Build one Arm image for both Axion placements
You need only one linux/arm64 assistant image for both the N4A and C4A pools, and that image can run in either placement.
Note
This is an Arm-targeted build for Axion, not a full multi-architecture build. A multi-architecture image is useful when the same tag must support non-Arm environments such as linux/amd64.
If you opened a new terminal, return to the source tree and restore the required variables:
source "${HOME}/.storefront-axion-env"
cd "${REPO}"
Confirm the image name
Confirm the reusable image path you configured during setup:
echo "${ASSISTANT_IMAGE}"
Use buildx to build and push the assistant image
Build the assistant image for linux/arm64 and push it to Artifact Registry:
docker buildx build --platform linux/arm64 -t "${ASSISTANT_IMAGE}" --push src/shoppingassistantservice
The command packages the Flask assistant service, protobuf stubs, and Python dependencies. The important success signal is that the build finishes and pushes the image to your Artifact Registry path.
Verify the pushed tag
List the tags for the assistant image:
gcloud artifacts docker tags list "${ASSISTANT_IMAGE_REPO}"
The output includes the lab-v1 tag.
You’ve now built and published an Arm image for the shopping assistant. Kubernetes can now pull this image when you deploy the assistant on N4A.
Next, you’ll create the N4A overlay and add the assistant to the running storefront.
