Give feedback
AI-assisted
Close
How do I verify the cluster has both N4A and C4A node pools before I start?
Use kubectl to list nodes and confirm that both pools are present. The workflow assumes an arm64 GKE Standard cluster with separate N4A and C4A pools.
What result should I expect after I apply the baseline overlay?
The storefront runs on N4A, and shoppingassistantservice isn’t present. This is intentional because you’ll build and deploy the assistant in later steps.
I've run this path before. What should I remove before I recreate the baseline?
Delete any existing assistant deployment, related service, and service account so the baseline reflects a storefront without the assistant.
Do I need different container images for N4A and C4A when I deploy the assistant?
No. You’ll build one linux/arm64 image targeted for Axion that’ll run in either placement.
How do I confirm the assistant is scheduled on the intended node pool when I switch from N4A to C4A?
Check the node assigned to the assistant pod and verify it matches the target pool after applying the appropriate Kustomize overlay. Inspect pod logs and service reachability to confirm the tier is healthy before capturing benchmarks.
