Understand the reference environment
You’ll train a multi-agent proximal policy optimization (MAPPO) policy entirely on Arm CPUs.
BenchMARL defines and runs the experiment, and TorchRL provides the reinforcement-learning components. VMAS simulates many navigation worlds in a vectorized PyTorch batch.
MAPPO trains an actor that selects each agent’s actions and a centralized critic used only during training. The reference configuration shares one actor across all three agents, which makes an actor-only export possible.
The reference experiment was tested on the following AWS configuration:
ComponentTested configuration
Instancem9g.48xlarge
ProcessorAWS Graviton5
Architectureaarch64
vCPUs192
Memory768 GiB
Operating systemUbuntu 24.04
Storage512 GB EBS volume
The M9g instance is EBS-only, so the storage volume is provisioned separately from the instance.
Note
The workflow doesn’t depend on an AWS-specific API, so you can run it on other Arm-based cloud instances. If you use a different instance, training time and the effective environment count will differ.
A smaller instance uses fewer vectorized environments. For more information on keeping the tested 100-batch budget or using an alternative fixed-total-frame budget, see Configure and train MAPPO .
AWS Graviton5 provides one hardware thread per core on the instance. The one-environment-per-workload-CPU rule is still a starting point rather than a fixed mapping, because VMAS processes the environments as tensor batches.
Note
The tested configuration is a reproducibility reference rather than a measured minimum requirement. Package installation, training logs, and checkpoints need persistent storage, but you don’t necessarily need 512 GB capacity.
Inspect the Arm cloud instance
Confirm that the instance uses the Arm64 architecture:
uname -m
The expected output is:
        aarch64
List the number of available CPUs:
nproc
You can also inspect the processor topology:
lscpu
Save the CPU count and leave one CPU out of the workload calculation:
export CORE_COUNT=$(nproc)
export RESERVED_CPUS=1
export WORKLOAD_CPUS=$((CORE_COUNT - RESERVED_CPUS))
test "$WORKLOAD_CPUS" -ge 1 || { echo "This sizing policy needs at least 2 CPUs" >&2; exit 1; }
Verify the values:
echo "TotalCPUs=$CORE_COUNT ReservedCPUs=$RESERVED_CPUS WorkloadCPUs=$WORKLOAD_CPUS"
The calculation reduces the size of the PyTorch thread pools and the VMAS batch. It doesn’t pin the workload to specific CPUs or prevent the operating system from scheduling work on them.
Understand agents and vectorized environments
The agent count and vectorized environment count control different parts of the workload:
  • Agents are the entities that learn to navigate in one VMAS world.
  • Vectorized environments are independent copies of that world simulated in parallel.
For example, three agents and 191 environments means that VMAS simulates 191 navigation worlds concurrently, with three agents in each world.
For CPU sampling, use one VMAS environment for each workload CPU:
export N_ENVS=$WORKLOAD_CPUS
Note
This is a workload-sizing policy. VMAS uses vectorized PyTorch operations, so an environment isn’t permanently mapped to one operating-system thread.
Install system packages
Update the package index:
sudo apt-get update
Install Python virtual environment support:
sudo apt-get install -y python3.12-venv
Install the remaining packages:
sudo apt-get install -y git build-essential python3-pip python3-dev pkg-config cmake ninja-build ffmpeg libgl1 libegl1 libglu1-mesa mesa-utils
Create a Python environment:
python3.12 -m venv $HOME/venvs/mappo
Activate the environment:
source $HOME/venvs/mappo/bin/activate
Confirm the active Python interpreter:
which python
Upgrade the Python packaging tools:
python -m pip install --upgrade pip setuptools wheel packaging
Install PyTorch:
python -m pip install torch torchvision torchaudio
Verify the installation:
python -c 'import platform, torch; print("Architecture:", platform.machine()); print("PyTorch:", torch.__version__); print("CUDA available:", torch.cuda.is_available()); print("CUDA device:", torch.cuda.get_device_name(0) if torch.cuda.is_available() else "N/A")'
On the tested system, the output was:
        Architecture: aarch64
PyTorch: 2.13.0+cu130
CUDA available: False
CUDA device: N/A
The PyTorch version can differ when you run an unpinned pip installation. CUDA available: False is expected on the CPU-only M9g instance, even if the wheel version contains a CUDA suffix.
Install BenchMARL and VMAS
Clone BenchMARL:
cd $HOME
git clone https://github.com/facebookresearch/BenchMARL.git
cd $HOME/BenchMARL
Install BenchMARL and VMAS:
python -m pip install -e .
python -m pip install vmas
Verify the software stack:
python -c 'import torch, torchrl, benchmarl, vmas; print("PyTorch:", torch.__version__); print("TorchRL: OK"); print("BenchMARL: OK"); print("VMAS: OK")'
TorchRL: OK
BenchMARL: OK
VMAS: OK
Record the BenchMARL revision used for the experiment:
git rev-parse HEAD
Keep the revision with your experiment notes so you can reproduce the software environment later.
You’ve verified the aarch64 environment, sized the initial VMAS workload, and installed the training stack. Next, you’ll choose a frame-budgeting method and adapt the vectorized environment count to the available CPUs.
