Before you begin
Switch to the root user and install all required system packages. This ensures you have the correct Java version, build tools, and database dependencies for Spark, Hadoop, Hive, and Gluten on Arm64.
sudo -i
apt update
apt install -y \
openjdk-17-jdk wget tar git curl unzip build-essential \
python3-pip mysql-server maven cmake ninja-build pkg-config libssl-dev
Java runtime is necessary for Spark and Hadoop. C++ dependencies are necessary for building Gluten. MySQL is necessary for Hive metastore.
Configure hostname
Hadoop requires a proper hostname for internal communication.
Set the hostname to spark-master so that Hadoop and Spark can communicate reliably on a single-node cluster. This prevents networking issues during service startup.
hostnamectl set-hostname spark-master
exec bash
Configure hosts
Append the hostname to /etc/hosts to ensure all Hadoop and Spark services resolve the local node correctly. This prevents connection errors.
echo "127.0.0.1 spark-master" >> /etc/hosts
Set up passwordless SSH
Generate an SSH key pair for passwordless authentication. Hadoop daemons use SSH to manage services internally, so this step is required for smooth operation.
ssh-keygen -t rsa -P ""
When prompted to enter the file location, press the Enter button to accept the default:
        Enter file in which to save the key (/root/.ssh/id_rsa):
Your identification has been saved in /root/.ssh/id_rsa
Your public key has been saved in /root/.ssh/id_rsa.pub
Append the public key to authorized_keys to enable passwordless SSH for the root user:
cat ~/.ssh/id_rsa.pub >> ~/.ssh/authorized_keys
Install Hadoop
Hadoop provides HDFS for storage and YARN for resource management.
Install Hadoop:
cd /opt
wget https://archive.apache.org/dist/hadoop/common/hadoop-3.3.1/hadoop-3.3.1-aarch64.tar.gz
tar -xvf hadoop-3.3.1-aarch64.tar.gz
ln -s hadoop-3.3.1 hadoop
Install Spark
Spark is the main engine for SQL and analytics.
Download and extract Apache Spark 3.4.2 built for Hadoop 3. This is the main analytics engine for running SQL and DataFrame workloads.
wget https://archive.apache.org/dist/spark/spark-3.4.2/spark-3.4.2-bin-hadoop3.tgz
tar -xvf spark-3.4.2-bin-hadoop3.tgz
ln -s spark-3.4.2-bin-hadoop3 spark
Install Hive
Download and extract Apache Hive 3.1.3. Hive provides the SQL metadata layer and metastore for Spark SQL.
wget https://archive.apache.org/dist/hive/hive-3.1.3/apache-hive-3.1.3-bin.tar.gz
tar -xvf apache-hive-3.1.3-bin.tar.gz
ln -s apache-hive-3.1.3-bin hive
Set up environment variables
Set up environment variables for Java, Hadoop, Spark, and Hive. This ensures all commands and scripts can find the correct binaries and configuration files.
cat >> ~/.consolerc <<EOF
export JAVA_HOME=/usr/lib/jvm/java-17-openjdk-arm64
export HADOOP_HOME=/opt/hadoop
export HADOOP_CONF_DIR=${HADOOP_HOME}/etc/hadoop
export YARN_CONF_DIR=${HADOOP_HOME}/etc/hadoop
export SPARK_HOME=/opt/spark
export HIVE_HOME=/opt/hive
export PATH=\$JAVA_HOME/bin:\$HADOOP_HOME/bin:\$SPARK_HOME/bin:\$HIVE_HOME/bin:\$PATH
EOF
Apply the environment changes to your current shell:
source ~/.consolerc
Set up Hadoop directories
HDFS needs storage directories.
Create the required HDFS storage directories for the NameNode and DataNode. This is necessary for Hadoop to manage its file system state.
mkdir -p $HADOOP_HOME/dfs/name
mkdir -p $HADOOP_HOME/dfs/data
mkdir -p /opt/dfs/data
Configure Hadoop
Create a minimal core-site.xml to define the default HDFS URI for a single-node cluster.
cat > $HADOOP_HOME/etc/hadoop/core-site.xml <<EOF
<configuration>
<property>
<name>fs.defaultFS</name>
<value>hdfs://spark-master:9000</value>
</property>
</configuration>
EOF
Create a minimal hdfs-site.xml to configure HDFS for single-node operation.
cat > $HADOOP_HOME/etc/hadoop/hdfs-site.xml <<EOF
<configuration>
<property>
    <name>dfs.replication</name>
    <value>1</value>
</property>
<property>
    <name>dfs.hosts</name>
    <value>/opt/hadoop/etc/hadoop/workers</value>
</property>
<property>
    <name>dfs.namenode.name.dir</name>
    <value>file:/opt/hadoop/dfs/name</value>
</property>
<property>
    <name>dfs.namenode.data.dir</name>
    <value>file:/opt/hadoop/dfs/data</value>
</property>
<property>
    <name>dfs.datanode.data.dir</name>
    <value>/opt/dfs/data</value>
</property>
</configuration>
EOF
Create a minimal yarn-site.xml optimized for Arm64, specifying the resource manager hostname and available resources.
cat > $HADOOP_HOME/etc/hadoop/yarn-site.xml <<EOF
<configuration>
<property><name>yarn.resourcemanager.hostname</name><value>spark-master</value></property>
<property><name>yarn.nodemanager.resource.memory-mb</name><value>8192</value></property>
<property><name>yarn.nodemanager.resource.cpu-vcores</name><value>4</value></property>
</configuration>
EOF
Fix Java 17 compatibility issue
Create hadoop-env.sh to fix Java 17 reflection issues and ensure Hadoop, Spark, and Gluten stability:
cat >> $HADOOP_HOME/etc/hadoop/hadoop-env.sh <<EOF
export HDFS_NAMENODE_USER=root
export HDFS_DATANODE_USER=root
export HDFS_SECONDARYNAMENODE_USER=root
export YARN_RESOURCEMANAGER_USER=root
export YARN_NODEMANAGER_USER=root
export HADOOP_OPTS="--add-opens java.base/java.lang=ALL-UNNAMED"
EOF
Start Hadoop
To start Hadoop, run:
hdfs namenode -format
export HADOOP_CONF_DIR=$HADOOP_HOME/etc/hadoop
$HADOOP_HOME/sbin/start-dfs.sh
$HADOOP_HOME/sbin/start-yarn.sh
The output from start-dfs.sh is similar to:
        Starting namenodes on [spark-master]
Starting datanodes
Starting secondary namenodes [spark-master]
The output from start-yarn.sh is similar to:
        Starting resourcemanager
Starting nodemanagers
Verify that all Hadoop daemons are running:
jps
The output is similar to:
        53856 ResourceManager
54469 Jps
54245 NodeManager
53526 SecondaryNameNode
53036 NameNode
53276 DataNode
Set up Hive Metastore
Hive stores table metadata. To set up Hive Metastore, run:
mysql -u root <<EOF
CREATE DATABASE hive_metastore;
CREATE USER 'hiveuser'@'localhost' IDENTIFIED BY '123456';
GRANT ALL PRIVILEGES ON hive_metastore.* TO 'hiveuser'@'localhost';
FLUSH PRIVILEGES;
EOF
Configure Hive to use MySQL
By default, Hive uses the embedded Derby database for its metastore. Derby does not support MySQL SQL syntax, which causes the schema initialization to fail. You need to download the MySQL Java Database Connectivity (JDBC) connector. Then, configure Hive to connect to the MySQL metastore you created in the previous step.
Download the MySQL JDBC connector:
wget https://repo1.maven.org/maven2/mysql/mysql-connector-java/8.0.28/mysql-connector-java-8.0.28.jar -P $HIVE_HOME/lib/
Create hive-site.xml with the MySQL connection details:
cat > $HIVE_HOME/conf/hive-site.xml <<EOF
<configuration>
  <property>
    <name>javax.jdo.option.ConnectionURL</name>
    <value>jdbc:mysql://localhost/hive_metastore?createDatabaseIfNotExist=true</value>
  </property>
  <property>
    <name>javax.jdo.option.ConnectionDriverName</name>
    <value>com.mysql.cj.jdbc.Driver</value>
  </property>
  <property>
    <name>javax.jdo.option.ConnectionUserName</name>
    <value>hiveuser</value>
  </property>
  <property>
    <name>javax.jdo.option.ConnectionPassword</name>
    <value>123456</value>
  </property>
  <property>
    <name>hive.metastore.schema.verification</name>
    <value>false</value>
  </property>
</configuration>
EOF
Initialize Hive
Initialize the Hive metastore schema in MySQL and start the Hive metastore service in the background. This step is required before Spark can use Hive tables for SQL analytics.
$HIVE_HOME/bin/schematool -dbType mysql -initSchema
nohup hive --service metastore &
        Initialization script completed
schemaTool completed
Build Gluten with Velox
Build the Gluten project with the Velox backend to enable native C++ query execution in Spark. This process downloads all dependencies, compiles the engine, and prepares the Java Archives (JARs) needed for Spark integration. The sed commands ensure the build targets Spark 3.4 and disables S3 support for simplicity.
cd /opt
git clone https://github.com/apache/incubator-gluten.git
cd incubator-gluten
git checkout v1.3.0
sed -i 's/SPARK_VERSION=ALL/SPARK_VERSION=3.4/' dev/builddeps-veloxbe.sh
sed -i 's/--enable_s3=ON//g' dev/package.sh
./dev/package.sh
mkdir -p /opt/gluten-jars
cp package/target/*.jar /opt/gluten-jars/
Configure Spark to use Gluten
Configure Spark to use the Gluten plugin and Velox backend by creating a spark-defaults.conf file. This enables native execution, sets resource limits, and ensures the correct JARs are loaded for both the driver and executors.
cat > $SPARK_HOME/conf/spark-defaults.conf <<EOF
spark.master yarn
spark.executor.instances 2
spark.executor.cores 2
spark.executor.memory 3g
spark.driver.memory 3g
spark.sql.shuffle.partitions 50
spark.plugins org.apache.gluten.GlutenPlugin
spark.gluten.enabled true
spark.memory.offHeap.enabled true
spark.memory.offHeap.size 2g
spark.gluten.sql.columnar.backend.lib velox
spark.driver.extraClassPath /opt/gluten-jars/*
spark.executor.extraClassPath /opt/gluten-jars/*
EOF
Start Spark Thrift Server
Start the Spark Thrift Server, which allows you to connect to Spark SQL using JDBC/Open Database Connectivity (ODBC) clients. This is the main entry point for running SQL queries and benchmarks.
$SPARK_HOME/sbin/start-thriftserver.sh
Verify that the Thrift Server processes are running:
jps
229942 Jps
54245 NodeManager
229910 ExecutorLauncher
229637 SparkSubmit
55622 RunJar
53036 NameNode
53276 DataNode
You’ve now created a fully operational Spark SQL cluster on Arm64 with native acceleration enabled. You installed and configured Hadoop, Spark, and Hive, built Gluten with the Velox backend, and set up native off-JVM query execution on your Azure Cobalt 100 VM.
Next, you’ll generate a TPC-DS dataset, load it into HDFS, create Spark SQL tables, and run analytical queries to measure the performance improvement over standard Spark.
