Deploy an AI storefront assistant on GKE on Google Axion
Understand mixed placement for a storefront AI assistant
Set up the source tree and cluster access
Deploy and validate the storefront on a Google N4A node pool
Review the shopping assistant implementation
Build and push the assistant image to Artifact Registry
Deploy the assistant on the Google N4A node pool
Observe and benchmark the assistant on the Google N4A node pool
Move the assistant to the Google C4A node pool and compare results
Review the telemetry scripts
The source tree includes helper scripts that focus traffic and telemetry on the assistant workflow:
workshop/telemetry_collector.pysamples Kubernetes metrics and records the assistant node pool.workshop/mini_dashboard.pyrenders a simple live dashboard.workshop/request_driver.pysends live assistant traffic.workshop/fixed_batch_trial.pyruns a repeatable benchmark.workshop/compare_summaries.pycompares benchmark summaries.
Check the assistant service and compile the scripts before you run them:
kubectl get deployment shoppingassistantservice
kubectl get pods -l app=shoppingassistantservice -o wide
kubectl top pod -l app=shoppingassistantservice --containers
python3 -m py_compile workshop/telemetry_collector.py
python3 -m py_compile workshop/mini_dashboard.py
python3 -m py_compile workshop/request_driver.py
python3 -m py_compile workshop/fixed_batch_trial.py
python3 -m py_compile workshop/compare_summaries.py
If kubectl top isn’t available yet, make sure metrics collection is enabled in the cluster before you rely on CPU telemetry.
Open three terminals
Use three terminals so telemetry, the dashboard, and benchmark commands can run at the same time.
In each terminal, restore the variables from setup and return to the source tree:
source "${HOME}/.storefront-axion-env"
cd "${REPO}"
export FRONTEND_IP="$(kubectl get service frontend-external \
-o jsonpath='{.status.loadBalancer.ingress[0].ip}')"
export APP_URL="http://${FRONTEND_IP}"
Use the first terminal for collecting telemetry, the second terminal for the dashboard web server, and the third terminal for live traffic and fixed benchmarks.
Start telemetry collection
Run the following command in the first terminal. The rm command clears previous live telemetry samples for the dashboard:
cd "${REPO}" || exit 1
rm -f workshop/telemetry-live.jsonl
python3 workshop/telemetry_collector.py \
--interval-seconds 2 \
--output-file workshop/telemetry-live.jsonl
Leave this command running.
Start the dashboard
Run the following command in the second terminal. The rm command clears previous live request data for the dashboard:
rm -f workshop/request-live.jsonl workshop/request-live.log
python3 workshop/mini_dashboard.py \
--telemetry-file workshop/telemetry-live.jsonl \
--request-file workshop/request-live.jsonl \
--port 5000
If port 5000 is already in use, choose another available port, such as 5001. If you use Cloud Shell, open Web Preview and select the port you used.
Confirm assistant health
Run the following command in the third terminal to confirm the health of the assistant:
kubectl rollout status deployment/shoppingassistantservice --timeout=1200s
kubectl get pods -o wide | grep -E 'frontend|shoppingassistantservice'
Generate a short live burst
Start a short request burst in the third terminal so the dashboard shows activity:
rm -f workshop/request-live.pid
python3 workshop/request_driver.py \
--base-url "${APP_URL}" \
--concurrency 4 \
--delay-seconds 0 \
--output-file workshop/request-live.jsonl > workshop/request-live.log 2>&1 &
echo $! > workshop/request-live.pid
Let it run for about 20 seconds, then inspect the recent log lines:
sleep 20
tail -n 20 workshop/request-live.log
Stop the live burst before you run the fixed benchmark:
REQUEST_DRIVER_PID="$(cat workshop/request-live.pid)"
if [ -n "${REQUEST_DRIVER_PID}" ] && \
ps -p "${REQUEST_DRIVER_PID}" -o command= | grep -q 'workshop/request_driver.py'; then
kill "${REQUEST_DRIVER_PID}"
wait "${REQUEST_DRIVER_PID}" 2>/dev/null || true
fi
Stopping the live burst keeps the N4A and C4A benchmark runs comparable.
Run the fixed N4A benchmark
Run the fixed batch in the third terminal while the assistant is still on N4A:
python3 workshop/fixed_batch_trial.py \
--expected-pool "${N4A_NODE_POOL_NAME}" \
--concurrency 2 \
--prompts-per-worker 8 \
--delay-seconds 0.2 \
--request-timeout-seconds 120 \
--telemetry-interval-seconds 0.5 \
--idle-threshold-cores 1.0 \
--idle-stable-samples 3 \
--idle-timeout-seconds 180 \
--request-output-file workshop/request-fixed-n4a.jsonl \
--telemetry-output-file workshop/telemetry-fixed-n4a.jsonl | \
tee workshop/fixed-n4a-summary.log
The command can keep running after the last request lines appear. It’s still sampling telemetry and waiting for the assistant to settle back toward idle.
Print the summary line:
grep 'SUMMARY_JSON' workshop/fixed-n4a-summary.log
The summary shows successful requests and the assistant running on the N4A node pool. Don’t continue if the summary line is missing or reports a different node pool.
You’ve now observed the assistant as a live workload and captured the N4A benchmark baseline.
Next, you’ll move only the assistant tier to C4A and run the same benchmark again.
