Deploy an AI storefront assistant on GKE on Google Axion
Understand mixed placement for a storefront AI assistant
Set up the source tree and cluster access
Deploy and validate the storefront on a Google N4A node pool
Review the shopping assistant implementation
Build and push the assistant image to Artifact Registry
Deploy the assistant on the Google N4A node pool
Observe and benchmark the assistant on the Google N4A node pool
Move the assistant to the Google C4A node pool and compare results
Inspect the assistant files
The source tree already contains the missing AI tier. Before you build it, review the files that make up the assistant:
find src/shoppingassistantservice -maxdepth 2 -type f | sort
find kustomize/components/shopping-assistant -maxdepth 2 -type f | sort
You’ll see the assistant source folder and the shopping-assistant Kustomize component.
If you see a __pycache__ directory, ignore it. Python creates that directory during local syntax checks.
Review the runtime dependencies and gRPC stubs
The assistant uses a small Python runtime and generated gRPC stubs to call the live storefront services:
sed -n '1,20p' src/shoppingassistantservice/requirements.txt
sed -n '1,25p' src/shoppingassistantservice/demo_pb2.py
grep -nE 'class (CartServiceStub|ProductCatalogServiceStub)' \
src/shoppingassistantservice/demo_pb2_grpc.py
The generated protobuf files are dense because they’re machine-generated. You only need to confirm that the cart and product catalog stubs exist.
Review the assistant service
Read the beginning and end of the assistant service:
sed -n '1,220p' src/shoppingassistantservice/shoppingassistantservice.py
tail -n 20 src/shoppingassistantservice/shoppingassistantservice.py
Focus on these parts of the file:
- Imports and environment variables
- Tool functions that call the live storefront services
- Request handlers that decide how the assistant responds
- The
app.run(...)entrypoint
Highlight the tool functions:
grep -nE 'def (search_catalog|get_product_details|get_cart|add_to_cart|handle_[a-z_]+)' \
These functions define the assistant behavior. The service searches the catalog, fetches product details, reads the cart, and updates the cart after confirmation. These are live application tool calls, not mock responses, which is what makes the assistant part of the storefront workflow.
Confirm that the Python source is valid
Compile the assistant source:
python3 -m py_compile src/shoppingassistantservice/shoppingassistantservice.py
The command returns no output. Don’t continue if this command fails.
Review the container and Kubernetes component
Review the Dockerfile and the Kustomize component:
sed -n '1,80p' src/shoppingassistantservice/Dockerfile
sed -n '1,120p' kustomize/components/shopping-assistant/kustomization.yaml
sed -n '1,220p' kustomize/components/shopping-assistant/shoppingassistantservice.yaml
The Dockerfile packages the Python assistant service. The Kubernetes component creates shoppingassistantservice, adds the Ollama sidecar, and patches frontend so the assistant becomes part of the storefront experience. Because the assistant and Ollama run in the same pod, moving this deployment later moves the AI logic and local reasoning runtime together.
You’ve now reviewed the source code, service contracts, container packaging, and Kubernetes component for the assistant tier.
Next, you’ll build the assistant image for linux/arm64 and push it to Artifact Registry.
