Get started with TimescaleDB on Google Axion C4A
Create a firewall rule for Grafana/TimescaleDB
Create a Google Axion C4A Arm virtual machine on GCP
Set up TimescaleDB on Arm64
Ingest real-time sensor data on Arm64
Install Grafana and configure the TimescaleDB data source
Build a live sensor temperature dashboard
In this section, you’ll create a Grafana dashboard that visualizes live temperature data stored in TimescaleDB. The dashboard continuously updates to display sensor temperature changes in near real time.
Before proceeding, ensure the following are already completed:
sensor_data table is runningYou can verify live ingestion with:
sudo -u postgres psql sensors -c "SELECT COUNT(*) FROM sensor_data;"
The count should increase over time.
Open Grafana in your browser:
http://<GRAFANA_PUBLIC_IP>:3000
Log in using your Grafana credentials.
You will be redirected to the Edit panel screen.
In the Query section:
Grafana visualization configuration
Paste the following query after selecting Code on the right of the query editor:
SELECT
time AS "time",
temperature
FROM sensor_data
WHERE $__timeFilter(time)
ORDER BY time;
TimescaleDB SQL query editor
This query retrieves live sensor temperature data within the selected time range.
Apply the following settings in the right-hand panel:
Visualization Settings
Time & Refresh Settings
These settings ensure the panel refreshes automatically with new data.
Once configured, the panel should display a continuously updating temperature graph.
Live sensor temperature panel
The dashboard is now active.
You’ve built a complete time-series monitoring pipeline on Google Cloud C4A Axion Arm-based processors. TimescaleDB is running natively on Arm64, ingesting live sensor data through Python, and serving queries to Grafana for real-time visualization. From here you can add more sensors, create additional dashboards, set up alerting rules in Grafana, or tune TimescaleDB for your specific workload.
