Configure your environment
You’ll use a prepared GKE Standard cluster with two Linux arm64 node pools:
  • An N4A node pool based on Google Axion and Arm Neoverse N3
  • A C4A node pool based on Google Axion and Arm Neoverse V2
The cluster must expose the Kubernetes Metrics API so that kubectl top and the benchmark telemetry collector can read pod CPU usage.
Your Google Cloud account also needs permission for the following:
  • Getting cluster credentials
  • Deploying Kubernetes workloads and services
  • Reading nodes, pod logs, and pod metrics
  • Creating or using an Artifact Registry Docker repository in the same project
Use Cloud Shell or a Linux or macOS administrative workstation to manage GKE. The application runs in Linux arm64 containers on the cluster.
You’ll need Docker running on your administrative environment, and the Buildx plugin to be available.
Buildx can create a linux/arm64 image on an Arm development machine. It can also use an appropriately configured builder to cross-build the image on another architecture.
Confirm that the tools are available:
gcloud --version
kubectl version --client
docker version
docker buildx version
git --version
curl --version
python3 --version
jq --version
The workshop helper scripts require Python 3.10 or later. Use a kubectl client version that Google Kubernetes Engine supports for your cluster version.
Create or reuse the builder for this Learning Path:
if docker buildx inspect axion-builder >/dev/null 2>&1; then
  docker buildx use axion-builder
else
  docker buildx create --name axion-builder --use
fi
docker buildx inspect --bootstrap
Confirm that the Platforms line includes linux/arm64 before you continue. The later build command uses this capability to produce an image for the Arm-based N4A and C4A nodes. If linux/arm64 is missing, configure Arm support for your Docker builder before continuing. For more information, see Build multi-architecture images with Docker buildx .
You’ll also use Kustomize in the following sections. Kustomize combines a shared set of Kubernetes manifests with reusable components and placement-specific patches. The tool is built into kubectl, so the kubectl kustomize and kubectl apply -k commands don’t need a separate Kustomize executable.
Set environment variables
Set the project, cluster, Artifact Registry, and node-pool variables. Adjust the values to match your prepared environment:
export PROJECT_ID="$(gcloud config get-value project)"
export CLUSTER_NAME="online-boutique"
export ARTIFACT_REGION="us-central1"
export ARTIFACT_REPO="axion-workshop"
export ARTIFACT_REGISTRY="${ARTIFACT_REGION}-docker.pkg.dev/${PROJECT_ID}/${ARTIFACT_REPO}"
export N4A_NODE_POOL_NAME="arm64-pool-n4a2"
export C4A_NODE_POOL_NAME="arm64-pool-c4a"
If PROJECT_ID is empty or prints (unset), set it manually:
printf 'Google Cloud project ID: '
read -r PROJECT_ID
export PROJECT_ID
gcloud config set project "${PROJECT_ID}"
Save the values in one environment file so that later terminals use the same configuration. If you change a prepared resource name, update it in the following block and recreate the file:
export AXION_LAB_ENV="${HOME}/.storefront-axion-env"
export REPO_ROOT="${HOME}/n4a-c4a"
export REPO="${REPO_ROOT}/microservices-demo"
export SOURCE_COMMIT="b0a1be98cd47087638b2ea98c9c3de01bc4f533c"
export ASSISTANT_IMAGE_REPO="${ARTIFACT_REGISTRY}/shoppingassistantservice"
export ASSISTANT_IMAGE_TAG="lab-v1"
export ASSISTANT_IMAGE="${ASSISTANT_IMAGE_REPO}:${ASSISTANT_IMAGE_TAG}"
cat <<EOF > "${AXION_LAB_ENV}"
export PROJECT_ID="${PROJECT_ID}"
export CLUSTER_NAME="${CLUSTER_NAME}"
export ARTIFACT_REGION="${ARTIFACT_REGION}"
export ARTIFACT_REPO="${ARTIFACT_REPO}"
export ARTIFACT_REGISTRY="${ARTIFACT_REGISTRY}"
export N4A_NODE_POOL_NAME="${N4A_NODE_POOL_NAME}"
export C4A_NODE_POOL_NAME="${C4A_NODE_POOL_NAME}"
export REPO_ROOT="${REPO_ROOT}"
export REPO="${REPO}"
export SOURCE_COMMIT="${SOURCE_COMMIT}"
export ASSISTANT_IMAGE_REPO="${ASSISTANT_IMAGE_REPO}"
export ASSISTANT_IMAGE_TAG="${ASSISTANT_IMAGE_TAG}"
export ASSISTANT_IMAGE="${ASSISTANT_IMAGE}"
EOF
Discover the cluster location
Query Google Cloud for the cluster location to avoid hard-coding a zone or region:
export CLUSTER_LOCATION="$(gcloud container clusters list \
  --project "${PROJECT_ID}" \
  --filter="name=${CLUSTER_NAME}" \
  --format='value(location)' | head -n 1)"
echo "${CLUSTER_LOCATION}"
The output prints the cluster location, such as us-central1 or us-central1-a.
Don’t continue if the output is empty. Confirm CLUSTER_NAME and PROJECT_ID, and then run the command again.
Connect kubectl to the cluster
Configure gcloud and get cluster credentials:
gcloud container clusters get-credentials "${CLUSTER_NAME}" \
  --location "${CLUSTER_LOCATION}"
Confirm the current Kubernetes context:
kubectl config current-context
kubectl get nodes
Create or confirm the Artifact Registry repository
The assistant image is pushed to Artifact Registry. Create the Docker repository if it doesn’t already exist:
gcloud artifacts repositories describe "${ARTIFACT_REPO}" \
  --location "${ARTIFACT_REGION}" >/dev/null 2>&1 || \
gcloud artifacts repositories create "${ARTIFACT_REPO}" \
  --repository-format=docker \
  --location "${ARTIFACT_REGION}" \
  --description="Axion storefront assistant images"
Authenticate Docker to Artifact Registry
Authenticate Docker so it can push your assistant image:
gcloud auth configure-docker "${ARTIFACT_REGION}-docker.pkg.dev" --quiet
Clone the lab source tree
Clone the Arm-maintained Online Boutique source tree for this Learning Path. If an existing checkout is present, move it aside before cloning a fresh copy:
mkdir -p "${REPO_ROOT}"
if [ -d "${REPO}" ]; then
  mv "${REPO}" "${REPO}.$(date +%Y%m%d%H%M%S).bak"
fi
git clone --branch arm-multiarch-baseline --single-branch \
  https://github.com/ArmDeveloperEcosystem/microservices-demo.git "${REPO}"
cd "${REPO}"
git checkout "${SOURCE_COMMIT}"
The commit is pinned because the workshop branch is under active development. Confirm that the working tree is at the expected commit:
pwd
git rev-parse HEAD
The commit should be:
Confirm Arm node pools and storefront images
Check that the cluster has Arm node pools for N4A and C4A:
kubectl get nodes -L kubernetes.io/arch,cloud.google.com/gke-nodepool
Inspect the frontend manifest in the source tree:
grep -n "image:" kustomize/base/frontend.yaml
The cluster uses Arm-based Axion node pools, and the storefront manifest uses image references that can resolve to Arm-compatible image variants.
You’ve now configured your Google Cloud project, connected kubectl to the prepared GKE cluster, confirmed Artifact Registry access, and cloned the source tree that contains the assistant implementation.
Next, you’ll validate the starting storefront baseline on N4A before you add the assistant.
