TensorFlow is an open-source machine learning (ML) library developed by Google for building and deploying ML models efficiently. On 64-bit Arm architecture (aarch64) SUSE Linux Enterprise Server (SLES) VMs, TensorFlow runs natively on the CPU and can use the GPU if available.
Update your system and install Python 3.11, pip, and virtual environment support:
sudo zypper refresh
sudo zypper install python311 python311-pip python311-venv
Enter “y” when prompted to confirm the installation. This ensures your system has the essential tools required for TensorFlow setup.
Confirm that Python and pip are correctly installed:
python3.11 --version
pip3.11 --version
The output is similar to:
Python 3.11.10
pip 22.3.1 from /usr/lib/python3.11/site-packages/pip (python 3.11)
Set up an isolated Python environment to keep TensorFlow dependencies separate from system packages:
python3.11 -m venv tf-venv
source tf-venv/bin/activate
Your virtual environment tf-venv is now active and isolated from system packages.
Upgrade pip to the latest version for reliable package installation:
pip3 install --upgrade pip
Install the latest stable TensorFlow version for Arm64:
pip3 install tensorflow==2.20.0
TensorFlow 2.18.0 introduced compatibility with NumPy 2.0, incorporating its updated type promotion rules and improved numerical precision. You can review What’s new in TensorFlow 2.18 for more information.
The Arm Ecosystem Dashboard recommends TensorFlow version 2.18.0 as the minimum recommended version on Arm platforms.
Check that TensorFlow installed successfully and display the version:
python -c "import tensorflow as tf; print(tf.__version__)"
2.20.0
You have now installed TensorFlow on your Arm-based VM and are ready to start building and running machine learning models!
