This section helps you confirm that TensorFlow is installed and working correctly on your Google Axion C4A Arm virtual machine (VM). You’ll run tests to check that your CPU can perform TensorFlow operations and basic neural network training.
List the hardware devices TensorFlow can use, such as CPU or GPU. On most VMs, only the CPU is available:
python -c "import tensorflow as tf; print(tf.config.list_physical_devices())"
The output is similar to:
[PhysicalDevice(name='/physical_device:CPU:0', device_type='CPU')]
Multiply two large matrices to verify TensorFlow computations on your CPU and measure execution time:
python -c "import tensorflow as tf; import time; \
a = tf.random.uniform((1000,1000)); b = tf.random.uniform((1000,1000)); \
start = time.time(); c = tf.matmul(a,b); end = time.time(); \
print('Computation time:', end - start, 'seconds')"
Computation time: 0.008263111114501953 seconds
This provides a baseline measurement for CPU performance.
Create a file named test_nn.py with the following code:
import keras
from keras import layers
import numpy as np
# Dummy data
x = np.random.rand(1000, 20)
y = np.random.rand(1000, 1)
# Define the model
model = keras.Sequential()
model.add(keras.Input(shape=(20,)))
model.add(layers.Dense(64, activation="relu"))
model.add(layers.Dense(1))
# Compile the model
model.compile(optimizer='adam', loss='mse')
# Train for 1 epoch
model.fit(x, y, epochs=1, batch_size=32)
This script creates and trains a basic neural network using random data to verify that TensorFlow’s deep learning functions work on the Arm platform.
Execute the script:
python test_nn.py
TensorFlow displays training progress similar to:
32/32 ━━━━━━━━━━━━━━━━━━━━ 0s 1ms/step - loss: 0.1024
TensorFlow is working correctly on your Arm-based VM for both basic computations and neural network training. Your environment is ready for benchmarking.
