Searching large arrays for specific values is a core task in performance-sensitive applications, from filtering records in a database to detecting patterns in text or images. On Arm Neoverse-based servers, SVE2 MATCH instructions unlock significant performance gains by vectorizing these operations. In this Learning Path, you’ll implement and benchmark both scalar and vectorized versions of search functions to see just how much faster workloads can run.
SVE2 (Scalable Vector Extension 2) is an extension to the Arm architecture that provides vector processing capabilities with a length-agnostic programming model. The MATCH instruction is a specialized SVE2 instruction that efficiently searches for elements in a vector that match any element in another vector.
To work through these examples, you need:
Start by setting up your environment:
sudo apt-get update
sudo apt-get install -y build-essential gcc g++
An effective way to achieve optimal performance on Arm is not only through optimal flag usage, but also by using the most recent compiler version. This Learning path was tested with GCC 13 which is the default version on Ubuntu 24.04, but you can run it with newer versions of GCC as well.
Create a directory for your implementations:
mkdir -p sve2_match_demo
cd sve2_match_demo
Your goal is to implement a function that searches for any occurrence of a set of keys in an array. The function should return true if any element in the array matches any of the keys, and false otherwise.
This type of search operation is common in many applications:
To understand the alternatives, you can implement three versions of the search function:
Create a generic implementation in C that checks each element individually against each key. Open an editor of your choice and copy the code shown into a file named sve2_match_demo.c:
#include <arm_sve.h>
#include <inttypes.h>
#include <stddef.h>
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <time.h>
int search_generic_u8(const uint8_t *hay, size_t n, const uint8_t *keys,
size_t nkeys) {
for (size_t i = 0; i < n; ++i) {
uint8_t v = hay[i];
for (size_t k = 0; k < nkeys; ++k)
if (v == keys[k]) return 1;
return 0;
int search_generic_u16(const uint16_t *hay, size_t n, const uint16_t *keys,
size_t nkeys) {
uint16_t v = hay[i];
return 0;
The search_generic_u8() and search_generic_u16() functions both return 1 immediately when a match is found in the inner loop.
Now create an implementation that uses SVE2 MATCH instructions to process multiple elements in parallel.
Copy the code shown into the same source file:
int search_sve2_match_u8(const uint8_t *hay, size_t n, const uint8_t *keys,
size_t nkeys) {
if (nkeys == 0) return 0;
const size_t VL = svcntb();
svbool_t pg = svptrue_b8();
uint8_t tmp[256];
for (size_t i = 0; i < VL; ++i) tmp[i] = keys[i % nkeys];
svuint8_t keyvec = svld1(pg, tmp);
size_t i = 0;
for (; i + VL <= n; i += VL) {
svuint8_t block = svld1(pg, &hay[i]);
if (svptest_any(pg, svmatch_u8(pg, block, keyvec))) return 1;
for (; i < n; ++i) {
uint8_t v = hay[i];
return 0;
int search_sve2_match_u16(const uint16_t *hay, size_t n, const uint16_t *keys,
size_t nkeys) {
const size_t VL = svcnth();
svbool_t pg = svptrue_b16();
uint16_t tmp[128];
svuint16_t keyvec = svld1(pg, tmp);
size_t i = 0;
svuint16_t block = svld1(pg, &hay[i]);
if (svptest_any(pg, svmatch_u16(pg, block, keyvec))) return 1;
return 0;
The SVE MATCH implementation with the search_sve2_match_u8() and search_sve2_match_u16() functions provide an efficient vectorized search approach with these key technical aspects:
svcntb() for scalabilityIn this next SVE2 implementation you will add loop unrolling and prefetching to further improve performance.
int search_sve2_match_u8_unrolled(const uint8_t *hay, size_t n, const uint8_t *keys,
size_t nkeys) {
// Prepare key vector
uint8_t tmp[256] __attribute__((aligned(64)));
size_t i = 0;
// Process 4 vectors per iteration
for (; i + 4*VL <= n; i += 4*VL) {
// Prefetch data ahead
__builtin_prefetch(&hay[i + 16*VL], 0, 0);
svuint8_t block1 = svld1(pg, &hay[i]);
svuint8_t block2 = svld1(pg, &hay[i + VL]);
svuint8_t block3 = svld1(pg, &hay[i + 2*VL]);
svuint8_t block4 = svld1(pg, &hay[i + 3*VL]);
svbool_t match1 = svmatch_u8(pg, block1, keyvec);
svbool_t match2 = svmatch_u8(pg, block2, keyvec);
svbool_t match3 = svmatch_u8(pg, block3, keyvec);
svbool_t match4 = svmatch_u8(pg, block4, keyvec);
if (svptest_any(pg, match1) || svptest_any(pg, match2) ||
svptest_any(pg, match3) || svptest_any(pg, match4))
return 1;
// Process remaining vectors one at a time
// Handle remainder
uint8_t v = hay[i];
return 0;
// Optimized 16-bit version with unrolling
int search_sve2_match_u16_unrolled(const uint16_t *hay, size_t n, const uint16_t *keys,
size_t nkeys) {
uint16_t tmp[128] __attribute__((aligned(64)));
size_t i = 0;
svuint16_t block1 = svld1(pg, &hay[i]);
svuint16_t block2 = svld1(pg, &hay[i + VL]);
svuint16_t block3 = svld1(pg, &hay[i + 2*VL]);
svuint16_t block4 = svld1(pg, &hay[i + 3*VL]);
svbool_t match1 = svmatch_u16(pg, block1, keyvec);
svbool_t match2 = svmatch_u16(pg, block2, keyvec);
svbool_t match3 = svmatch_u16(pg, block3, keyvec);
svbool_t match4 = svmatch_u16(pg, block4, keyvec);
return 1;
// Handle remainder
return 0;
The main highlights of this implementation are:
__builtin_prefetch) to reduce memory latencysvmatch_u8 and svmatch_u16 instructions to efficiently compare each element against multiple keys in a single operationTo compare the performance of the three implementations, use a benchmarking framework that measures the execution time of each implementation. You will also add helper functions for membership testing that are needed to setup the test data with controlled hit rates.
Copy the code below into the bottom of the same source code file:
// Timing function
static inline uint64_t nsec_now(void) {
struct timespec ts;
#if defined(CLOCK_MONOTONIC_RAW)
clock_gettime(CLOCK_MONOTONIC_RAW, &ts);
#else
clock_gettime(CLOCK_MONOTONIC, &ts);
#endif
return (uint64_t)ts.tv_sec * 1000000000ULL + ts.tv_nsec;
// ---------------- helper: membership test for RNG fill ----------------------
static int key_in_set_u8(uint8_t v, const uint8_t *keys, size_t nkeys) {
return 0;
static int key_in_set_u16(uint16_t v, const uint16_t *keys, size_t nkeys) {
return 0;
// Fill such that P(match) ~= p.
static void fill_bytes_lowhit(uint8_t *buf, size_t n, const uint8_t *keys,
size_t nkeys, double p) {
if (drand48() < p) {
buf[i] = keys[rand() % nkeys];
} else {
uint8_t v;
do { v = (uint8_t)rand(); } while (key_in_set_u8(v, keys, nkeys));
buf[i] = v;
static void fill_u16_lowhit(uint16_t *buf, size_t n, const uint16_t *keys,
} else {
uint16_t v;
do { v = (uint16_t)rand(); } while (key_in_set_u16(v, keys, nkeys));
buf[i] = v;
// Main benchmarking function
int main(int argc, char **argv) {
const size_t len = (argc > 1) ? strtoull(argv[1], NULL, 0) : (1ull << 26);
const int iterations = (argc > 2) ? atoi(argv[2]) : 5;
const double hit_prob = (argc > 3) ? atof(argv[3]) : 0.001;
printf("Haystack length : %zu elements\n", len);
printf("Iterations : %d\n", iterations);
printf("Hit probability : %.6f (%.4f %% )\n\n", hit_prob, hit_prob * 100.0);
// Initialize data and run benchmarks...
srand48(42);
srand(42);
// Align memory to 64-byte boundary for better performance
uint8_t *hay8 = aligned_alloc(64, len);
uint16_t *hay16 = aligned_alloc(64, len * sizeof(uint16_t));
const uint8_t keys8[] = {0x13, 0x7F, 0xA5, 0xEE, 0x4C, 0x42, 0x01, 0x9B};
const uint16_t keys16[] = {0x1234, 0x7F7F, 0xA5A5, 0xEEEE, 0x4C4C, 0x4242};
const size_t NKEYS8 = sizeof(keys8) / sizeof(keys8[0]);
const size_t NKEYS16 = sizeof(keys16) / sizeof(keys16[0]);
fill_bytes_lowhit(hay8, len, keys8, NKEYS8, hit_prob);
fill_u16_lowhit(hay16, len, keys16, NKEYS16, hit_prob);
uint64_t t_gen8 = 0, t_sve8 = 0, t_sve8_unrolled = 0;
uint64_t t_gen16 = 0, t_sve16 = 0, t_sve16_unrolled = 0;
for (int it = 0; it < iterations; ++it) {
uint64_t t0;
t0 = nsec_now();
volatile int r = search_generic_u8(hay8, len, keys8, NKEYS8); (void)r;
t_gen8 += nsec_now() - t0;
#if defined(__ARM_FEATURE_SVE2)
t0 = nsec_now();
r = search_sve2_match_u8(hay8, len, keys8, NKEYS8); (void)r;
t_sve8 += nsec_now() - t0;
t0 = nsec_now();
r = search_sve2_match_u8_unrolled(hay8, len, keys8, NKEYS8); (void)r;
t_sve8_unrolled += nsec_now() - t0;
#endif
t0 = nsec_now();
r = search_generic_u16(hay16, len, keys16, NKEYS16); (void)r;
t_gen16 += nsec_now() - t0;
t0 = nsec_now();
r = search_sve2_match_u16(hay16, len, keys16, NKEYS16); (void)r;
t_sve16 += nsec_now() - t0;
t0 = nsec_now();
r = search_sve2_match_u16_unrolled(hay16, len, keys16, NKEYS16); (void)r;
t_sve16_unrolled += nsec_now() - t0;
#endif
// ---------- latency results ----------
printf("Average latency over %d iterations (ns):\n", iterations);
printf(" generic_u8 : %.2f\n", (double)t_gen8 / iterations);
printf(" sve2_u8 : %.2f\n", (double)t_sve8 / iterations);
printf(" sve2_u8_unrolled : %.2f\n", (double)t_sve8_unrolled / iterations);
printf(" speed‑up (orig) : %.2fx\n", (double)t_gen8 / t_sve8);
printf(" speed‑up (unroll): %.2fx\n\n", (double)t_gen8 / t_sve8_unrolled);
#else
printf(" (SVE2 path not built)\n\n");
#endif
printf(" generic_u16 : %.2f\n", (double)t_gen16 / iterations);
printf(" sve2_u16 : %.2f\n", (double)t_sve16 / iterations);
printf(" sve2_u16_unrolled: %.2f\n", (double)t_sve16_unrolled / iterations);
printf(" speed‑up (orig) : %.2fx\n", (double)t_gen16 / t_sve16);
printf(" speed‑up (unroll): %.2fx\n", (double)t_gen16 / t_sve16_unrolled);
#else
printf(" (SVE2 path not built)\n");
#endif
// ---------- throughput results ----------
const double elems_total = (double)len * iterations;
printf("\nThroughput (million items/second):\n");
double tp_gen8 = elems_total / (t_gen8 / 1e9) / 1e6;
printf(" generic_u8 : %.2f Mi/s\n", tp_gen8);
double tp_sve8 = elems_total / (t_sve8 / 1e9) / 1e6;
double tp_sve8_unrolled = elems_total / (t_sve8_unrolled / 1e9) / 1e6;
printf(" sve2_u8 : %.2f Mi/s\n", tp_sve8);
printf(" sve2_u8_unrolled : %.2f Mi/s\n", tp_sve8_unrolled);
printf(" speed‑up (orig) : %.2fx\n", tp_sve8 / tp_gen8);
printf(" speed‑up (unroll): %.2fx\n\n", tp_sve8_unrolled / tp_gen8);
#else
#endif
double tp_gen16 = elems_total / (t_gen16 / 1e9) / 1e6;
printf(" generic_u16 : %.2f Mi/s\n", tp_gen16);
double tp_sve16 = elems_total / (t_sve16 / 1e9) / 1e6;
double tp_sve16_unrolled = elems_total / (t_sve16_unrolled / 1e9) / 1e6;
printf(" sve2_u16 : %.2f Mi/s\n", tp_sve16);
printf(" sve2_u16_unrolled: %.2f Mi/s\n", tp_sve16_unrolled);
printf(" speed‑up (orig) : %.2fx\n", tp_sve16 / tp_gen16);
printf(" speed‑up (unroll): %.2fx\n", tp_sve16_unrolled / tp_gen16);
#else
#endif
free(hay8);
free(hay16);
return 0;
You can now compile the different search implementations:
gcc -O3 -march=armv9-a+sve2 -mcpu=neoverse-v2 sve2_match_demo.c -o sve2_match_demo
Run the benchmark on a dataset of 65,536 elements (2^16) with a 0.001% hit rate:
./sve2_match_demo $((1<<16)) 3 0.00001
The output is similar to:
Haystack length : 65536 elements
Iterations : 3
Hit probability : 0.000010 (0.0010 % )
Average latency over 3 iterations (ns):
generic_u8 : 79149.33
sve2_u8 : 1051.00
sve2_u8_unrolled : 871.67
speed‑up (orig) : 75.31x
speed‑up (unroll): 90.80x
generic_u16 : 85405.33
sve2_u16 : 4118.67
sve2_u16_unrolled: 3137.00
speed‑up (orig) : 20.74x
speed‑up (unroll): 27.23x
You can experiment with different haystack lengths, iterations and hit probabilities.
./sve2_match_demo [length] [iterations] [hit_prob]
When running on a Graviton4 instance with Ubuntu 24.04 and a dataset of 65,536 elements (2^16), you will see different hit probabilities, as shown in the following results:
| Implementation | 0% (No Matches) | 0.001% | 0.01% | 0.1% | 1% |
| Generic Scalar | 145,042.80 | 79,414.40 | 22,351.20 | 2,244.60 | 332.60 |
| SVE2 MATCH | 2,180.60 | 1,092.00 | 425.80 | 109.40 | 67.40 |
| SVE2 MATCH Unrolled | 1,520.20 | 861.60 | 320.20 | 89.60 | 55.60 |
| Generic Scalar | 86,936.80 | 86,882.40 | 33,973.40 | 4,054.80 | 117.60 |
| SVE2 MATCH | 3,941.40 | 4,012.20 | 1,618.00 | 235.00 | 59.60 |
| SVE2 MATCH Unrolled | 3,102.00 | 3,192.40 | 1,254.60 | 193.40 | 59.40 |
| Hit Rate | SVE2 MATCH | SVE2 MATCH Unrolled |
| 0% | 66.52x | 95.41x |
| 0.001% | 72.72x | 92.17x |
| 0.01% | 52.49x | 69.80x |
| 0.1% | 20.52x | 25.05x |
| 1% | 4.93x | 5.98x |
| 0% | 22.06x | 28.03x |
| 0.001% | 21.65x | 27.22x |
| 0.01% | 21.00x | 27.08x |
| 0.1% | 17.25x | 20.97x |
The benchmark results reveal several important insights about the performance characteristics of SVE2 MATCH instructions. The most striking observation is how the performance advantage of SVE2 MATCH varies with the hit rate:
This pattern makes SVE2 MATCH particularly well-suited for applications where matches are rare but important to find, such as:
The unrolled implementation consistently outperforms the basic SVE2 MATCH implementation:
This demonstrates the value of combining algorithmic optimizations (loop unrolling, prefetching) with hardware-specific instructions for maximum performance.
The SVE2 MATCH instruction can be applied to various real-world scenarios such as:
Database Systems
In database systems, MATCH can accelerate:
Text Processing
For text processing applications, MATCH can speed up:
Network Packet Inspection
In network applications, MATCH can improve:
Image Processing
For image processing, MATCH can accelerate:
The SVE2 MATCH instruction provides a powerful way to accelerate search operations in byte and half word arrays. By implementing these optimizations on cloud instances with SVE2, you can achieve significant performance improvements for your applications.
