],
        "deterministic_action": "TanhNormal.deterministic_sample == tanh(loc)",
        "observation_layout": [
            "x_vmas",
            "y_vmas",
            "vx_vmas",
            "vy_vmas",
            "agent_x_minus_goal_x_vmas",
            "agent_y_minus_goal_y_vmas",
            "lidar_proximity_0",
            "lidar_proximity_1",
            "lidar_proximity_2",
            "lidar_proximity_3",
            "lidar_proximity_4",
            "lidar_proximity_5",
            "lidar_proximity_6",
            "lidar_proximity_7",
            "lidar_proximity_8",
            "lidar_proximity_9",
            "lidar_proximity_10",
            "lidar_proximity_11",
        "lidar_encoding": "lidar_range_vmas - measured_range_vmas",
        "training_n_lidar_rays": n_lidar_rays,
        "training_lidar_range_vmas": lidar_range,
        "training_agent_radius_vmas": agent_radius,
        "training_max_steps": max_steps,
        "training_collisions": collisions,
        "training_observe_all_goals": observe_all_goals,
    output.parent.mkdir(parents=True, exist_ok=True)
    np.savez_compressed(
        output,
        W1=W1_t.numpy(),
        b1=b1_t.numpy(),
        W2=W2_t.numpy(),
        b2=b2_t.numpy(),
        W3=W3_t.numpy(),
        b3=b3_t.numpy(),
        metadata_json=np.array(json.dumps(metadata)),
    max_raw_error, max_action_error = validate_numpy_export(
        output,
        (W1_t, b1_t, W2_t, b2_t, W3_t, b3_t),
        scale_mapping,
    print(f"Actor export:              {output}")
    print(f"Agents:                    {n_agents}")
    print(f"Frames:                    {training_frames}")
    print(f"Actor group:               {agent_group}")
    print(f"Input:                     {W1_t.shape[1]}")
    print(f"Hidden:                    {W1_t.shape[0]}, {W2_t.shape[0]}")
    print(f"Raw output:                {W3_t.shape[0]}")
    print("Deterministic action:      2-D TanhNormal deterministic_sample")
    print(f"NumPy raw parity max err:  {max_raw_error:.3e}")
    print(f"Action parity max err:     {max_action_error:.3e}")
    print("Validation:                PASS")
if __name__ == "__main__":
    main()
Important
config.pkl uses Python pickle serialization. Run the exporter only on config.pkl and checkpoint files produced by training runs that you trust.
Make the exporter executable:
chmod +x export_mappo_actor.py
Export the actor
Make sure CHECKPOINT still points to the BenchMARL training checkpoint that you selected earlier:
echo "$CHECKPOINT"
The path should point to the original BenchMARL checkpoint layout:
<experiment-directory>/
├── config.pkl
└── checkpoints/
    └── checkpoint_<frames>.pt
Create the actor output directory:
export ACTOR_EXPORT_DIR=$HOME/mappo_actor_exports
mkdir -p "$ACTOR_EXPORT_DIR"
Run the exporter:
python export_mappo_actor.py --checkpoint "$CHECKPOINT" --output-dir "$ACTOR_EXPORT_DIR"
The exporter reads the agent count and training-frame count from the trusted training artifacts and creates a file with the form:
$HOME/mappo_actor_exports/mappo_actor_<agents>agent_<frames>.npz
For example, a three-agent policy trained for 1,910,000 frames produces:
$HOME/mappo_actor_exports/mappo_actor_3agent_1910000.npz
A successful export ends with output similar to:
        Actor export:              /home/ubuntu/mappo_actor_exports/mappo_actor_3agent_1910000.npz
Agents:                    3
Frames:                    1910000
Actor group:               agents
Input:                     18
Hidden:                    256, 256
Raw output:                4
NumPy raw parity max err:  <small value>
Action parity max err:     <small value>
Validation:                PASS
The .npz artifact contains only the actor tensors and metadata:
W1    (256, 18)
b1    (256,)
W2    (256, 256)
b2    (256,)
W3    (4, 256)
b3    (4,)
metadata_json
The critic and the remaining BenchMARL training state aren’t included.
Understand the exporter validation
The exporter performs several checks before and after writing the .npz file.
It verifies that the training configuration includes the following:
share_policy_params = true
use_tanh_normal = true
collisions = true
observe_all_goals = false
12 LiDAR rays
MLP hidden layers = [256, 256]
hidden activation = torch.nn.Tanh
It also checks that the checkpoint contains exactly one actor parameter group with the following tensor shapes:
mlp.params.0.weight  -> (256, 18)
mlp.params.0.bias    -> (256,)
mlp.params.2.weight  -> (256, 256)
mlp.params.2.bias    -> (256,)
mlp.params.4.weight  -> (4, 256)
mlp.params.4.bias    -> (4,)
After saving the actor, the exporter performs two numerical parity checks:
  1. It runs the same test observations through the checkpoint tensors in PyTorch and through the saved NumPy actor, and checks that their raw outputs match.
  2. It passes the raw outputs through the same NormalParamExtractor and TanhNormal deterministic-action semantics used by the MAPPO policy. It checks that the lightweight tanh(loc) action matches TanhNormal.deterministic_sample for the [-1, 1] VMAS action range.
These checks validate both the weight extraction and the deterministic action interpretation used by the lightweight actor.
Inspect the exported artifact
Set the actor path using the most recently created export:
export ACTOR_OUTPUT=$(find "$ACTOR_EXPORT_DIR" -maxdepth 1 -type f -name 'mappo_actor_*agent_*.npz' -printf '%T@ %p
' | sort -nr | head -1 | cut -d' ' -f2-)
Display the path:
echo "$ACTOR_OUTPUT"
Inspect the tensors:
python -c "import numpy as np; d=np.load('$ACTOR_OUTPUT', allow_pickle=False); [print(k, d[k].shape, d[k].dtype) for k in d.files]"
Inspect the embedded metadata:
python -c "import numpy as np, json; d=np.load('$ACTOR_OUTPUT', allow_pickle=False); print(json.dumps(json.loads(str(d['metadata_json'])), indent=2))"
The metadata records settings needed to identify the policy interface, including:
  • The source checkpoint name and full path
  • SHA-256 checksum
  • Training frames
  • Training agent count
  • Model dimensions
  • Action interpretation
  • Observation ordering
  • LiDAR configuration
Run a standalone inference check
You can also run the exported MLP without BenchMARL or TorchRL. Use an all-zero 18-value observation as a smoke test:
python -c "import numpy as np; d=np.load('$ACTOR_OUTPUT', allow_pickle=False); obs=np.zeros(18,dtype=np.float32); x=np.tanh(d['W1']@obs+d['b1']); x=np.tanh(d['W2']@x+d['b2']); raw=d['W3']@x+d['b3']; action=np.tanh(raw[:2]); print('Action:',action); print('Shape:',action.shape); print('Finite:',np.all(np.isfinite(action))); print('Within [-1,1]:',np.all(np.abs(action)<=1.0))"
A successful check includes:
        Shape: (2,)
Finite: True
Within [-1,1]: True
This is an interface smoke test. It checks tensor shapes, finite arithmetic, and action bounds, but it doesn’t show that the policy navigates successfully. Use the BenchMARL evaluation and GUI playback checks for behavioral validation.
You now have two forms of the trained policy:
Full BenchMARL experiment
checkpoint_<frames>.pt + config.pkl
Cloud MARL GUI
Actor-only policy
Downstream inference runtime
The downstream runtime must reproduce the observation ordering and action interpretation recorded in metadata_json. The actor-only artifact doesn’t contain the VMAS environment, critic, or robot-specific sensor and control integration.
What you’ve accomplished
You’ve extracted the validated shared MAPPO actor into a portable NumPy artifact and confirmed that its deterministic output matches the trained TorchRL policy.
You can now use the observation layout and action semantics that you recorded to integrate the actor with a downstream runtime.
