The white paper presents a micro-benchmark from the DynamoRIO project. The stride benchmark is a pointer chasing algorithm that accesses values in a 16 MB array, with the array position being determined by the pointer being chased. The pointer position is a function of a constant value set in the array before the pointer chasing function begins.
The original source code is at https://github.com/DynamoRIO/dynamorio/blob/master/clients/drcachesim/tests/stride_benchmark.cpp
The code below is slightly modified to increase the number of iterations so that it runs longer for performance analysis.
stride.cpp:
* Copyright (c) 2018-2023 Google LLC All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* * Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* * Neither the name of Google, Inc. nor the names of its contributors may be
* used to endorse or promote products derived from this software without
* specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL GOOGLE LLC OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH
* DAMAGE.
#include <stdint.h>
#include <string.h>
#include <iostream>
#define MEM_BARRIER() __asm__ __volatile__("" ::: "memory")
int
main(int argc, const char *argv[])
// Cache line size in bytes.
const int kLineSize = 64;
// Number of cache lines skipped by the stream every iteration.
const int kStride = 7;
// Number of 1-byte elements in the array.
const size_t kArraySize = 16 * 1024 * 1024;
// Number of iterations in the main loop.
const int kIterations = 2000000000;
// The main vector/array used for emulating pointer chasing.
unsigned char *buffer = new unsigned char[kArraySize];
memset(buffer, kStride, kArraySize);
// Add a memory barrier so the call doesn't get optimized away or
// reordered with respect to callers.
MEM_BARRIER();
int position = 0;
// Here the code will pointer chase through the array skipping forward
// kStride cache lines at a time. Since kStride is an odd number, the main
// loop will touch different cache lines as it wraps around.
for (int loop = 0; loop < kIterations; ++loop) {
#if defined(ENABLE_PREFETCH) && defined (DIST)
const int prefetch_distance = DIST * kStride * kLineSize;
__builtin_prefetch(&buffer[position + prefetch_distance], 0, 0);
#endif
position += (buffer[position] * kLineSize);
position &= (kArraySize - 1);
MEM_BARRIER();
std::cerr << "Value = " << position << std::endl;
return 0;
g++ -g -O3 stride.cpp -o stride
Using -g provides source code information later for perf report.
./stride
The program runs for about 10-20 seconds, depending on your hardware, and the expected output is:
Value = 12779520
The next section demonstrates how to collect metrics for performance analysis.
