This Learning Path provides instructions to use the Arm Telemetry solution and Linux Perf for performance analysis on an example application presented in the Arm Neoverse N1 Core: Performance Analysis Methodology white paper (referred to as “white paper” for the remainder of the Learning Path).
Follow the Telemetry Solution install guide to install the required tools on an Arm Neoverse server. The Telemetry Solution install guide includes instructions to install Python and Linux Perf.
You will also need the GNU C++ compiler, g++. Refer to the
GNU Compiler install guide
to install it.
Application performance analysis involves measuring hardware and software events, understanding their meaning, and making software changes to improve performance. Performance analysis is a challenging task that may or may not yield meaningful results, but learning how to measure software performance and knowing how to identify performance issues is an important skill.
The Linux Perf event system provides a way to collect events for performance analysis. Linux Perf is a common tool for collecting performance information, but other tools exist.
There are two types of events, software events and hardware events. Examples of software events are context switches and page faults. Examples of hardware events are instructions executed and cache accesses.
In addition to the two types of events, there are two ways to collect the events, counting and sampling.
Counting collects the number of times an event occurs over a period of time, such as an entire program or a section of a program. Counting indicates how many times the event occurred, but does not help identify which instructions in an application are causing the events. Counting is a useful first step to characterize application performance.
Sampling is used to find places for performance improvement in code. It identifies which sections of code are executing most frequently. This information is gathered by taking a “sample” and recording where the program is executing (program counter). The samples can be collected based on time passing (such as every 10 milliseconds) or triggered by hardware events occurring. By sampling the software execution it is possible to locate the areas in the code that are running most often and connect the code to the hardware events.
Performance analysis requires an understanding of the hardware events, and how to connect them to causes of suboptimal performance.
Arm Neoverse processors include more than 100 hardware counters, but not all are important to get started with performance analysis.
Important event categories include:
The white paper covers these events in more detail. Each Neoverse CPU also has a complete PMU guide that documents all events.
To make performance analysis easier, combinations of events are used to compute frequently used metrics. For example, the L1 instruction cache miss rate is computed by dividing the L1 instruction cache refill count by the number of L1 instruction cache accesses.
The white paper outlines the important performance metrics for the Neoverse N1 and provides the calculations. The metrics are built into the Telemetry Solution so you don’t need to make the calculation or write scripts to compute the metrics.
If the events and metrics are not familiar to you, you may want to learn more about common CPU architecture features so you are better able to connect software execution to hardware events. Additional resources are provided in the Next Steps section of this Learning Path.
The white paper uses the hardware events and performance metrics to build a methodology you can follow to improve application performance.
The first step is to collect instructions per clock cycle (IPC), front end stall rate, and back end stall rate. The results will determine where to go next.
A high front end stall rate indicates cycles are being wasted due to pipeline stalls in the instruction fetch, L1 instruction cache, L1 instruction TLB, and the branch predictor. Such an application is characterized as front end bound.
A high back end stall rate indicates cycles are wasted due to pipeline stalls. Such an application is characterized as back end bound.
For front end bound applications look at the following metrics:
For back end bound applications look at the following metrics:
The following sections demonstrate the performance analysis methodology on an example application.
