Ingest real-time sensor data
In this section, you simulate real-time sensor data using Python and continuously ingest it into TimescaleDB running on an Arm64 VM. This creates a live time-series data stream that can later be visualized using Grafana.
Architecture overview
Python Sensor Generator
        v
TimescaleDB Hypertable
  • A Python script acts as a sensor, generating temperature readings.
  • Each reading is written to TimescaleDB.
  • TimescaleDB stores the data in a hypertable, optimized for time-series workloads.
This architecture mirrors real-world IoT and telemetry pipelines.
Install Python dependencies
cd $HOME
sudo zypper install -y \
  python3 \
  python3-pip \
  python3-psycopg2
Verify psycopg2 is installed correctly:
python3 - <<EOF
import psycopg2
print("psycopg2 OK")
EOF
The output is similar to:
        psycopg2 OK
  • Confirms that the PostgreSQL driver is correctly installed.
  • If the import succeeds, Python can communicate with TimescaleDB.
Create a sensor table
Connect to the sensors database and create the sensor_data hypertable:
sudo -u postgres psql sensors
CREATE TABLE sensor_data (
  time        TIMESTAMPTZ NOT NULL,
  sensor_id   TEXT NOT NULL,
  temperature DOUBLE PRECISION
SELECT create_hypertable('sensor_data', 'time');
Press Ctrl+D to exit back into the SSH shell.
Create a sensor ingestion script
The following Python script simulates multiple sensors sending readings every two seconds and inserts them into TimescaleDB.
Create a new Python file called sensor_ingest.py and add the following code to the file:
import time
import random
import psycopg2
from datetime import datetime
conn = psycopg2.connect(
    dbname="sensors",
    user="postgres",
    host="localhost"
cur = conn.cursor()
sensors = ["sensor-1", "sensor-2", "sensor-3"]
while True:
    cur.execute(
        "INSERT INTO sensor_data VALUES (%s, %s, %s)",
            datetime.utcnow(),
            random.choice(sensors),
            round(random.uniform(20, 35), 2)
    conn.commit()
    time.sleep(2)
Run ingestion in the background
Start the ingestion process as a background job so it continues running even after you close the terminal:
nohup python3 sensor_ingest.py > ingest.log 2>&1 &
This ensures the sensor generator continues running even after you close the terminal.
Verify data ingestion
ps -ef | grep sensor_ingest.py
        gcpuser   5398  2841  0 08:55 pts/0    00:00:00 python3 sensor_ingest.py
gcpuser   5401  2841  0 08:55 pts/0    00:00:00 grep --color=auto sensor_ingest.py
sudo -u postgres psql sensors -c "SELECT COUNT(*) FROM sensor_data;"
  • Verified sensor ingestion by checking running processes and data count in TimescaleDB.
  • The count should increase continuously.
        gcpuser@tsdb-suse-arm64:~> sudo -u postgres psql sensors -c "SELECT COUNT(*) FROM sensor_data;"
 count
    14
(1 row)
 count
    15
(1 row)
 count
    16
(1 row)
Optimize time-series performance
These steps make TimescaleDB production-ready.
Create an index for faster queries
Connect to the sensors database and create an index optimized for time-range scans by sensor:
Issue the following SQL command:
CREATE INDEX ON sensor_data (sensor_id, time DESC);
This index improves Grafana query performance for time-range scans.
Enable a data retention policy
Automatically remove data older than seven days:
SELECT add_retention_policy(
  'sensor_data',
  INTERVAL '7 days'
This prevents disk exhaustion and runs automatically in the background.
Create a continuous aggregate
Precompute hourly averages per sensor for faster reporting:
CREATE MATERIALIZED VIEW sensor_hourly_avg
WITH (timescaledb.continuous) AS
SELECT
  time_bucket('1 hour', time) AS bucket,
  sensor_id,
  AVG(temperature) AS avg_temp
FROM sensor_data
GROUP BY bucket, sensor_id;
Add an aggregate refresh policy
Automate hourly aggregate refresh every five minutes for near real-time analytics:
SELECT add_continuous_aggregate_policy(
  'sensor_hourly_avg',
  INTERVAL '1 day',
  INTERVAL '1 hour',
  INTERVAL '5 minutes'
The table below explains the three interval parameters:
SettingMeaning
1 dayRecompute last day
1 hourSkip newest data
5 minRefresh interval
Validate the optimization
SELECT * FROM sensor_hourly_avg LIMIT 5;
Ensures ingestion and aggregation are running correctly and data is available for queries.
        postgres=# SELECT * FROM sensor_hourly_avg LIMIT 5;
         bucket         | sensor_id |     avg_temp
 2026-02-17 08:00:00+00 | sensor-1  |  26.6380487804878
 2026-02-17 08:00:00+00 | sensor-2  |             27.21
 2026-02-17 08:00:00+00 | sensor-3  | 28.13413793103448
(3 rows)
postgres=# SELECT COUNT(*) FROM sensor_data;
 count
  2466
(1 row)
Press Ctrl+D to exit.
Set the postgres password
Let’s set a password for postgres so Grafana can connect in the next section:
Then enter the new password:
\password postgres
Save the password — you’ll need it when configuring the Grafana data source. Press Ctrl+D to exit.
You’ve successfully:
  • Built a fully functioning real-time sensor data ingestion pipeline
  • Created TimescaleDB hypertables optimized for time-series storage
  • Implemented retention policies to automatically manage data lifecycle
  • Created continuous aggregates for faster reporting and analytics
  • Set up automated refresh policies for near real-time analytics
  • Set the postgres password for use in the Grafana plugin
Next, you’ll install Grafana, configure TimescaleDB as a data source, and build a live sensor temperature dashboard to visualize the real-time data you’re ingesting.
