Understand the GUI dependency
The MARL GUI used in this stage is a separate application from BenchMARL and VMAS. It’s not created automatically when you run the training workflow.
The GUI source and helper scripts aren’t included in the Arm Learning Paths repository. Treat this stage as optional unless you have the companion checkout described in the prerequisites . Checkpoint validation and actor export don’t depend on the GUI.
If you already have the companion GUI code, use that checkout and continue with the steps.
If you don’t have the GUI code, you can either skip this stage and continue to the actor-export section , or create an equivalent visualization application. A compatible GUI should be able to:
  • Accept a BenchMARL checkpoint_<frames>.pt file and its associated config.pkl
  • Reload the trained experiment with BenchMARL
  • Run a single VMAS environment for interactive evaluation
  • Render agent positions, goals, and episode state
  • Register and select trained checkpoints
  • Preserve the BenchMARL directory layout required by Experiment.reload_from_file()
The required portable model structure is:
<model-directory>/
├── config.pkl
└── checkpoints/
    └── checkpoint_<frames>.pt
The companion GUI also provides the following utilities:
tools/deploy_checkpoint.py
tools/inspect_checkpoint.py
deploy_checkpoint.py copies the trained checkpoint and its configuration into the GUI model store and registers the model. inspect_checkpoint.py verifies that BenchMARL can reload the checkpoint successfully.
The remaining commands assume that the companion GUI is available locally. If you create your own GUI, replace the paths and helper-script names with the corresponding paths in your implementation.
Prepare the GUI environment
The GUI reloads the full BenchMARL experiment, so use the same Python environment that you used for training:
source $HOME/venvs/mappo/bin/activate
export RUN_DIR=$HOME/mappo_navigation_runs/latest
source "$RUN_DIR/run.env"
Sourcing run.env restores CHECKPOINT, SOURCE_EXPERIMENT_DIR, the agent count, and the device labels that you saved earlier.
Set the GUI root to your local checkout:
export GUI_ROOT=$HOME/rl_marl_vmassmapponav_demo/app/marl_live_demo_gui
Verify that the deployment and inspection tools are available:
test -f "$GUI_ROOT/tools/deploy_checkpoint.py" && echo "Deployment tool found"
test -f "$GUI_ROOT/tools/inspect_checkpoint.py" && echo "Inspection tool found"
Install the GUI requirements into the active MAPPO environment:
python -m pip install -r "$GUI_ROOT/requirements.txt"
Move training artifacts when the GUI is on another system
The GUI import requires both of the following training artifacts:
$SOURCE_EXPERIMENT_DIR/config.pkl
$SOURCE_EXPERIMENT_DIR/checkpoints/checkpoint_<frames>.pt
If training and the GUI run on different systems, copy the complete experiment directory to the GUI system and preserve this layout. After the copy, update CHECKPOINT and SOURCE_EXPERIMENT_DIR to the paths on the GUI system.
If the GUI runs on the same system as training, keep the existing paths.
Validate the source checkpoint
Move to the GUI directory:
cd "$GUI_ROOT"
Inspect the source checkpoint:
python tools/inspect_checkpoint.py "$CHECKPOINT" --device cpu
The expected output is:
        "reload": "success"
If the tool reports config.pkl file not found in experiment folder, restore the BenchMARL directory layout before continuing.
Register the checkpoint
The GUI deployment tool is part of the GUI checkout. Run it from its existing path:
python "$GUI_ROOT/tools/deploy_checkpoint.py" --checkpoint "$CHECKPOINT" --gui-root "$GUI_ROOT" --instance-label "$(hostname)" --sampling-device "$SAMPLING_DEVICE" --train-device "$TRAIN_DEVICE"
The deployment tool performs the following tasks:
  1. Locates config.pkl relative to the source checkpoint.
  2. Reads n_agents from the trained task configuration.
  3. Copies the checkpoint and configuration to the GUI model store.
  4. Preserves the checkpoints/checkpoint_<frames>.pt layout required by BenchMARL.
  5. Creates model metadata.
  6. Adds the training instance, agent count, run configuration, and checkpoint to configs/models.yaml.
The deployed model has the following structure:
$GUI_ROOT/model_assets/models/<model-id>/
├── config.pkl
├── checkpoints/
│   └── checkpoint_<frames>.pt
├── model_metadata.json
└── source_path.txt
The instance metadata is required because the GUI first filters models by training instance and then builds the available agent-count selections.
Verify the GUI model
Extract the checkpoint step:
export CHECKPOINT_STEP=$(basename "$CHECKPOINT" | sed 's/checkpoint_//;s/.pt//')
Construct the model ID generated by the deployment tool:
export MODEL_ID="$(hostname)_agents$(printf '%03d' "$CHECKPOINT_AGENTS")_sampling_${SAMPLING_DEVICE}_train_${TRAIN_DEVICE}_ckpt${CHECKPOINT_STEP}"
Set the deployed model paths:
export GUI_MODEL_DIR="$GUI_ROOT/model_assets/models/$MODEL_ID"
export GUI_CHECKPOINT="$GUI_MODEL_DIR/checkpoints/$(basename "$CHECKPOINT")"
Verify the artifacts:
ls -lh "$GUI_MODEL_DIR/config.pkl" "$GUI_CHECKPOINT" "$GUI_MODEL_DIR/model_metadata.json"
Verify the registry metadata:
python -c "import yaml; d=yaml.safe_load(open('$GUI_ROOT/configs/models.yaml')); m=next(x for x in d['models'] if x['id']=='$MODEL_ID'); print('kind=',m.get('kind')); print('instance=',m['metadata'].get('instance')); print('agents=',m['metadata'].get('agent_count')); print('run=',m['metadata'].get('run_name')); print('asset=',m['checkpoint'].get('asset_path'))"
A valid entry is similar to:
        kind= benchmarl_checkpoint
instance= <hostname>
agents= 3
run= sampling_cpu_train_cpu
asset= model_assets/models/<model-id>/checkpoints/checkpoint_<frames>.pt
Validate the deployed checkpoint:
python tools/inspect_checkpoint.py "$GUI_CHECKPOINT" --device cpu
Confirm that the output again contains the following:
        "reload": "success"
Start the GUI
Start the application on the cloud instance. Bind it to the loopback interface so it’s not exposed directly through the instance network:
cd "$GUI_ROOT"
./run_demo.sh --host 127.0.0.1 --port 8045
From your local workstation, open an SSH tunnel to the instance:
ssh -L 8045:127.0.0.1:8045 ubuntu@INSTANCE_PUBLIC_IP
Keep the SSH connection open and visit http://127.0.0.1:8045 in your local browser. Replace ubuntu and INSTANCE_PUBLIC_IP with the SSH user and address for your instance.
Important
The SSH tunnel avoids opening TCP port 8045 to the internet. If you intentionally bind the GUI to 0.0.0.0, restrict the cloud firewall or security-group rule to a trusted source address and confirm that the GUI’s authentication is suitable for your environment.
Refresh the browser after registration. Select the model in the following order:
Training instance
Agent count
Run configuration
Checkpoint
Select Start to run interactive VMAS playback with the trained MAPPO policy.
Note
The GUI uses a single VMAS environment for interactive playback, independent of the number of vectorized environments used during training.
Know which artifacts the GUI uses
The following table describes the artifacts that the GUI uses:
ArtifactLocationPurpose
Training checkpoint$CHECKPOINTComplete BenchMARL training state
Training configuration$SOURCE_EXPERIMENT_DIR/config.pklReconstructs the experiment
GUI checkpoint$GUI_MODEL_DIR/checkpoints/checkpoint_<frames>.ptPortable checkpoint used by the GUI
GUI configuration$GUI_MODEL_DIR/config.pklRequired for BenchMARL reload
GUI metadata$GUI_MODEL_DIR/model_metadata.jsonDescribes the imported model
GUI registry$GUI_ROOT/configs/models.yamlDrives model selection
The full BenchMARL checkpoint is the correct artifact for the GUI. For a downstream inference runtime, export only the actor parameters.
What you’ve accomplished
You’ve preserved the BenchMARL directory layout, registered the checkpoint with the companion GUI, reloaded the deployed model, and accessed interactive playback through a secure tunnel.
Next, you’ll extract the shared actor for a runtime that doesn’t include BenchMARL.
