Benchmark TensorFlow models
This section benchmarks multiple TensorFlow models - ResNet50, MobileNetV2, and InceptionV3 - using dummy input data. You’ll measure average inference time and throughput for each model running on the CPU of your Arm-based Google Cloud Platform (GCP) VM.
TensorFlow Keras (tf.keras) is TensorFlow’s high-level API for building, training, and benchmarking deep learning models. It provides access to predefined architectures such as ResNet, MobileNet, and Inception, making it easy to evaluate model performance on different hardware setups.
Activate your virtual environment
Enable your isolated Python environment where TensorFlow is installed:
source ~/tf-venv/bin/activate
python -c "import tensorflow as tf; print(tf.__version__)"
This ensures that all TensorFlow-related packages run in a clean, controlled setup without affecting system-wide Python installations.
Install required packages
Install TensorFlow and NumPy for model creation and benchmarking:
pip install tensorflow==2.20.0 numpy
These packages are likely already installed from previous steps. NumPy supports efficient numerical operations, while TensorFlow handles deep learning workloads.
Create the benchmark script
Use an editor to create a Python script named tf_cpu_benchmark.py that will run TensorFlow model benchmarking tests.
Add the following code to benchmark three different model architectures:
import time
# List of models to benchmark
models = {
    "ResNet50": tf.keras.applications.ResNet50,
    "MobileNetV2": tf.keras.applications.MobileNetV2,
    "InceptionV3": tf.keras.applications.InceptionV3
batch_size = 32
num_runs = 50
for name, constructor in models.items():
    print(f"\nBenchmarking {name}...")
    # Create model without pretrained weights
    model = constructor(weights=None, input_shape=(224,224,3))
    # Generate dummy input
    dummy_input = tf.random.uniform([batch_size, 224, 224, 3])
    # Warm-up
    _ = model(dummy_input)
    # Benchmark
    start = time.time()
    for _ in range(num_runs):
    end = time.time()
    avg_time = (end - start) / num_runs
    throughput = batch_size / avg_time
    print(f"{name} average inference time per batch: {avg_time:.4f} seconds")
    print(f"{name} throughput: {throughput:.2f} images/sec")
This script creates model instances without pretrained weights for fair CPU testing, generates random image data for inference, includes a warm-up phase to stabilize model performance, and measures inference time over 50 runs to calculate average performance and throughput.
Run the benchmark
Execute the benchmarking script:
python tf_cpu_benchmark.py
The output is similar to:
        Benchmarking ResNet50...
ResNet50 average inference time per batch: 1.2051 seconds
ResNet50 throughput: 26.55 images/sec
Benchmarking MobileNetV2...
MobileNetV2 average inference time per batch: 0.2909 seconds
MobileNetV2 throughput: 110.02 images/sec
Benchmarking InceptionV3...
InceptionV3 average inference time per batch: 0.8971 seconds
InceptionV3 throughput: 35.67 images/sec
Interpret the results
The benchmark provides key performance metrics. Average inference time per batch measures how long it takes to process one batch of input data, with lower values indicating faster performance. Throughput shows how many images the model can process per second, with higher values indicating better efficiency.
Performance summary
The following table shows results from running the benchmark on a c4a-standard-4 (4 vCPU, 16 GB memory) aarch64 VM in Google Cloud Platform (GCP) using SUSE Linux Enterprise Server (SLES):
ModelAverage Inference Time per Batch (seconds)Throughput (images/sec)
ResNet501.205126.55
MobileNetV20.2909110.02
InceptionV30.897135.67
The results show strong performance for lightweight CNNs like MobileNetV2, achieving over 110 images/sec on the aarch64 platform. Medium-depth models like InceptionV3 maintain balanced performance between accuracy and latency. Heavier architectures such as ResNet50 show longer inference times but deliver stable throughput.
You have successfully benchmarked TensorFlow models on your Arm-based VM. This demonstrates the efficiency and scalability of Arm platforms for deep learning workloads - great job!
