Create a firewall rule in Google Cloud Console to expose TCP port 3000 for the TimescaleDB (Grafana) management interface.
Note
For help with GCP setup, see the Learning Path Getting started with Google Cloud Platform .
Configure the firewall rule
Navigate to the Google Cloud Console , go to VPC Network > Firewall, and select Create firewall rule.
Image Alt Text:Google Cloud Console VPC Network Firewall page showing the Create firewall rule button in the top menu bar alt-txtCreate a firewall rule in Google Cloud Console
Next, create the firewall rule that exposes TCP port 3000. Set the Name of the new rule to “allow-tcp-3000”. Select your network that you intend to bind to your VM (default is “autoscaling-net” but your organization might have others).
Set Direction of traffic to “Ingress”. Set Allow on match to “Allow” and Targets to “Specified target tags”. Enter “allow-tcp-3000” in the Target tags text field. Set Source IPv4 ranges to “0.0.0.0/0”.
Image Alt Text:Google Cloud Console Create firewall rule form with Name set to allow-tcp-3000, Direction of traffic set to Ingress, and Target tags field showing allow-tcp-3000 alt-txtConfiguring the allow-tcp-3000 firewall rule
Finally, select Specified protocols and ports under the Protocols and ports section. Select the TCP checkbox, enter “3000” in the Ports text field, and select Create.
Image Alt Text:Google Cloud Console Protocols and ports section with the TCP checkbox selected and port 3000 entered in the Ports text field alt-txtSetting TCP port 3000 in the firewall rule
In this section, you:
  • Created a firewall rule to expose TCP port 3000 for Grafana web interface access
  • Configured network ingress rules to allow remote connections from any source IP
Next, you’ll provision a Google Axion C4A Arm virtual machine and apply this firewall rule to enable external access to Grafana.
